[petsc-users] Poor weak scaling when solving successive linearsystems
Michael Becker Michael.Becker at physik.uni-giessen.de
Mon Jun 4 11:59:40 CDT 2018
Hello again,
this took me longer than I anticipated, but here we go.
I did reruns of the cases where only half the processes per node were
used (without -log_sync):
125 procs,1st           125 procs,2nd          1000 procs,1st
1000 procs,2nd
                    Max        Ratio Max        RatioMax
RatioMax        Ratio
KSPSolve 1.203E+02    1.0        1.210E+02    1.0        1.399E+02
1.1        1.365E+02    1.0
VecTDot            6.376E+00    3.7        6.551E+00    4.0 7.885E+00
2.9        7.175E+00    3.4
VecNorm            4.579E+00    7.1        5.803E+00   10.2 8.534E+00
6.9        6.026E+00    4.9
VecScale           1.070E-01    2.1        1.129E-01    2.2 1.301E-01
2.5        1.270E-01    2.4
VecCopy            1.123E-01    1.3        1.149E-01    1.3 1.301E-01
1.6        1.359E-01    1.6
VecSet             7.063E-01    1.7        6.968E-01    1.7 7.432E-01
1.8        7.425E-01    1.8
VecAXPY            1.166E+00    1.4        1.167E+00    1.4 1.221E+00
1.5        1.279E+00    1.6
VecAYPX            1.317E+00    1.6        1.290E+00    1.6 1.536E+00
1.9        1.499E+00    2.0
VecScatterBegin    6.142E+00    3.2        5.974E+00    2.8 6.448E+00
3.0        6.472E+00    2.9
VecScatterEnd      3.606E+01    4.2        3.551E+01    4.0 5.244E+01
2.7        4.995E+01    2.7
MatMult            3.561E+01    1.6        3.403E+01    1.5 3.435E+01
1.4        3.332E+01    1.4
MatMultAdd         1.124E+01    2.0        1.130E+01    2.1 2.093E+01
2.9        1.995E+01    2.7
MatMultTranspose   1.372E+01    2.5        1.388E+01    2.6 1.477E+01
2.2        1.381E+01    2.1
MatSolve           1.949E-02    0.0        1.653E-02    0.0 4.789E-02
0.0        4.466E-02    0.0
MatSOR             6.610E+01    1.3        6.673E+01    1.3 7.111E+01
1.3        7.105E+01    1.3
MatResidual        2.647E+01    1.7        2.667E+01    1.7 2.446E+01
1.4        2.467E+01    1.5
PCSetUpOnBlocks    5.266E-03    1.4        5.295E-03    1.4 5.427E-03
1.5        5.289E-03    1.4
PCApply            1.031E+02    1.0        1.035E+02    1.0 1.180E+02
1.0        1.164E+02    1.0
I also slimmed down my code and basically wrote a simple weak scaling
test (source files attached) so you can profile it yourself. I
appreciate the offer Junchao, thank you.
You can adjust the system size per processor at runtime via
"-nodes_per_proc 30" and the number of repeated calls to the function
containing KSPsolve() via "-iterations 1000". The physical problem is
simply calculating the electric potential from a homogeneous charge
distribution, done multiple times to accumulate time in KSPsolve().
A job would be started using something like
    mpirun -n 125 ~/petsc_ws/ws_test -nodes_per_proc 30 -mesh_size 1E-4
    -iterations 1000 \\
      -ksp_rtol 1E-6 \
      -log_view -log_sync\
      -pc_type gamg -pc_gamg_type classical\
      -ksp_type cg \
      -ksp_norm_type unpreconditioned \
      -mg_levels_ksp_type richardson \
      -mg_levels_ksp_norm_type none \
      -mg_levels_pc_type sor \
      -mg_levels_ksp_max_it 1 \
      -mg_levels_pc_sor_its 1 \
      -mg_levels_esteig_ksp_type cg \
      -mg_levels_esteig_ksp_max_it 10 \
      -gamg_est_ksp_type cg
, ideally started on a cube number of processes for a cubical process grid.
Using 125 processes and 10.000 iterations I get the output in
"log_view_125_new.txt", which shows the same imbalance for me.
Michael
Am 02.06.2018 um 13:40 schrieb Mark Adams:
> On Fri, Jun 1, 2018 at 11:20 PM, Junchao Zhang <jczhang at mcs.anl.gov
> <mailto:jczhang at mcs.anl.gov>> wrote:
>     Hi,Michael,
>       You can add -log_sync besides -log_view, which adds barriers to
>     certain events but measures barrier time separately from the
>     events. I find this option makes it easier to interpret log_view
>     output.
> That is great (good to know).
> This should give us a better idea if your large VecScatter costs are
> from slow communication or if it catching some sort of load imbalance.
>     --Junchao Zhang
>     On Wed, May 30, 2018 at 3:27 AM, Michael Becker
>     <Michael.Becker at physik.uni-giessen.de
>     <mailto:Michael.Becker at physik.uni-giessen.de>> wrote:
>         Barry: On its way. Could take a couple days again.
>         Junchao: I unfortunately don't have access to a cluster with a
>         faster network. This one has a mixed 4X QDR-FDR InfiniBand 2:1
>         blocking fat-tree network, which I realize causes parallel
>         slowdown if the nodes are not connected to the same switch.
>         Each node has 24 processors (2x12/socket) and four NUMA
>         domains (two for each socket).
>         The ranks are usually not distributed perfectly even, i.e. for
>         125 processes, of the six required nodes, five would use 21
>         cores and one 20.
>         Would using another CPU type make a difference
>         communication-wise? I could switch to faster ones (on the same
>         network), but I always assumed this would only improve
>         performance of the stuff that is unrelated to communication.
>         Michael
>>         The log files have something like "Average time for zero size
>>         MPI_Send(): 1.84231e-05". It looks you ran on a cluster with
>>         a very slow network. A typical machine should give less than
>>         1/10 of the latency you have. An easy way to try is just
>>         running the code on a machine with a faster network and see
>>         what happens.
