[petsc-users] Using PETSC with an openMP program
Adrián Amor
aamor at pa.uc3m.es
Fri Mar 2 09:00:00 CST 2018
Hi all,
I have been working in the last months with PETSC in a FEM program written
on FORTRAN, so far sequential. Now, I want to parallelize it with OpenMP
and I have found some problems. Finally, I have built a mockup program
trying to localize the error.
1. I have compiled PETSC with these options:
./configure --with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort
--with-blas-lapack-dir=/opt/intel/mkl/lib/intel64/ --with-debugging=1
--with-scalar-type=complex --with-threadcomm --with-pthreadclasses
--with-openmp
--with-openmp-include=/opt/intel/compilers_and_libraries_2016.1.150/linux/compiler/lib/intel64_lin
--with-openmp-lib=/opt/intel/compilers_and_libraries_2016.1.150/linux/compiler/lib/intel64_lin/libiomp5.a
PETSC_ARCH=linux-intel-dbg PETSC-AVOID-MPIF-H=1
(I have tried also removing --with-threadcomm --with-pthreadclasses and
with libiomp5.so).
2. The program to be executed is composed of two files, one is
hellocount.F90:
MODULE hello_count
use omp_lib
IMPLICIT none
CONTAINS
subroutine hello_print ()
integer :: nthreads,mythread
!pragma hello-who-omp-f
!$omp parallel
nthreads = omp_get_num_threads()
mythread = omp_get_thread_num()
write(*,'("Hello from",i3," out of",i3)') mythread,nthreads
!$omp end parallel
!pragma end
end subroutine hello_print
END MODULE hello_count
and the other one is hellocount_main.F90:
Program Hello
USE hello_count
call hello_print
STOP
end Program Hello
3. To compile these two functions I use:
rm -rf _obj
mkdir _obj
ifort -E -I/home/aamor/petsc/include
-I/home/aamor/petsc/linux-intel-dbg/include -c hellocount.F90
>_obj/hellocount.f90
-I/home/aamor/petsc/linux-intel-dbg/include -c hellocount_main.F90
>_obj/hellocount_main.f90
mpiifort -CB -g -warn all -O0 -shared-intel -check:none -qopenmp -module
_obj -I./_obj -I/home/aamor/MUMPS_5.1.2/include
-I/opt/intel/compilers_and_libraries_2016.1.150/linux/mkl/include
-I/opt/intel/compilers_and_libraries_2016.1.150/linux/mkl/include/intel64/lp64/
-I/home/aamor/petsc/include -I/home/aamor/petsc/linux-intel-dbg/include -o
_obj/hellocount.o -c _obj/hellocount.f90
_obj/hellocount_main.o -c _obj/hellocount_main.f90
_obj -I./_obj -o exec/HELLO _obj/hellocount.o _obj/hellocount_main.o
/home/aamor/lib_tmp/libarpack_LinuxIntel15.a
/home/aamor/MUMPS_5.1.2/lib/libzmumps.a
/home/aamor/MUMPS_5.1.2/lib/libmumps_common.a
/home/aamor/MUMPS_5.1.2/lib/libpord.a
/home/aamor/parmetis-4.0.3/lib/libparmetis.a
/home/aamor/parmetis-4.0.3/lib/libmetis.a
-L/opt/intel/compilers_and_libraries_2016.1.150/linux/mkl/lib/intel64
-lmkl_scalapack_lp64 -lmkl_blacs_intelmpi_lp64 -lpetsc -lmkl_intel_lp64
-lmkl_intel_thread -lmkl_core -lmkl_lapack95_lp64 -liomp5 -lpthread -lm
-L/home/aamor/lib_tmp -lgidpost -lz /home/aamor/lua-5.3.3/src/liblua.a
/home/aamor/ESEAS-master/libeseas.a
-Wl,-rpath,/home/aamor/petsc/linux-intel-dbg/lib
-L/home/aamor/petsc/linux-intel-dbg/lib
-Wl,-rpath,/opt/intel/mkl/lib/intel64 -L/opt/intel/mkl/lib/intel64
-Wl,-rpath,/opt/intel/impi/5.1.2.150/intel64/lib/debug_mt -L/opt/intel/impi/
5.1.2.150/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/impi/
5.1.2.150/intel64/lib -L/opt/intel/impi/5.1.2.150/intel64/lib
-Wl,-rpath,/opt/intel/compilers_and_libraries_2016/linux/mkl/lib/intel64
-L/opt/intel/compilers_and_libraries_2016/linux/mkl/lib/intel64
-Wl,-rpath,/opt/intel/compilers_and_libraries_2016.1.150/linux/compiler/lib/intel64_lin
-L/opt/intel/compilers_and_libraries_2016.1.150/linux/compiler/lib/intel64_lin
-Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.4.7
-L/usr/lib/gcc/x86_64-redhat-linux/4.4.7
-Wl,-rpath,/opt/intel/mpi-rt/5.1/intel64/lib/debug_mt
-Wl,-rpath,/opt/intel/mpi-rt/5.1/intel64/lib -lmkl_intel_lp64
-lmkl_sequential -lmkl_core -lpthread -lX11 -lssl -lcrypto -lifport
-lifcore_pic -lmpicxx -ldl -Wl,-rpath,/opt/intel/impi/
5.1.2.150/intel64/lib -L/opt/intel/impi/5.1.2.150/intel64/lib -lmpifort
-lmpi -lmpigi -lrt -lpthread -Wl,-rpath,/opt/intel/impi/
-Wl,-rpath,/opt/intel/mpi-rt/5.1/intel64/lib -limf -lsvml -lirng -lm -lipgo
-ldecimal -lcilkrts -lstdc++ -lgcc_s -lirc -lirc_s
-L/opt/intel/compilers_and_libraries_2016/linux/mkl/lib/intel64 -ldl
exec/HELLO
4. Then I have seen that:
4.1. If I set OMP_NUM_THREADS=2 and I remove -lpetsc and -lifcore_pic from
the last step, I got:
Hello from 0 out of 2
Hello from 1 out of 2
4.2 But if add -lpetsc and -lifcore_pic (because I want to use PETSC) I get
this error:
forrtl: severe (40): recursive I/O operation, unit -1, file unknown
Image PC Routine Line Source
HELLO 000000000041665C Unknown Unknown Unknown
HELLO 00000000004083C8 Unknown Unknown Unknown
libiomp5.so 00007F9C603566A3 Unknown Unknown Unknown
libiomp5.so 00007F9C60325007 Unknown Unknown Unknown
libiomp5.so 00007F9C603246F5 Unknown Unknown Unknown
libiomp5.so 00007F9C603569C3 Unknown Unknown Unknown
libpthread.so.0 0000003CE76079D1 Unknown Unknown Unknown
libc.so.6 0000003CE6AE88FD Unknown Unknown Unknown
If you set OMP_NUM_THREADS to 8, I get:
I am sorry if this is a trivial problem because I guess that lots of people
use PETSC with OpenMP in FORTRAN, but I have really done my best to figure
out where the error is. Can you help me?
Thanks a lot!
Adrian.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180302/3ef00b5d/attachment.html>
