[petsc-users] PETSc Solver: Large iteration count for first solution
Najeeb Ahmad nahmad16 at ku.edu.tr
Sun Jun 24 14:26:47 CDT 2018
Very good point. Thank you for the clarification.
On Sun, Jun 24, 2018 at 8:46 PM Mark Adams <mfadams at lbl.gov> wrote:
> Note, you converged because of the relative tolerance so initial guess
> does not really matter except that the initial residual on the second time
> step may have more high frequency content then your first initial residual.
> On Sun, Jun 24, 2018 at 6:37 AM Najeeb Ahmad <nahmad16 at ku.edu.tr> wrote:
>> Hi Massimiliano,
>> Thanks for your feedback. Indeed i am using previous solution for the
>> subsequent ones and probably that is the reason for the faster convergence
>> for the subsequent iterations. As Matt suggested, i need to improve my
>> preconditioning to make first iteration converge faster.
>> Thanks
>> On Sun, Jun 24, 2018 at 3:26 PM Massimiliano Leoni <
>> leoni.massimiliano1 at gmail.com> wrote:
>>> Hi, are the various solves a time stepping procedure? Could it be that
>>> it is re-using the solution at a previous iteration as an initial guess for
>>> the subsequent ones, and for this reason it converges sooner?
>>> Massimiliano
>>> On sabato 23 giugno 2018 13:36:59 CEST Najeeb Ahmad wrote:
>>> Hi,
>>> I am trying to solve a  64008000 x  64008000 system using PETSc. The
>>> problem I am facing is that I am getting a very large iteration count for
>>> the first solution (order of thousands). For the subsequent soluitons, the
>>> iteration count is less. For instance, here is the iteration count for the
>>> first solution when my code is run on 32 processes.
>>> 2772 KSP Residual norm 1.198554448053e-07
>>> 2773 KSP Residual norm 1.190214006391e-07
>>> 2774 KSP Residual norm 1.181931531360e-07
>>> 2775 KSP Residual norm 1.173706620648e-07
>>> 2776 KSP Residual norm 1.165538874733e-07
>>> 2777 KSP Residual norm 1.157427896857e-07
>>> 2778 KSP Residual norm 1.149373293013e-07
>>> 2779 KSP Residual norm 1.141374671925e-07
>>> 2780 KSP Residual norm 1.133431645025e-07
>>> Linear solve converged due to CONVERGED_RTOL iterations 2780
>>> For the subsequent solutions, the iteration count is as follows:
>>> 116 KSP Residual norm 2.657138978992e-04
>>> 117 KSP Residual norm 2.767485246885e-04
>>> 118 KSP Residual norm 2.071574619161e-04
>>> 119 KSP Residual norm 2.273562103015e-04
>>> 120 KSP Residual norm 1.693847273193e-04
>>> 121 KSP Residual norm 1.803833437167e-04
>>> 122 KSP Residual norm 1.443434809819e-04
>>> 123 KSP Residual norm 1.390878278231e-04
>>> 124 KSP Residual norm 1.247521972621e-04
>>> 125 KSP Residual norm 1.059224678494e-04
>>> Linear solve converged due to CONVERGED_RTOL iterations 125
>>> The solver setup for my code is as follows:
>>>  ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
>>>   ierr = KSPSetOperators(ksp,A,A);CHKERRQ(ierr);
>>>   ierr = KSPSetType(ksp, KSPCG);CHKERRQ(ierr);
>>>   ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
>>>   ierr = PCSetType(pc, PCJACOBI);
>>>   ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
>>>   ierr = KSPSetUp(ksp);CHKERRQ(ierr);
>>> and the command line for running the code is:
>>> mpiexec -n 32 ./main -mat_type mpiaij -ksp_atol 1E-7 -ksp_rtol 1E-7
>>> -ksp_converged_reason -ksp_monitor
>>> Any help is highly appreciated.
>>> Najeeb Ahmad
>>> Research and Teaching Assistant
>>> PARallel and MultiCORE Computing Laboratory (ParCoreLab)
>>> Computer Science and Engineering
>>> Koç University, Istanbul, Turkey
>> *Najeeb Ahmad*
>> *Research and Teaching Assistant*
>> *PARallel and MultiCORE Computing Laboratory (ParCoreLab) *
>> *Computer Science and Engineering*
>> *Koç University, Istanbul, Turkey*
*Najeeb Ahmad*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180625/5a568b21/attachment.html>