>>         Also, how many cores & numa domains does a compute node have?
>>         I could not figure out how you distributed the 125 MPI ranks
>>         evenly.
>>         --Junchao Zhang
>>         On Tue, May 29, 2018 at 6:18 AM, Michael Becker
>>             Hello again,
>>             here are the updated log_view files for 125 and 1000
>>             processors. I ran both problems twice, the first time
>>             with all processors per node allocated ("-1.txt"), the
>>             second with only half on twice the number of nodes
>>             ("-2.txt").
>>>>             On May 24, 2018, at 12:24 AM, Michael Becker<Michael.Becker at physik.uni-giessen.de>
>>>>             <mailto:Michael.Becker at physik.uni-giessen.de>  wrote:
>>>>             I noticed that for every individual KSP iteration, six vector objects are created and destroyed (with CG, more with e.g. GMRES).
>>>                 Hmm, it is certainly not intended at vectors be created and destroyed within each KSPSolve() could you please point us to the code that makes you think they are being created and destroyed?   We create all the work vectors at KSPSetUp() and destroy them in KSPReset() not during the solve. Not that this would be a measurable distance.
>>             I mean this, right in the log_view output:
>>>             Memory usage is given in bytes:
>>>             Object Type Creations Destructions Memory Descendants' Mem.
>>>             Reports information only for process 0.
>>>             --- Event Stage 0: Main Stage
>>>             --- Event Stage 1: First Solve
>>>             --- Event Stage 2: Remaining Solves
>>>             Vector 23904 23904 1295501184 0.
>>             I logged the exact number of KSP iterations over the 999
>>             timesteps and its exactly 23904/6 = 3984.
>>             Michael
>>             Am 24.05.2018 um 19:50 schrieb Smith, Barry F.:
>>>                Please send the log file for 1000 with cg as the solver.
>>>                 You should make a bar chart of each event for the two cases to see which ones are taking more time and which are taking less (we cannot tell with the two logs you sent us since they are for different solvers.)
>>>>             This seems kind of wasteful, is this supposed to be like this? Is this even the reason for my problems? Apart from that, everything seems quite normal to me (but I'm not the expert here).
>>>>             Thanks in advance.
>>>>             Michael
>>>>             <log_view_125procs.txt><log_view_1000procs.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180604/34557441/attachment-0001.html>
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
/home/ritsat/beckerm/petsc_ws2/ws_test on a arch-linux-amd-opt named node1-051 with 125 processors, by beckerm Mon Jun  4 16:37:26 2018
Using Petsc Development GIT revision: v3.9.2-503-g9e88a8b  GIT Date: 2018-05-24 08:01:24 -0500
                         Max       Max/Min        Avg      Total
Time (sec):           2.249e+03      1.00000   2.249e+03
Objects:              4.205e+05      1.00000   4.205e+05
Flop:                 3.694e+11      1.15838   3.497e+11  4.372e+13
Flop/sec:            1.643e+08      1.15838   1.555e+08  1.944e+10
MPI Messages:         1.812e+07      3.38507   1.233e+07  1.542e+09
MPI Message Lengths:  2.261e+10      2.20109   1.418e+03  2.186e+12
MPI Reductions:       3.706e+05      1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flop
                            and VecAXPY() for complex vectors of length N --> 8N flop
Summary of Stages:   ----- Time ------  ----- Flop -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 1.4622e-01   0.0%  0.0000e+00   0.0%  1.200e+03   0.0%  1.802e+03        0.0%  1.700e+01   0.0%
 1:     First Solve: 2.9678e+00   0.1%  5.6491e+09   0.0%  4.212e+05   0.0%  3.421e+03        0.1%  5.660e+02   0.2%
 2: Remaining Solves: 2.2459e+03  99.9%  4.3710e+13 100.0%  1.541e+09 100.0%  1.417e+03       99.9%  3.700e+05  99.8%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flop: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flop in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flop                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
VecSet                 2 1.0 1.3185e-04 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided         12 1.0 9.4547e-03 1.6 0.00e+00 0.0 8.8e+03 4.0e+00 0.0e+00  0  0  0  0  0   0  0  2  0  0     0
BuildTwoSidedF        30 1.0 2.2989e-01 3.1 0.00e+00 0.0 7.1e+03 1.0e+04 0.0e+00  0  0  0  0  0   5  0  2  5  0     0
KSPSetUp               9 1.0 5.4758e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.8e+01  0  0  0  0  0   0  0  0  0  3     0
KSPSolve               1 1.0 2.9672e+00 1.0 4.82e+07 1.2 4.2e+05 3.4e+03 5.7e+02  0  0  0  0  0 100100100100100  1904
VecTDot               14 1.0 1.8083e-02 5.9 7.56e+05 1.0 0.0e+00 0.0e+00 1.4e+01  0  0  0  0  0   0  2  0  0  2  5226
