[petsc-users] Segmentation fault inside PETSc
Lucas Clemente Vella
lvella at gmail.com
Thu Mar 1 14:01:52 CST 2018
After updating from PETSc 2.7.5 to 2.7.7 (alongside openmpi, but I don't
which version was installed, now is 2.1.1), my application started failing
insinde KspSetUp() when run with more than 1 process. GDB backtrace:
#0 0x00007fffca57f798 in mca_pml_ob1_recv_request_progress_rget () from
/usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi/mca_pml_ob1.so
#1 0x00007fffca57c4fd in mca_pml_ob1_recv_frag_callback_rget () from
#2 0x00007fffcafd32b0 in ?? () from
/usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi/mca_btl_self.so
#3 0x00007fffca58ad6a in mca_pml_ob1_send_request_start_rdma () from
#4 0x00007fffca577299 in mca_pml_ob1_isend () from
#5 0x00007ffff5574c35 in PMPI_Isend () from
/usr/lib/x86_64-linux-gnu/libmpi.so.20
#6 0x00007ffff6f94c02 in VecScatterCreate_PtoP(int, int const*, int, int
const*, _p_Vec*, _p_Vec*, int, _p_VecScatter*) ()
from /usr/lib/x86_64-linux-gnu/libpetsc_real.so.3.7
#7 0x00007ffff6f71bf3 in VecScatterCreate () from
#8 0x00007ffff7563247 in ?? () from
#9 0x00007ffff747d911 in PCSetUp () from
#10 0x00007ffff759874f in KSPSetUp () from
Is this some known problem that affected more users? What could be the
problem?
lvella at gmail.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180301/05bf2d65/attachment.html>
