[petsc-users] downloading hypre
Matthew Knepley
knepley at gmail.com
Mon Jun 4 03:04:30 CDT 2018
On Mon, Jun 4, 2018 at 3:50 AM, Lukas van de Wiel <
lukas.drinkt.thee at gmail.com> wrote:
> Hi Matt,
> Whoa, thanks for the invite, but that is a bit too short of a notice for
> the circumstances.
> I will gladly come to the next one. And if it is far away, I have good
> excuse to prepend a holiday to it. :-)
> WIll it be in the beginning of June in 2019 as well?
It usually is. We try to work around other conferences. Generally we get it
set 6 months in advance.
Matt
> Cheers
> Lukas
> On Fri, Jun 1, 2018 at 5:16 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Jun 1, 2018 at 11:11 AM, Lukas van de Wiel <
>>> Thanks Matt. That was fast! :-)
>>> The university server has:
>>> [17:04 gtecton at pbsserv petsc-3.8.1] > openssl version
>>> OpenSSL 0.9.8zh 3 Dec 2015
>>> And a friend with
>>> OpenSSL 1.0.2g 1 Mar 2016
>>> Can execute the git clone command without trouble.
>>> Cheers and have a great weekend!
>> Great! Also if you are bored next week, we are having the PETSc Meeting
>> in London.
>> Only a short train ride by Eurostar :)
>> Matt
>>> Lukas
>>> On Fri, Jun 1, 2018 at 5:08 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Fri, Jun 1, 2018 at 11:01 AM, Lukas van de Wiel <
>>>>> Hi all,
>>>>> for years I have been installing PETSc on machines, almost always
>>>>> without any issue to speak off. Compliments for the solid configure script.
>>>>> However, now I see an issue I cannot easily solve.
>>>>> When getting HYPRE in the configuration options, the output gives
>>>>> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log
>>>>> for details):
>>>>> Error during download/extract/detection of HYPRE:
>>>>> Unable to download hypre
>>>>> Could not execute "git clone https://github.com/LLNL/hypre
>>>>> /net/home/gtecton/flops/petsc-3.8.1/linux-gnu-x86_64/externa
>>>>> lpackages/git.hypre":
>>>>> Cloning into '/net/home/gtecton/flops/petsc
>>>>> -3.8.1/linux-gnu-x86_64/externalpackages/git.hypre'...
>>>>> fatal: unable to access 'https://github.com/LLNL/hypre/':
>>>>> error:1407742E:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert
>>>>> protocol version
>>>>> Unable to download package HYPRE from: git://https://github.com/LLNL/
>>>>> hypre
>>>>> Has anybody else seen this? It seems to get stuck on SSL, but web
>>>>> security is sadly not my forte...
>>>> I have definitely had issues similar to this. It came up with
>>>> Firedrake. I built my own Python, and had
>>>> an early version of libssh/libcrypto. I think you need at least 1.0.1
>>>> to get the SSL version that github
>>>> is now requiring. You can use ldd (or otool -L) to check the version
>>>> for your Python.
>>>> Thanks,
>>>> Matt
>>>>> Thanks a lot,
>>>>> Lukas
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180604/df345f1f/attachment-0001.html>