VecNormBarrier         9 1.0 2.1014e-03 5.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNorm                9 1.0 9.9111e-04 1.2 4.86e+05 1.0 0.0e+00 0.0e+00 9.0e+00  0  0  0  0  0   0  1  0  0  2 61295
VecScale              42 1.0 4.4274e-04 3.0 9.47e+04 2.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 20631
VecCopy                1 1.0 1.2612e-04 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               178 1.0 1.3885e-03 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               14 1.0 2.0151e-03 2.0 7.56e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  2  0  0  0 46896
VecAYPX               49 1.0 2.4726e-03 2.1 6.46e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 32264
VecAssemblyBegin       2 1.0 2.3842e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd         2 1.0 2.1458e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBarrie     178 1.0 9.6261e-02 3.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
VecScatterBegin      178 1.0 1.4301e-02 4.6 0.00e+00 0.0 1.5e+05 1.4e+03 0.0e+00  0  0  0  0  0   0  0 37 15  0     0
VecScatterEnd        178 1.0 3.4915e-02 4.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatMult               50 1.0 8.9105e-02 1.5 1.05e+07 1.1 5.1e+04 2.1e+03 0.0e+00  0  0  0  0  0   2 22 12  7  0 13981
MatMultAdd            42 1.0 3.3666e-02 1.7 2.40e+06 1.3 2.8e+04 6.7e+02 0.0e+00  0  0  0  0  0   1  5  7  1  0  8183
MatMultTranspose      42 1.0 2.7552e-02 1.5 2.40e+06 1.3 2.8e+04 6.7e+02 0.0e+00  0  0  0  0  0   1  5  7  1  0 10000
MatSolve               7 0.0 3.0994e-05 0.0 8.40e+02 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    27
MatSOR                84 1.0 1.2700e-01 1.7 1.90e+07 1.2 4.7e+04 1.6e+03 1.4e+01  0  0  0  0  0   4 40 11  5  2 17715
MatLUFactorSym         1 1.0 9.7990e-05 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         1 1.0 1.5020e-05 5.2 3.14e+02 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    21
MatResidual           42 1.0 7.5414e-02 1.7 7.97e+06 1.2 4.7e+04 1.6e+03 0.0e+00  0  0  0  0  0   2 17 11  5  0 12369
MatAssemblyBegin      94 1.0 2.3261e-01 2.8 0.00e+00 0.0 7.1e+03 1.0e+04 0.0e+00  0  0  0  0  0   5  0  2  5  0     0
MatAssemblyEnd        94 1.0 2.2487e-01 1.1 0.00e+00 0.0 6.3e+04 2.1e+02 2.3e+02  0  0  0  0  0   7  0 15  1 41     0
MatGetRow        3100250 1.2 4.5413e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  14  0  0  0  0     0
MatGetRowIJ            1 0.0 1.0014e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCreateSubMats       6 1.0 5.7464e-01 1.5 0.00e+00 0.0 5.5e+04 1.8e+04 1.2e+01  0  0  0  0  0  16  0 13 67  2     0
MatCreateSubMat        4 1.0 9.9725e-02 1.0 0.00e+00 0.0 2.8e+03 2.8e+02 6.4e+01  0  0  0  0  0   3  0  1  0 11     0
MatGetOrdering         1 0.0 1.5283e-04 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatIncreaseOvrlp       6 1.0 7.9965e-02 1.3 0.00e+00 0.0 2.7e+04 1.0e+03 1.2e+01  0  0  0  0  0   2  0  6  2  2     0
MatCoarsen             6 1.0 2.0824e-02 1.1 0.00e+00 0.0 5.4e+04 6.0e+02 3.4e+01  0  0  0  0  0   1  0 13  2  6     0
MatZeroEntries         6 1.0 3.5489e-03 5.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatPtAP                6 1.0 3.1160e-01 1.0 1.13e+07 1.3 6.4e+04 2.7e+03 9.2e+01  0  0  0  0  0  10 23 15 12 16  4085
MatPtAPSymbolic        6 1.0 1.5794e-01 1.0 0.00e+00 0.0 3.4e+04 2.7e+03 4.2e+01  0  0  0  0  0   5  0  8  6  7     0
MatPtAPNumeric         6 1.0 1.4963e-01 1.0 1.13e+07 1.3 2.9e+04 2.6e+03 4.8e+01  0  0  0  0  0   5 23  7  5  8  8507
MatGetLocalMat         6 1.0 4.6241e-03 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          6 1.0 1.0492e-02 1.6 0.00e+00 0.0 2.0e+04 3.6e+03 0.0e+00  0  0  0  0  0   0  0  5  5  0     0
SFSetGraph            12 1.0 1.5020e-05 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetUp               12 1.0 1.6023e-02 1.1 0.00e+00 0.0 2.6e+04 6.3e+02 0.0e+00  0  0  0  0  0   1  0  6  1  0     0
SFBcastBegin          46 1.0 2.0034e-03 2.2 0.00e+00 0.0 5.5e+04 7.0e+02 0.0e+00  0  0  0  0  0   0  0 13  3  0     0
SFBcastEnd            46 1.0 8.9741e-03 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
GAMG: createProl       6 1.0 2.2056e+00 1.0 0.00e+00 0.0 2.0e+05 5.3e+03 2.9e+02  0  0  0  0  0  74  0 47 73 51     0
GAMG: partLevel        6 1.0 4.1617e-01 1.0 1.13e+07 1.3 6.6e+04 2.6e+03 1.9e+02  0  0  0  0  0  14 23 16 12 34  3059
  repartition          2 1.0 1.3080e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  0   0  0  0  0  2     0
  Invert-Sort          2 1.0 1.3320e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  0   0  0  0  0  1     0
  Move A               2 1.0 2.3206e-02 1.0 0.00e+00 0.0 1.4e+03 5.4e+02 3.4e+01  0  0  0  0  0   1  0  0  0  6     0
  Move P               2 1.0 7.7642e-02 1.0 0.00e+00 0.0 1.4e+03 1.3e+01 3.4e+01  0  0  0  0  0   3  0  0  0  6     0
PCSetUp                2 1.0 2.6313e+00 1.0 1.13e+07 1.3 2.7e+05 4.6e+03 5.1e+02  0  0  0  0  0  89 23 63 85 91   484
PCSetUpOnBlocks        7 1.0 4.0460e-04 1.9 3.14e+02 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     1
