[petsc-users] Is there a way of having PETSc compile hypre with provided intel/mkl?
Bastian Löhrer
bastian.loehrer at tu-dresden.de
Mon Jul 30 04:48:19 CDT 2018
Dear PETSc users,
im configuring PETSc to use an intel stack including intel/mkl:
./configure PETSC_ARCH=$PETSC_ARCH \
--with-gnu-compilers=0
--with-vendor-compilers=intel \
--with-large-file-io=1 \
--CFLAGS="-L${I_MPI_ROOT}/intel64/lib -I${I_MPI_ROOT}/intel64/include
-lmpi" \
--CXXFLAGS="-L${I_MPI_ROOT}/intel64/lib -I${I_MPI_ROOT}/intel64/include
-lmpi -lmpicxx" \
--FFLAGS="-L${I_MPI_ROOT}/intel64/lib -I${I_MPI_ROOT}/intel64/include
-lmpi" \
--LDFLAGS="-L${I_MPI_ROOT}/intel64/lib -I${I_MPI_ROOT}/intel64/include
-lmpi" \
--with-blas-lapack-dir="${MKLROOT}/lib/intel64" \
--download-hypre \
--with-debugging=yes
two questions:*
1)* the blas-lapack-dir option is not passed down to the compilation of
hypre according to $PETSC_DIR/$PETSC_ARCH/conf/hypre
*Is there a way of having PETSc compile hypre with my intel/mkl?*
2)* *Should I omit or include any option?* I have come across a few
options in previous configuration calls used at my department which I
have removed from my configuration call because
a) I had the impression that they were of no additional use:
* --with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort --with-mpi=1
* --with-pic, because --with-pic=1 is the default anyway since
2.3.1, is it not?
(https://www.mcs.anl.gov/petsc/documentation/changes/231.html)
* --with-mpiexec=mpirun
* --with-mpi-compilers=1
* --known-mpi-shared=1
* --with-mpi-dir=...
* COPTFLAGS="-g" CXXOPTFLAGS="-g" FOPTFLAGS="-g" because
--with-debugging=yes adds them anyway
b) because I couldn't figure out what they were actually for:
* --configModules=PETSc.Configure
* --optionsModule=PETSc.compilerOptions
c) others:
* --known-64-bit-blas-indices I guess it wouldn't hurt anyway so I
guess I'll include this option the next time I configure petsc
(http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscBLASInt.html)
Looking forward to your advice
Kind regards,
Bastian
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180730/eb7c85a4/attachment.html>
