[petsc-users] Modifying the computed TS step, TSSetPostStep vs TSSetPostEvaluate
Stefano Zampini stefano.zampini at gmail.com
Sun Jul 22 09:21:13 CDT 2018
> On Jul 22, 2018, at 11:47 AM, Mark Lohry <mlohry at gmail.com> wrote:
> Thanks Stefano.
> If the filter is part got your residual evaluation (your R), then you should do it inside  your RHS function itself.
> I've tried this and it works okay for explicit, but with implicit it seems to totally tank the krylov convergence.
What do you mean by “tank”? more iterations? larger time to solution?
Also, which kind of filter is this? Probably you are changing the sparsity of the Jacobian.
> Instead, if the filter applies to y(t+dt), you should do it in PostEvaluate. Note that PostStep is equivalent to PostEvaluate if you don’t have TSEvents set.
> And it's okay to call a TSSetSolution here without any side effects?
There’s no need to call TSSetSolution inside the PostEvaluate routine. Just call TSGetSolution(ts,&U) and apply your filter on U. You are allowed to change U inside the post evaluate routine.
> The filter is only applied to the time step direction, not y(t+dt) itself (i.e. if R=0 then y(t+dt) should equal y(t) without any filter effects), so I assume I'll have to store the previous time step and manually do the arithmetic here.
> On Sun, Jul 22, 2018 at 10:06 AM, Stefano Zampini <stefano.zampini at gmail.com <mailto:stefano.zampini at gmail.com>> wrote:
> > On Jul 22, 2018, at 11:13 AM, Mark Lohry <mlohry at gmail.com <mailto:mlohry at gmail.com>> wrote:
> > For the time iteration
> > y(t+dt) = y(t) + dt * R(y,t,...)
> > I need to apply a spectral filter to R prior to moving to the next step, e.g. so not use exactly the step computed by TS.
> > Where is the appropriate place to do this? SNES provides SNESLineSearchSetPostCheck where you can modify the newton step; is there a TS equivalent?
> > Or do I need to internally maintain a copy of y(t) to re-compute R and then call TSSetSolution with a modified vector?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180722/f9dcc946/attachment.html>