PCApply                7 1.0 2.2264e-01 1.1 3.18e+07 1.2 1.5e+05 1.2e+03 1.4e+01  0  0  0  0  0   7 66 35 13  2 16770
KSPSolve           10000 1.0 2.2427e+03 1.0 3.69e+11 1.2 1.5e+09 1.4e+03 3.7e+05100100100100100 100100100100100 19490
VecTDot           140000 1.0 1.8447e+02 6.4 7.56e+09 1.0 0.0e+00 0.0e+00 1.4e+05  3  2  0  0 38   3  2  0  0 38  5123
VecNormBarrier     90000 1.0 1.9840e+01 5.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNorm            90000 1.0 8.2702e+00 1.2 4.86e+09 1.0 0.0e+00 0.0e+00 9.0e+04  0  1  0  0 24   0  1  0  0 24 73456
VecScale          420000 1.0 2.1495e+00 2.2 9.47e+08 2.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 42496
VecCopy            10000 1.0 1.2405e+00 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet           1470000 1.0 1.3027e+01 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY           140000 1.0 1.8036e+01 1.8 7.56e+09 1.0 0.0e+00 0.0e+00 0.0e+00  1  2  0  0  0   1  2  0  0  0 52397
VecAYPX           490000 1.0 2.4474e+01 2.2 6.46e+09 1.0 0.0e+00 0.0e+00 0.0e+00  1  2  0  0  0   1  2  0  0  0 32596
VecScatterBarrie 1760000 1.0 7.9999e+02 6.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 15  0  0  0  0  15  0  0  0  0     0
VecScatterBegin  1760000 1.0 1.1154e+02 3.9 0.00e+00 0.0 1.5e+09 1.4e+03 0.0e+00  3  0100100  0   3  0100100  0     0
VecScatterEnd    1760000 1.0 3.2220e+02 4.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  8  0  0  0  0   8  0  0  0  0     0
MatMult           500000 1.0 7.7645e+02 1.6 1.05e+11 1.1 5.1e+08 2.1e+03 0.0e+00 24 28 33 49  0  24 29 33 49  0 16044
MatMultAdd        420000 1.0 3.0354e+02 1.8 2.40e+10 1.3 2.8e+08 6.7e+02 0.0e+00 10  6 18  9  0  10  6 18  9  0  9077
MatMultTranspose  420000 1.0 2.5492e+02 1.7 2.40e+10 1.3 2.8e+08 6.7e+02 0.0e+00  8  6 18  9  0   8  6 18  9  0 10807
MatSolve           70000 0.0 2.8931e-01 0.0 8.40e+06 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    29
MatSOR            840000 1.0 1.2249e+03 1.7 1.90e+11 1.2 4.7e+08 1.6e+03 1.4e+05 49 51 30 33 38  49 51 30 33 38 18326
MatResidual       420000 1.0 6.4252e+02 1.8 7.97e+10 1.2 4.7e+08 1.6e+03 0.0e+00 19 21 30 33  0  19 21 30 33  0 14518
PCSetUpOnBlocks    70000 1.0 9.7365e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCApply            70000 1.0 2.0260e+03 1.1 3.18e+11 1.2 1.5e+09 1.2e+03 1.4e+05 89 85 97 84 38  89 85 97 84 38 18404
       Krylov Solver     1              9        11424     0.
     DMKSP interface     1              1          656     0.
              Vector     4             52      2371888     0.
              Matrix     0             72     14160468     0.
    Distributed Mesh     1              1         5248     0.
           Index Set     2             12       133928     0.
   IS L to G Mapping     1              1       131728     0.
   Star Forest Graph     2              2         1728     0.
     Discrete System     1              1          932     0.
         Vec Scatter     1             14       233696     0.
      Preconditioner     1              9         9676     0.
              Viewer     1              0            0     0.
       Krylov Solver     8              0            0     0.
              Vector   158            110      3181312     0.
              Matrix   140             68     21757144     0.
      Matrix Coarsen     6              6         3816     0.
           Index Set   110            100       543716     0.
   Star Forest Graph    12             12        10368     0.
         Vec Scatter    31             18        22752     0.
      Preconditioner     8              0            0     0.
              Vector 420000          420000  22766800000     0.
Average time to get PetscTime(): 9.53674e-08
Average time for MPI_Barrier(): 1.80244e-05
Average time for zero size MPI_Send(): 1.40877e-05
#PETSc Option Table entries:
-iterations 10000
-ksp_rtol 1E-6
-ksp_type cg
-log_sync
-log_view
-mesh_size 1E-4
-nodes_per_proc 30
-pc_type gamg
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --known-level1-dcache-size=65536 --known-level1-dcache-linesize=64 --known-level1-dcache-assoc=2 --known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8 --known-bits-per-byte=8 --known-memcmp-ok=1 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-int64_t=1 --known-mpi-c-double-complex=1 --known-has-attribute-aligned=1 PETSC_ARCH=arch-linux-amd-opt --download-f2cblaslapack --with-mpi-dir=/cm/shared/apps/mvapich2/intel-17.0.1/2.0 --download-hypre --download-ml --with-fc=0 --with-debugging=0 COPTFLAGS=-O3 CXXOPTFLAGS=-O3 --with-batch --with-x --known-mpi-shared-libraries=1 --known-64-bit-blas-indices=4
Libraries compiled on 2018-05-25 07:05:14 on node1-001
Machine characteristics: Linux-2.6.32-696.18.7.el6.x86_64-x86_64-with-redhat-6.6-Carbon
Using PETSc directory: /home/ritsat/beckerm/petsc
Using PETSc arch: arch-linux-amd-opt
Using C compiler: /cm/shared/apps/mvapich2/intel-17.0.1/2.0/bin/mpicc  -fPIC  -wd1572 -O3
