[petsc-users] "snes_type test" is gone?
Smith, Barry F.
bsmith at mcs.anl.gov
Fri Jun 29 17:16:51 CDT 2018
I think you need to write your own tester, possibly by taking code from the previous release of PETSc where we supported -snes_type test.
Barry
Note that the new code does a much more comprehensive testing of the Jacobian.
> On Jun 29, 2018, at 5:06 PM, Alexander Lindsay <alexlindsay239 at gmail.com> wrote:
> Is there a way to mimic the behavior of `-snes_type test` with new PETSc? E.g. don't attempt to perform any solves? They're stupid but we have a bunch of tests in MOOSE that are set-up only to test the Jacobian, and any attempts to actually solve the system are disastrous. I can hack around this by doing things like setting the convergence reason to `SNES_CONVERGED_ITS` and similarly for ksp, making sure I use `-pc_type gamg` since there are missing Jacobian diagonal entries, etc. but this doesn't seem ideal.
> Alex
> On Mon, Jun 4, 2018 at 4:26 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> Thanks, Hong,
> I see. It is better if "-snes_type test" did not exist at the first place.
> Fande,
> On Mon, Jun 4, 2018 at 4:01 PM, Zhang, Hong <hongzhang at anl.gov> wrote:
> > On Jun 4, 2018, at 4:59 PM, Zhang, Hong <hongzhang at anl.gov> wrote:
> > -snes_type has been removed. We can just use -snes_test_jacobian instead. Note that the test is done every time the Jacobian is computed.
> It was meant to be "-snes_type test".
> > Hong (Mr.)
> >> On Jun 4, 2018, at 3:27 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> >> Hi PETSc Team,
> >> I was wondering if "snes_type test" has been gone? Quite a few MOOSE users use this option to test their Jacobian matrices.
> >> If it is gone, any reason?
> >> Fande,
