[petsc-users] residual norm with TSPSEUDO
Praveen C cpraveen at gmail.com
Wed Jun 13 10:54:05 CDT 2018
Hello Barry
I am working in Fortran :-(
I can see the residual if I use -info but it prints too much information. Is it possible to reduce the amount of log messages printed to screen, some sort of log-level ???
Thanks
praveen
> On 13-Jun-2018, at 8:29 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   Take a look at TSPseudoMonitorDefault() in src/ts/impls/pseudo/posindep.c
>    The problem is that you need to expose
> typedef struct {
>  Vec update;       /* work vector where new solution is formed */
>  Vec func;         /* work vector where F(t[i],u[i]) is stored */
>  Vec xdot;         /* work vector for time derivative of state */
>  /* information used for Pseudo-timestepping */
>  PetscErrorCode (*dt)(TS,PetscReal*,void*);              /* compute next timestep, and related context */
>  void *dtctx;
>  PetscErrorCode (*verify)(TS,Vec,void*,PetscReal*,PetscBool*);  /* verify previous timestep and related context */
>  void *verifyctx;
>  PetscReal fnorm_initial,fnorm;                   /* original and current norm of F(u) */
>  PetscReal fnorm_previous;
>  PetscReal dt_initial;                     /* initial time-step */
>  PetscReal dt_increment;                   /* scaling that dt is incremented each time-step */
>  PetscReal dt_max;                         /* maximum time step */
>  PetscBool increment_dt_from_initial_dt;
>  PetscReal fatol,frtol;
> } TS_Pseudo;
> inside your application code (that is make a copy of this struct definition and put it in your code so you can access the fields).
>   Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180613/e39d1f7a/attachment-0001.html>