Using include paths: -I/home/ritsat/beckerm/petsc/include -I/home/ritsat/beckerm/petsc/arch-linux-amd-opt/include -I/cm/shared/apps/mvapich2/intel-17.0.1/2.0/include
Using C linker: /cm/shared/apps/mvapich2/intel-17.0.1/2.0/bin/mpicc
Using libraries: -Wl,-rpath,/home/ritsat/beckerm/petsc/arch-linux-amd-opt/lib -L/home/ritsat/beckerm/petsc/arch-linux-amd-opt/lib -lpetsc -Wl,-rpath,/home/ritsat/beckerm/petsc/arch-linux-amd-opt/lib -L/home/ritsat/beckerm/petsc/arch-linux-amd-opt/lib -lHYPRE -lml -lf2clapack -lf2cblas -lX11 -ldl
/home/ritsat/beckerm/ppp_test/plasmapic on a arch-linux-amd-opt named node4-083 with 125 processors, by beckerm Wed May 30 16:24:18 2018
Time (sec):           2.497e+02      1.00000   2.497e+02
Objects:              2.438e+04      1.00004   2.438e+04
Flop:                 2.125e+10      1.27708   1.963e+10  2.454e+12
Flop/sec:            8.510e+07      1.27708   7.862e+07  9.828e+09
MPI Messages:         1.042e+06      3.36140   7.129e+05  8.911e+07
MPI Message Lengths:  1.344e+09      2.32209   1.439e+03  1.282e+11
MPI Reductions:       2.250e+04      1.00000
 0:      Main Stage: 6.4457e+00   2.6%  0.0000e+00   0.0%  3.000e+03   0.0%  3.178e+03        0.0%  1.700e+01   0.1%
 1:     First Solve: 2.4843e+00   1.0%  3.6885e+09   0.2%  3.549e+05   0.4%  3.736e+03        1.0%  5.500e+02   2.4%
 2: Remaining Solves: 2.4077e+02  96.4%  2.4504e+12  99.8%  8.875e+07  99.6%  1.430e+03       99.0%  2.192e+04  97.4%
Phase summary info:
VecSet                 3 1.0 4.7421e-04 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided         12 1.0 6.9022e-03 1.9 0.00e+00 0.0 8.8e+03 4.0e+00 0.0e+00  0  0  0  0  0   0  0  2  0  0     0
BuildTwoSidedF        30 1.0 2.8585e-01 3.6 0.00e+00 0.0 7.1e+03 1.0e+04 0.0e+00  0  0  0  0  0   6  0  2  5  0     0
KSPSetUp               9 1.0 3.2625e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.8e+01  0  0  0  0  0   0  0  0  0  3     0
KSPSolve               1 1.0 2.4871e+00 1.0 3.26e+07 1.4 3.5e+05 3.7e+03 5.5e+02  1  0  0  1  2 100100100100100  1483
VecTDot                8 1.0 6.3627e-03 3.7 4.32e+05 1.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  0   0  1  0  0  1  8487
VecNorm                6 1.0 1.3714e-03 2.8 3.24e+05 1.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  0   0  1  0  0  1 29532
VecScale              24 1.0 1.4067e-04 2.4 5.43e+04 2.4 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 36596
VecCopy                1 1.0 1.1802e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               115 1.0 7.8726e-04 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                8 1.0 1.1842e-03 1.4 4.32e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 45599
VecAYPX               28 1.0 1.3180e-03 1.6 3.58e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 33275
VecAssemblyBegin       2 1.0 2.1458e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin      103 1.0 6.1374e-03 2.8 0.00e+00 0.0 8.9e+04 1.4e+03 0.0e+00  0  0  0  0  0   0  0 25  9  0     0
VecScatterEnd        103 1.0 3.9134e-02 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatMult               29 1.0 3.4050e-02 1.4 6.14e+06 1.2 3.0e+04 2.1e+03 0.0e+00  0  0  0  0  0   1 19  8  5  0 21052
MatMultAdd            24 1.0 1.4260e-02 2.5 1.37e+06 1.6 1.6e+04 6.5e+02 0.0e+00  0  0  0  0  0   0  4  5  1  0 10595
MatMultTranspose      24 1.0 1.4215e-02 2.7 1.37e+06 1.6 1.6e+04 6.5e+02 0.0e+00  0  0  0  0  0   0  4  5  1  0 10629
MatSolve               4 0.0 1.9312e-05 0.0 2.64e+02 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    14
MatSOR                48 1.0 7.1831e-02 1.3 1.09e+07 1.3 2.7e+04 1.5e+03 8.0e+00  0  0  0  0  0   3 34  8  3  1 17455
MatLUFactorSym         1 1.0 5.3883e-05 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         1 1.0 1.4067e-05 7.4 1.29e+02 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     9
MatResidual           24 1.0 2.7424e-02 1.7 4.55e+06 1.3 2.7e+04 1.5e+03 0.0e+00  0  0  0  0  0   1 14  8  3  0 18926
MatAssemblyBegin      94 1.0 2.8823e-01 3.2 0.00e+00 0.0 7.1e+03 1.0e+04 0.0e+00  0  0  0  0  0   7  0  2  5  0     0
MatAssemblyEnd        94 1.0 8.1276e-02 1.1 0.00e+00 0.0 6.3e+04 2.1e+02 2.3e+02  0  0  0  0  1   3  0 18  1 42     0
MatGetRow        3102093 1.3 4.5239e-01 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  16  0  0  0  0     0
MatGetRowIJ            1 0.0 5.9605e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCreateSubMats       6 1.0 4.4482e-01 2.4 0.00e+00 0.0 5.5e+04 1.7e+04 1.2e+01  0  0  0  1  0  13  0 15 71  2     0
MatCreateSubMat        4 1.0 6.8214e-03 1.0 0.00e+00 0.0 2.9e+03 2.7e+02 6.4e+01  0  0  0  0  0   0  0  1  0 12     0
MatGetOrdering         1 0.0 1.1611e-04 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatIncreaseOvrlp       6 1.0 5.6694e-02 1.2 0.00e+00 0.0 2.7e+04 1.0e+03 1.2e+01  0  0  0  0  0   2  0  8  2  2     0
MatCoarsen             6 1.0 1.6149e-02 1.0 0.00e+00 0.0 5.3e+04 5.8e+02 3.3e+01  0  0  0  0  0   1  0 15  2  6     0
