[petsc-users] Is there a way of having PETSc compile hypre with provided intel/mkl?
Bastian Löhrer bastian.loehrer at tu-dresden.de
Mon Jul 30 10:55:05 CDT 2018
On 30.07.2018 16:11, Satish Balay wrote:
> On Mon, 30 Jul 2018, Bastian Löhrer wrote:
>> On 30.07.2018 13:28, Matthew Knepley wrote:
>>> On Mon, Jul 30, 2018 at 5:48 AM Bastian Löhrer
>>> <bastian.loehrer at tu-dresden.de <mailto:bastian.loehrer at tu-dresden.de>>
>>> wrote:
>>>      Dear PETSc users,
>>>      im configuring PETSc to use an intel stack including intel/mkl:
>>>      ./configure PETSC_ARCH=$PETSC_ARCH \
>>>      --with-gnu-compilers=0 --with-vendor-compilers=intel \
>>>      --with-large-file-io=1 \
>>>      --CFLAGS="-L${I_MPI_ROOT}/intel64/lib
>>>      -I${I_MPI_ROOT}/intel64/include -lmpi"            \
>>>      --CXXFLAGS="-L${I_MPI_ROOT}/intel64/lib
>>>      -I${I_MPI_ROOT}/intel64/include -lmpi -lmpicxx" \
>>>      --FFLAGS="-L${I_MPI_ROOT}/intel64/lib
>>>      --LDFLAGS="-L${I_MPI_ROOT}/intel64/lib
>>>      --with-blas-lapack-dir="${MKLROOT}/lib/intel64" \
>>>      --download-hypre \
>>>      --with-debugging=yes
>>>      two questions:*
>>>      1)* the blas-lapack-dir option is not passed down to the
>>>      compilation of hypre according to $PETSC_DIR/$PETSC_ARCH/conf/hypre
>>>      *Is there a way of having PETSc compile hypre with my intel/mkl?*
>>> This should happen. Please send configure.log so we can see what went on.
>> My initial guess was that the file $PETSC_DIR/$PETSC_ARCH/conf/hypre lists the
>> parameters which are used for compiling hypre. As I said, this file does not
>> mention mkl anywhere.
>> I may be mistaken though, because having a second look I do realize that the
>> mkl library is mentioned in the configure log file in line 86661 ff. (where
>> hypre is being configured) and at the end of the log.
>> Here is my configure.log:
>> https://cloudstore.zih.tu-dresden.de/index.php/s/b6rT0WMAKEMsj8S/download
>> Here is that hypre file:
>> https://cloudstore.zih.tu-dresden.de/index.php/s/TSfXQ2pgDw5ALZm/download
> Working directory: /lustre/ssd/prime/libraries/petsc-3.3-p6_29
> This release is pretty old. Can you use the currently supported release - i.e 3.9?
> Satish
Yes, we are indeed currently updating our code to be compatible with
3.9, but we will need older versions of petsc too to be able to run old
versions of our code.
Bastian
