[petsc-users] DMPlex CGNS import
Fri Jun 8 13:49:52 CDT 2018
On Fri, Jun 8, 2018 at 8:45 AM, Valerio Barnabei <valerio.barnabei at gmail.com
> wrote:
> Hello,
> I'm trying to import a simple CGNS file representing a simple 3D
> unstructured box, but i keep getting the same error:
> [0]PETSC ERROR: Error in external library
>> [0]PETSC ERROR: CGNS file must have a single section, not 2
CGNS support stinks because I never used it and no one else has requested
it. Also the format is not workable in parallel.
Here is the code
https://bitbucket.org/petsc/petsc/src/58edc67f565b6826877b6037e2237b6b17930a07/src/dm/impls/plex/plexcgns.c#lines-149
You can see I am just asking CGNS how many sections it has in the the zone.
I do not really know
what a section is, so I am limiting it to one section. The files you have
must have multiple sections
for reason that are not clear to me.
Here are some meshes I can read:
  https://bitbucket.org/petsc/petsc/src/master/share/petsc/datafiles/meshes/
    Matt
I'm using the following script:
>> #include <petscdmplex.h>
>> #include <cgnslib.h>
>> int main(int argc, char **argv){
>>     char MeshFileName[2048];
>>     MPI_Comm comm;
>>     DM dm;
>>     PetscErrorCode ierr;
>>     PetscBool flg;
>>     ierr = PetscInitialize(&argc, &argv, NULL,NULL);if (ierr) return ierr;
>>     ierr = PetscOptionsGetString(NULL,NULL,"-file",MeshFileName,
>> sizeof(MeshFileName),&flg);CHKERRQ(ierr);
>>     comm= PETSC_COMM_WORLD;
>>     if(!flg){
>>                SETERRQ(comm,PETSC_ERR_ARG_NULL,"please specify a fine
>> mesh file \n");
>>     ierr = DMPlexCreateCGNSFromFile(comm, MeshFileName, PETSC_FALSE,
>> &dm);CHKERRQ(ierr);
>>     ierr = DMDestroy(&dm);CHKERRQ(ierr);
>>     ierr = PetscFinalize();CHKERRQ(ierr);
>> return ierr;
> I'm not using a multiblock mesh, i just created a single unstructured
> block volume in pointwise, exported as adf (using hdf i got a crash during
> file opening so i switched). I tried with different exportation options
> (node to node, cell to cell, face to face) but nothing seems to work.
> I got the same identical error also downloading files from official CGNS
> site:
> http://cgns.sourceforge.net/CGNSFiles.html
> It's obvious there's something I'm missing.
> -Where is my mistake?
> -Is there any notable limitation in the importation of CGNS file? (e.g.
> multiblock files can't be imported as dmplex objects)
> Thanks in advance for your kind help.
> Valerio
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180608/52272763/attachment.html>