MatZeroEntries         6 1.0 3.4871e-03 4.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatPtAP                6 1.0 2.5855e-01 1.0 1.13e+07 1.6 6.3e+04 2.6e+03 9.2e+01  0  0  0  0  0  10 33 18 13 17  4731
MatPtAPSymbolic        6 1.0 1.4759e-01 1.0 0.00e+00 0.0 3.4e+04 2.7e+03 4.2e+01  0  0  0  0  0   6  0 10  7  8     0
MatPtAPNumeric         6 1.0 1.1022e-01 1.0 1.13e+07 1.6 2.9e+04 2.6e+03 4.8e+01  0  0  0  0  0   4 33  8  6  9 11099
MatGetLocalMat         6 1.0 4.5311e-03 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          6 1.0 8.2998e-03 1.7 0.00e+00 0.0 2.0e+04 3.5e+03 0.0e+00  0  0  0  0  0   0  0  6  5  0     0
SFSetGraph            12 1.0 1.3113e-05 3.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetUp               12 1.0 1.2064e-02 1.1 0.00e+00 0.0 2.6e+04 6.2e+02 0.0e+00  0  0  0  0  0   0  0  7  1  0     0
SFBcastBegin          45 1.0 2.0254e-03 2.3 0.00e+00 0.0 5.4e+04 6.9e+02 0.0e+00  0  0  0  0  0   0  0 15  3  0     0
SFBcastEnd            45 1.0 5.0657e-03 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
GAMG: createProl       6 1.0 2.0193e+00 1.0 0.00e+00 0.0 2.0e+05 5.2e+03 2.8e+02  1  0  0  1  1  81  0 56 78 52     0
GAMG: partLevel        6 1.0 2.6818e-01 1.0 1.13e+07 1.6 6.6e+04 2.5e+03 1.9e+02  0  0  0  0  1  11 33 19 13 35  4562
  repartition          2 1.0 6.9189e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  0   0  0  0  0  2     0
  Invert-Sort          2 1.0 6.0797e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  0   0  0  0  0  1     0
  Move A               2 1.0 4.2229e-03 1.1 0.00e+00 0.0 1.4e+03 5.3e+02 3.4e+01  0  0  0  0  0   0  0  0  0  6     0
  Move P               2 1.0 3.6728e-03 1.1 0.00e+00 0.0 1.4e+03 1.3e+01 3.4e+01  0  0  0  0  0   0  0  0  0  6     0
PCSetUp                2 1.0 2.2978e+00 1.0 1.13e+07 1.6 2.7e+05 4.5e+03 5.1e+02  1  0  0  1  2  92 33 75 90 93   532
PCSetUpOnBlocks        4 1.0 2.5201e-04 1.4 1.29e+02 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     1
PCApply                4 1.0 1.1062e-01 1.0 1.82e+07 1.3 8.6e+04 1.2e+03 8.0e+00  0  0  0  0  0   4 56 24  8  1 18759
KSPSolve             999 1.0 1.2099e+02 1.0 2.12e+10 1.3 8.8e+07 1.4e+03 2.2e+04 47100 99 97 97  49100 99 98100 20253
VecTDot             7968 1.0 6.5506e+00 4.0 4.30e+08 1.0 0.0e+00 0.0e+00 8.0e+03  1  2  0  0 35   1  2  0  0 36  8210
VecNorm             5982 1.0 5.8032e+0010.2 3.23e+08 1.0 0.0e+00 0.0e+00 6.0e+03  1  2  0  0 27   1  2  0  0 27  6958
VecScale           23904 1.0 1.1292e-01 2.2 5.40e+07 2.4 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 45407
VecCopy              999 1.0 1.1493e-01 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet             83664 1.0 6.9683e-01 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY             7968 1.0 1.1667e+00 1.4 4.30e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0 46100
VecAYPX            27888 1.0 1.2901e+00 1.6 3.56e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0 33851
VecScatterBegin   100599 1.0 5.9735e+00 2.8 0.00e+00 0.0 8.8e+07 1.4e+03 0.0e+00  2  0 99 97  0   2  0 99 98  0     0
VecScatterEnd     100599 1.0 3.5510e+01 4.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  7  0  0  0  0   8  0  0  0  0     0
MatMult            28887 1.0 3.4026e+01 1.5 6.12e+09 1.2 3.0e+07 2.1e+03 0.0e+00 11 29 33 49  0  11 29 33 49  0 20986
MatMultAdd         23904 1.0 1.1303e+01 2.1 1.37e+09 1.6 1.6e+07 6.5e+02 0.0e+00  3  6 18  8  0   3  6 18  8  0 13314
MatMultTranspose   23904 1.0 1.3880e+01 2.6 1.37e+09 1.6 1.6e+07 6.5e+02 0.0e+00  4  6 18  8  0   4  6 18  8  0 10842
MatSolve            3984 0.0 1.6525e-02 0.0 2.63e+05 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    16
MatSOR             47808 1.0 6.6732e+01 1.3 1.08e+10 1.3 2.7e+07 1.5e+03 8.0e+03 25 51 30 32 35  26 51 30 32 36 18638
MatResidual        23904 1.0 2.6673e+01 1.7 4.54e+09 1.3 2.7e+07 1.5e+03 0.0e+00  8 21 30 32  0   8 21 30 32  0 19381
PCSetUpOnBlocks     3984 1.0 5.2946e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCApply             3984 1.0 1.0349e+02 1.0 1.81e+10 1.3 8.5e+07 1.2e+03 8.0e+03 41 84 96 80 35  42 84 96 81 36 19921
     DMKSP interface     1              0            0     0.
              Vector     5             52      2371496     0.
              Matrix     0             72     14138216     0.
    Distributed Mesh     1              0            0     0.
           Index Set     2             12       133768     0.
   IS L to G Mapping     1              0            0     0.
   Star Forest Graph     2              0            0     0.
     Discrete System     1              0            0     0.
         Vec Scatter     1             13        16432     0.
              Viewer     1              0            0     0.
              Vector   140             92      2204792     0.
              Matrix   140             68     21738552     0.
           Index Set   110            100       543240     0.
