[petsc-users] removing cells from existing DMPLEX
Fri Jun 8 13:43:06 CDT 2018
On Fri, Jun 8, 2018 at 5:10 AM, Matteo Semplice <matteo.semplice at unito.it>
wrote:
> Hi.
> We are developing a ghost-fluid type scheme, so we start creating a
> (cartesian) grid and then "mark" some cells in which the evolution actually
> takes place and solve a PDE only there.
> We currently handle the grid via a DMPLEX, we through a Label that marks
> the fluid cells we define a trivial operator for the non-fluid part of the
> grid, but of course the dofs attached to those cells and faces are still
> there in the Vec's and in the output.
> We know that (sometimes large) portions of the original grid will never be
> touched during the evolution, so we would like to remove those from the
> DMPLEX before partitioning it. Is there a simple way to do it? Ideally
> automagically via a Label or an IndexSet...
Can this do what you want?
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexFilter.html
If so, I would caution you that no one uses this right now, so it might
forget to do something (say edit out all those
things from existing labels). I will fix anything that gives you a problem.
    Matt
> The second best option would be to give less weight to the non-fluid
> portion of the DM when partitioning the DMPLEX: is there an example showing
> the use of weights in a Plex partitioner?
> Thanks in advance for your time.
> Best,
>    Matteo
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180608/d8d48ee0/attachment-0001.html>
