[petsc-users] Solve for all repeated eigenvalues
Vinh Pham-Xuan vinh.phamxuan2 at mail.dcu.ie
Thu Jun 28 16:51:46 CDT 2018
You may try the contour integral method (CISS). Obviously, it is
computationally more expensive. I used the contour integral method on
MATLAB and it worked quite well. I expected the same result with SLEPc.
On Thu, 28 Jun 2018 at 23:22, Jose E. Roman <jroman at dsic.upv.es> wrote:
> This is a known issue of Krylov solvers. Sometimes you can workaround it
> by increasing the number of eigenvalues to compute (nev, for instance
> request twice as much as you need) and maybe reduce the mpd parameter to
> force more restarts. This approach is quite wasteful and still there is no
> guarantee that you get the full multiplicities right.
> To avoid the issue completely, use the lobpcg solver. However, SLEPc's
> implementation of lobpcg is not very well tuned, I have to take some time
> to improve it. You can also try the BLOPEX interface (configure
> --download-blopex in SLEPc).
> Jose
> > El 28 jun 2018, a las 22:53, Greg Meyer <gregory.meyer at gmail.com>
> escribió:
> > Hi all,
> > I'm using SLEPc to solve for some eigenvalues. If I ask for the
> eigenvalues with the leftmost real part (using SMALLEST_REAL), and there
> are repeated eigenvalues, it appears that the solver does not always find
> all of the repeated values before jumping up to the next unique eigenvalue.
> For example if the lowest eigenvalues of my matrix are [-12, -10, -10, -10,
> -8], and I request 4 eigenvalues, I may get [-12, -10, -10, -8]. I'm using
> the default solver. Is there any way, or any solver, that ensures that no
> eigenvalues are skipped?
> > Thanks in advance,
> > Greg
Vinh Pham-Xuan, Ph.D
School of Electronic Engineering
Dublin City University
Ireland
__
Séanadh Ríomhphoist/_
Email Disclaimer__
Tá an ríomhphost seo agus
aon chomhad a sheoltar leis faoi rún agus is lena úsáid ag an seolaí agus
sin amháin é. Is féidir tuilleadh a léamh anseo.
<https://www4.dcu.ie/iss/seanadh-riomhphoist.shtml>
<https://www4.dcu.ie/iss/seanadh-riomhphoist.shtml>*
_
This e-mail and any
files transmitted with it are confidential and are intended solely for use
by the addressee. Read more here.
<https://www4.dcu.ie/iss/email-disclaimer.shtml> _
*_
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180628/3f4fca82/attachment-0001.html>