Average time for MPI_Barrier(): 1.81675e-05
Average time for zero size MPI_Send(): 1.45779e-05
-ksp_type cg
-log_view
-pc_type gamg
/home/ritsat/beckerm/ppp_test/plasmapic on a arch-linux-amd-opt named node1-013 with 1000 processors, by beckerm Wed May 30 19:06:34 2018
Time (sec):           2.892e+02      1.00001   2.892e+02
Objects:              2.440e+04      1.00004   2.440e+04
Flop:                 2.124e+10      1.27708   2.041e+10  2.041e+13
Flop/sec:            7.342e+07      1.27708   7.057e+07  7.057e+10
MPI Messages:         1.238e+06      3.99536   8.489e+05  8.489e+08
MPI Message Lengths:  1.343e+09      2.32238   1.393e+03  1.183e+12
MPI Reductions:       2.256e+04      1.00000
 0:      Main Stage: 2.7802e+01   9.6%  0.0000e+00   0.0%  2.700e+04   0.0%  3.178e+03        0.0%  1.700e+01   0.1%
 1:     First Solve: 3.3072e+00   1.1%  3.0885e+10   0.2%  3.675e+06   0.4%  3.508e+03        1.1%  6.220e+02   2.8%
 2: Remaining Solves: 2.5814e+02  89.2%  2.0380e+13  99.8%  8.452e+08  99.6%  1.384e+03       98.9%  2.191e+04  97.1%
Phase summary info:
VecSet                 3 1.0 5.7411e-04 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided         12 1.0 1.3082e-02 1.5 0.00e+00 0.0 8.9e+04 4.0e+00 0.0e+00  0  0  0  0  0   0  0  2  0  0     0
BuildTwoSidedF        30 1.0 4.3104e-01 2.7 0.00e+00 0.0 6.5e+04 1.0e+04 0.0e+00  0  0  0  0  0   8  0  2  5  0     0
KSPSetUp               9 1.0 5.3465e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 1.8e+01  0  0  0  0  0   0  0  0  0  3     0
KSPSolve               1 1.0 3.3113e+00 1.0 3.25e+07 1.4 3.7e+06 3.5e+03 6.2e+02  1  0  0  1  3 100100100100100  9327
VecTDot                8 1.0 6.8474e-03 4.2 4.32e+05 1.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  0   0  1  0  0  1 63089
VecNorm                6 1.0 1.6654e-03 2.8 3.24e+05 1.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  0   0  1  0  0  1 194553
VecScale              24 1.0 1.3828e-04 2.4 5.43e+04 2.4 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 344362
VecCopy                1 1.0 1.4305e-04 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               124 1.0 8.4376e-04 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                8 1.0 1.2994e-03 1.6 4.32e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 332466
VecAYPX               28 1.0 1.5504e-03 2.0 3.58e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 228452
VecAssemblyBegin       3 1.0 3.0994e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd         3 1.0 3.0994e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin      108 1.0 6.7146e-03 2.8 0.00e+00 0.0 8.4e+05 1.4e+03 0.0e+00  0  0  0  0  0   0  0 23  9  0     0
VecScatterEnd        108 1.0 4.8888e-02 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatMult               29 1.0 3.6063e-02 1.5 6.14e+06 1.2 2.8e+05 2.0e+03 0.0e+00  0  0  0  0  0   1 19  8  4  0 164544
MatMultAdd            24 1.0 2.2712e-02 3.2 1.37e+06 1.6 1.5e+05 6.5e+02 0.0e+00  0  0  0  0  0   1  4  4  1  0 56747
MatMultTranspose      24 1.0 1.4198e-02 2.3 1.37e+06 1.6 1.5e+05 6.5e+02 0.0e+00  0  0  0  0  0   0  4  4  1  0 90779
MatSolve               4 0.0 4.7922e-05 0.0 1.10e+04 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   229
MatSOR                48 1.0 7.6652e-02 1.3 1.09e+07 1.3 2.6e+05 1.5e+03 8.0e+00  0  0  0  0  0   2 34  7  3  1 136439
MatLUFactorSym         1 1.0 9.4891e-05 3.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         1 1.0 6.6042e-0534.6 3.29e+04 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   498
MatResidual           24 1.0 2.7970e-02 1.7 4.55e+06 1.3 2.6e+05 1.5e+03 0.0e+00  0  0  0  0  0   1 14  7  3  0 155507
MatAssemblyBegin     102 1.0 4.3351e-01 2.5 0.00e+00 0.0 6.5e+04 1.0e+04 0.0e+00  0  0  0  0  0   8  0  2  5  0     0
MatAssemblyEnd       102 1.0 1.1318e-01 1.1 0.00e+00 0.0 6.2e+05 2.0e+02 2.5e+02  0  0  0  0  1   3  0 17  1 40     0
MatGetRow        3102093 1.3 5.0438e-01 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  12  0  0  0  0     0
MatGetRowIJ            1 0.0 1.5974e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCreateSubMats       6 1.0 4.6014e-01 2.3 0.00e+00 0.0 5.7e+05 1.6e+04 1.2e+01  0  0  0  1  0  10  0 15 72  2     0
MatCreateSubMat        6 1.0 1.9575e-02 1.0 0.00e+00 0.0 2.2e+04 3.3e+02 9.4e+01  0  0  0  0  0   1  0  1  0 15     0
MatGetOrdering         1 0.0 1.4710e-04 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatIncreaseOvrlp       6 1.0 1.1349e-01 1.1 0.00e+00 0.0 2.6e+05 9.9e+02 1.2e+01  0  0  0  0  0   3  0  7  2  2     0
MatCoarsen             6 1.0 3.4475e-02 1.1 0.00e+00 0.0 7.1e+05 4.4e+02 5.6e+01  0  0  0  0  0   1  0 19  2  9     0
MatZeroEntries         6 1.0 3.4661e-03 4.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatPtAP                6 1.0 3.8021e-01 1.1 1.11e+07 1.6 6.3e+05 2.5e+03 9.2e+01  0  0  0  0  0  11 34 17 12 15 27282
