[petsc-users] detailed documentation for benchmarkExample.py
Fri Jun 15 18:11:16 CDT 2018
On Fri, Jun 15, 2018 at 6:30 PM Storm Weiner <stormweiner at berkeley.edu>
wrote:
> Hey there,
> I'm trying to use the benchmark example script but I don't understand the
> usage.
I have not updated the script. We now use -log_view, and so the option
would be
  -log_view :summary.py:ascii_info_detail
Eventually, I will update it. We are working on it now.
    Matt
> For reference, I am talking about the script located at
> *petsc/src/benchmarks/benchmarkExample.py*
> I execute using the suggested example parameters at the bottom of the
> script
> *>> ./src/benchmarks/benchmarkExample.py --events IntegBatchCPU
> IntegBatchGPU IntegGPUOnly --num 52 DMComplex --refine 0.0625 0.00625
> 0.000625 0.0000625 --blockExp 4 --order=1 CPU='dm_view show_residual=0
> compute_function batch' GPU='dm_view show_residual=0 compute_function batch
> gpu gpu_batches=8'*
> *Namespace(batch=False, comp=4, daemon=False, events=['VecMDot',
> 'VecMAXPY', 'KSPGMRESOrthog', 'MatMult', 'VecCUSPCopyTo',
> 'VecCUSPCopyFrom', 'MatCUSPCopyTo'], gpulang='OpenCL', library='SNES',
> module='summary', num=50, runs=["CPU='pc_type=none", 'mat_no_inode',
> 'dm_vec_type=seq', "dm_mat_type=seqaij'", "GPU='pc_type=none",
> 'mat_no_inode', 'dm_vec_type=seqcusp', 'dm_mat_type=seqaijcusp',
> "cusp_synchronize'"], size=['10', '20', '50', '100'],
> stage='Main_Stage')Executing:
> /g/g19/weiner6/petsc/arch-mvapich-fftw3/lib/snes/ex50 -preload off
> -log_summary summary.dat -log_summary_python summary.py -'pc_type none
> -da_grid_x 10 -da_grid_y 10/bin/sh: -c: line 0: unexpected EOF while
> looking for matching `''/bin/sh: -c: line 1: syntax error: unexpected end
> of fileTraceback (most recent call last):  File "./benchmarkExample.py",
> line 453, in <module>    run_DMDA(ex, name, opts, args, sizes, times,
> events, log=log)  File "./benchmarkExample.py", line 356, in run_DMDA
> processSummary('summary', args.stage, args.events, times[name],
> events[name])  File "./benchmarkExample.py", line 123, in processSummary
> m = __import__(moduleName)ImportError: No module named summary*
> There are two issues here.
> 1) the script attempts to run *petsc/arch-mvapich-fftw3/lib/snes/ex50*
> when it should attempt to run
> *petsc/src/<library>/examples/tutorials/ex<num>* as indicated in the help
> menu. In fact, there is no *petsc/<arch>/lib/snes* directory.
> 2) The *"No module named summary"* error causes the python script to
> crash.
> What is going on here? How should I be using this script?  Is there any
> documentation to describe the usage?  I find the help menu to be a bit too
> sparse and the source code too dense to follow closely.
> More specifically, I want to use this profiling script for more than just
> the standard petsc examples.  If I understand the source correctly, the
> simplest way to accomplish that is to create a new directory tree *petsc/src/dummy_lib/examples/tutorials
> *and populate it with *ex<num> *compiled executables.  I would then
> access these by running benchmarkExample.py with the *--library dummy_lib*
> argument.  Is this a reasonable way to benchmark arbitrary petsc programs?
> Thanks for your time,
> Storm
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180615/92ffb585/attachment-0001.html>
