[petsc-users] find eigenvalues in serial for small matrix
Matthew Knepley
knepley at gmail.com
Mon Jul 23 20:32:46 CDT 2018
On Mon, Jul 23, 2018 at 9:28 PM Oleksandr Koshkarov <olk548 at mail.usask.ca>
wrote:
> Dear All,
> In my large parallel simulation, I need to precompute eigenvalues (or at
> least the largest one) of smallish simple matrix (from 4x4 up to maybe
> 50x50, tridiagonal and symmetric). Computation time here is not
> important and I thought to do it for each processor independently in
> serial. I thought to use petsc for this as I already use petsc for
> everything else. However, simple solution seems not to work:
> Mat M;
> MatCreateSeqDense(PETSC_COMM_SELF,n,n,NULL,&M);
> ... insering some values
> MatAssemblyBegin(M,MAT_FINAL_ASSEMBLY);
> MatAssemblyEnd(M,MAT_FINAL_ASSEMBLY);
> KSP ksp;
> KSPCreate(PETSC_COMM_WORLD,&ksp);
> KSPSetOperators(ksp,M,M);
> PetscReal r[n], c[n];
> KSPComputeEigenvaluesExplicitly(ksp,n,r,c);
> which produces the error:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Null argument, when expecting valid pointer
> [0]PETSC ERROR: Null Object: Parameter # 1
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.9.2, May, 20, 2018
> [0]PETSC ERROR: ./eigtest on a arch-linux2-c-debug named koshlaptop by
> kosh Mon Jul 23 19:25:29 2018
> [0]PETSC ERROR: Configure options --with-hdf5-dir=/home/kosh/.local/hdf5
> [0]PETSC ERROR: #1 VecDuplicate() line 372 in
> /home/kosh/.local/petsc-3.9.2/src/vec/vec/interface/vector.c
> [0]PETSC ERROR: #2 KSPComputeExplicitOperator() line 47 in
> /home/kosh/.local/petsc-3.9.2/src/ksp/ksp/interface/eige.c
> [0]PETSC ERROR: #3 KSPComputeEigenvaluesExplicitly() line 140 in
> Is it possible to use petsc for this simple task? or KSP will not work
> with dense serial matrix?
What that does is compute the eigenvalues of the Krylov matrix. If you want
the eigenvalues of an explicit dense matrix, just call the LAPACK function
directly (dgeev).
Matt
> Thank you in advance and best regards,
> Alex.
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180723/3876a513/attachment.html>