MatPtAPSymbolic        6 1.0 2.1572e-01 1.0 0.00e+00 0.0 3.2e+05 2.7e+03 4.2e+01  0  0  0  0  0   7  0  9  7  7     0
MatPtAPNumeric         6 1.0 1.4471e-01 1.0 1.11e+07 1.6 3.0e+05 2.3e+03 4.8e+01  0  0  0  0  0   4 34  8  6  8 71679
MatGetLocalMat         6 1.0 4.7863e-03 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          6 1.0 1.9191e-02 3.1 0.00e+00 0.0 1.9e+05 3.4e+03 0.0e+00  0  0  0  0  0   0  0  5  5  0     0
SFSetGraph            12 1.0 2.3127e-05 6.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetUp               12 1.0 1.9232e-02 1.1 0.00e+00 0.0 2.7e+05 5.8e+02 0.0e+00  0  0  0  0  0   1  0  7  1  0     0
SFBcastBegin          68 1.0 2.7168e-03 2.7 0.00e+00 0.0 7.2e+05 5.1e+02 0.0e+00  0  0  0  0  0   0  0 20  3  0     0
SFBcastEnd            68 1.0 1.5905e-02 3.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
GAMG: createProl       6 1.0 2.4556e+00 1.0 0.00e+00 0.0 2.2e+06 4.7e+03 3.1e+02  1  0  0  1  1  74  0 59 79 50     0
GAMG: partLevel        6 1.0 4.0791e-01 1.1 1.11e+07 1.6 6.5e+05 2.4e+03 2.4e+02  0  0  0  0  1  12 34 18 12 39 25428
  repartition          3 1.0 2.3220e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.8e+01  0  0  0  0  0   0  0  0  0  3     0
  Invert-Sort          3 1.0 2.0869e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  0   0  0  0  0  2     0
  Move A               3 1.0 1.2217e-02 1.1 0.00e+00 0.0 9.5e+03 7.4e+02 5.0e+01  0  0  0  0  0   0  0  0  0  8     0
  Move P               3 1.0 9.7649e-03 1.1 0.00e+00 0.0 1.3e+04 1.3e+01 5.0e+01  0  0  0  0  0   0  0  0  0  8     0
PCSetUp                2 1.0 3.0642e+00 1.0 1.11e+07 1.6 2.8e+06 4.2e+03 5.8e+02  1  0  0  1  3  93 34 77 91 94  3385
PCSetUpOnBlocks        4 1.0 3.9506e-04 2.9 3.29e+04 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    83
PCApply                4 1.0 1.2272e-01 1.0 1.82e+07 1.3 8.2e+05 1.2e+03 8.0e+00  0  0  0  0  0   4 56 22  7  1 141671
KSPSolve             999 1.0 1.3648e+02 1.0 2.12e+10 1.3 8.4e+08 1.4e+03 2.2e+04 46100 99 97 97  51100 99 98100 149327
VecTDot             7964 1.0 7.1750e+00 3.4 4.30e+08 1.0 0.0e+00 0.0e+00 8.0e+03  1  2  0  0 35   1  2  0  0 36 59937
VecNorm             5980 1.0 6.0258e+00 4.9 3.23e+08 1.0 0.0e+00 0.0e+00 6.0e+03  1  2  0  0 27   1  2  0  0 27 53589
VecScale           23892 1.0 1.2695e-01 2.4 5.40e+07 2.4 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 373403
VecCopy              999 1.0 1.3586e-01 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet             83622 1.0 7.4253e-01 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY             7964 1.0 1.2791e+00 1.6 4.30e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0 336221
VecAYPX            27874 1.0 1.4993e+00 2.0 3.56e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0 235111
VecScatterBegin   100549 1.0 6.4721e+00 2.9 0.00e+00 0.0 8.4e+08 1.4e+03 0.0e+00  2  0 99 97  0   2  0 99 98  0     0
VecScatterEnd     100549 1.0 4.9949e+01 2.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  8  0  0  0  0   9  0  0  0  0     0
MatMult            28873 1.0 3.3321e+01 1.4 6.11e+09 1.2 2.8e+08 2.0e+03 0.0e+00  9 29 33 48  0  10 29 34 49  0 177317
MatMultAdd         23892 1.0 1.9948e+01 2.7 1.37e+09 1.6 1.5e+08 6.5e+02 0.0e+00  6  6 18  8  0   7  6 18  8  0 64321
MatMultTranspose   23892 1.0 1.3810e+01 2.1 1.37e+09 1.6 1.5e+08 6.5e+02 0.0e+00  3  6 18  8  0   3  6 18  8  0 92909
MatSolve            3982 0.0 4.4663e-02 0.0 1.09e+07 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   245
MatSOR             47784 1.0 7.1050e+01 1.3 1.08e+10 1.3 2.6e+08 1.5e+03 8.0e+03 23 51 30 32 35  26 51 30 32 36 145956
MatResidual        23892 1.0 2.4668e+01 1.5 4.53e+09 1.3 2.6e+08 1.5e+03 0.0e+00  7 21 30 32  0   7 21 30 32  0 175528
PCSetUpOnBlocks     3982 1.0 5.2893e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCApply             3982 1.0 1.1642e+02 1.0 1.81e+10 1.3 8.1e+08 1.2e+03 8.0e+03 40 85 96 81 35  45 85 96 82 36 148313
              Vector     5             52      2382208     0.
              Matrix     0             65     14780672     0.
           Index Set     2             18       171852     0.
              Viewer     1              0            0     0.
              Vector   152            104      2238504     0.
              Matrix   148             83     22951356     0.
           Index Set   128            112       590828     0.
         Vec Scatter    34             21        26544     0.
              Vector 23892          23892   1302241424     0.
Average time for MPI_Barrier(): 3.45707e-05
Average time for zero size MPI_Send(): 1.60329e-05
-ksp_type cg
-log_view
-pc_type gamg
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180604/34557441/attachment-0001.zip>
