[petsc-users] MatPtAP
Smith, Barry F.
bsmith at mcs.anl.gov
Fri Jun 1 12:35:33 CDT 2018
Could you save the P matrix with MatView() using a binary viewer and the A matrix with MatView() and the binary viewer and email them to petsc-maint at mcs.anl.gov ? Then we can run the code in the profiler with your matrices and see if there is any way to speed up the computation.
Barry
> On Jun 1, 2018, at 11:07 AM, Samuel Lanthaler <s.lanthaler at gmail.com> wrote:
> On 06/01/2018 03:42 PM, Matthew Knepley wrote:
>> On Fri, Jun 1, 2018 at 9:21 AM, Samuel Lanthaler <s.lanthaler at gmail.com> wrote:
>> Hi,
>> I was wondering what the most efficient way to use MatPtAP would be in the following situation: I am discretizing a PDE system. The discretization yields a matrix A that has a band structure (with k upper and lower bands, say). In order to implement the boundary conditions, I use a transformation matrix P which is essentially the unit matrix, except for the entries P_{ij} where i,j<k and n-i,n-j<k, so
>> P = [ B, 0, 0, 0, ..., 0, 0 ]
>> [ 0, 1, 0, 0, ..., 0, 0 ]
>> [ ..., 1, 0 ]
>> [ 0, 0, 0, 0, ..., 0, C ]
>> with B,C are (k-by-k) matrices.
>> Right now, I'm simply constructing A, P and calling
>> CALL MatPtAP(petsc_matA,petsc_matP,MAT_INITIAL_MATRIX,PETSC_DEFAULT_REAL,petsc_matPtAP,ierr)
>> where I haven't done anything to pestc_matPtAP, prior to this call. Is this the way to do it?
>> I'm asking because, currently, setting up the matrices A and P takes very little time, whereas the operation MatPtAP is taking quite long, which seems very odd... The matrices are of type MPIAIJ. In my problem, the total matrix dimension is around 10'000 and the matrix blocks (B,C) are of size ~100.
>> Are you sure this is what you want to do? Usually BC are local, since by definition PDE are local, and
>> are applied pointwise. What kind of BC do you have here?
> The boundary conditions are a mixture of Dirichlet and Neumann; in my case, the PDE is a system involving 8 variables on a disk, where the periodic direction is discretized using a Fourier series expansion, the radial direction uses B-splines.
> In reality, I have two matrices A,B, and want to solve the eigenvalue problem \lambda*B*x = A*x.
> I found it quite convenient to use a transformation P to a different set of variables y, such that x=P*y and x satisfies the BC iff certain components of y are 0. The latter is enforced by inserting spurious eigenvalues at the relevant components of y in the transformed eigenvalue problem \lambda*Pt*B*P*y=Pt*A*P*y. After solving the EVP in terms of y, I get back x=P*y.
> Is this an inherently bad/inefficient way of enforcing BC's? Thanks.
>> Thanks,
>> Matt
>> Thanks in advance for any ideas.
>> Cheers,
>> Samuel
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
