[petsc-users] Reusing pseudo time-stepper
Smith, Barry F. bsmith at mcs.anl.gov
Mon Jun 25 16:12:54 CDT 2018
   It is intended to be reusable as you are attempting.
   You will have to either (1) run in the debugger with some break points to see why the initial time is always forced to be so small (2) send us the code so we can reproduce the problem.
   Barry
> On Jun 25, 2018, at 3:55 PM, zakaryah <zakaryah at gmail.com> wrote:
> I'm interested in using a time-stepper to solve problems arising from multiple data sets (external forces).  Currently, I do the following:
> TSCreate
> TSSetProblemType
> TSSetSolution
> TSSetDM
> TSSetRHSFunction
> TSSetRHSJacobian
> TSSetType
> TSSetMaxSteps
> TSSetMaxTime
> TSSetExactFinalTime
> TSSetMaxStepRejections
> then, inside the loop over different data sets:
> TSSetTimeStep
> TSPseudoSetTimeStepIncrement
> TSSetTime        (to zero)
> TSSetStepNumber    (to zero)
> TSSetUp
> TSSolve
> This seems to be working, but the step increment behaves oddly on every loop iteration after the first.  Regardless of what I set the time step to, the first TSSolve iteration makes a step which is about twelve orders of magnitude smaller than the specified dt, and from that point on, the controller multiplies every step size by the specified pseudo time step increment (1.5), up until the very end, at which point the multiplier becomes very large as expected near convergence.
> If I create, set up, and destroy the TS in each iteration of the loop, the behavior is as expected, i.e. the first step is almost always by the specified dt.  Is there additional information inside the TS that I need to reset?  Is it a bad idea to reuse a TS?
> A couple tangential questions - I don't seem to be getting any output from -ts_adapt_monitor, and calling TSSetMaxStepRejections(ts,(PetscInt)-1) seems to set the maximum number of accepted step rejections to zero, rather than to unlimited, as specified by the documentation.
> Thanks for any help you can provide!
