[petsc-users] problem with installation using quad precision
Santiago Andres Triana
repepo at gmail.com
Mon Jul 30 12:10:38 CDT 2018
Dear Karl, Jed:
It was indeed the --with-fortran-kernels=1 option the culprit. Without it
the make check steps succeeds :)
Thanks so much for your prompt help!
Santiago
On Mon, Jul 30, 2018 at 6:58 PM, Karl Rupp <rupp at iue.tuwien.ac.at> wrote:
> Hi Santiago,
> I am trying to install petsc with the option --with-precision=__float128.
>> The ./configure goes fine, as well as the make all stage. However, the make
>> check step to test the libraries fails with the following error:
>> /usr/bin/ld: home/spin/petsc-3.9.3/arch-linux2-c-opt/lib/libpetsc.so:
>> undefined reference to `dgemv_'
>> this is the configure command I use:
>> ./configure --with-scalar-type=complex --with-precision=__float128
>> --with-debugging=0 --with-fortran-kernels=1 COPTFLAGS='-O3 -march=native
>> -mtune=native' CXXOPTFLAGS='-O3 -march=native -mtune=native' FOPTFLAGS='-O3
>> -march=native -mtune=native' --download-f2cblaslapack
>> Any hints or suggestions are welcome. Thanks so much in advance!
> I just verified the following to work on my laptop:
> --download-f2cblaslapack --download-mpich
> As Jed pointed out, --with-fortran-kernels=1 is probably clashing with
> --download-f2cblaslapack. Does the build succeed without
> --with-fortran-kernels=1?
> Best regards,
> Karli
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180730/3b535fad/attachment.html>
