[petsc-users] MKL Pardiso Solver Execution Step control
Matthew Overholt overholt at capesim.com
Tue Jun 5 13:36:10 CDT 2018
On Tue, Jun 5, 2018 at 1:48 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> > On Jun 5, 2018, at 4:08 PM, Matthew Overholt <overholt at capesim.com>
> wrote:
> > Yes to Matthew - not repeating Phase 1: Fill-reduction analysis and
> symbolic factorization .  Numerical factoring is required because the
> matrix values have changed (although only slightly) as well as the RHS.
> > We are using KSPPREONLY with Picard iterations.  Thank you, Barry, for
> the KSP*Preconditioner calls I wasn't aware of.
> > It sounds like PETSc and/or Pardiso automatically determines whether
> Phase 1 is required or not, but if we want to force a new Phase 1 (such as
> in a long unsteady run), then I suppose we could just destroy KSP and
> remake it.
>    I'm confused. Yes PETSc will do a new analysis if the nonzero structure
> changes otherwise it will never do a new analysis.
>    Is your nonzero structure changing?
>    If you nonzero structure is not changing you have to do nothing.
>    If the nonzero structure does change than the code needs to do a new
> analysis because the old factors (for the numerical part) cannot work with
> the new nonzero locations of the matrix.
>     I really don't see why you have to do anything?
>     Barry
> No, the nonzero structure never changes.  Redoing the analysis is not
required, in the sense that a solution can still be obtained without it;
however, for long unsteady runs (with heat sources turning on and off) the
matrix values change so much that, without redoing the analysis, more
iterations are required to converge at each time step, resulting in a
doubling of the total solve time compared to when the analysis is
periodically redone.  I don't know exactly what Pardiso is doing "under the
hood" but that has been our experience.
Matt...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180605/64a1ce4a/attachment.html>
