[petsc-users] Using both DMDA and matrix-free methods with KSP
    Joseph Essman
    jte1 at rice.edu
    Thu Jul 19 17:58:13 CDT 2018
Hello all,
I'm a relatively new PETSc user and am currently attempting to apply
matrix-free methods to a program I wrote that uses the KSP and DMDA
libraries.
However, I've come across an issue. When I use KSPSetDM, it requires that I
set operators with KSPSetComputeOperators rather than simply setting an
operator. However, the primary issue here is that when I use
KSPSetComputeOperators, I attempt to compute my operators with the
following function:
PetscErrorCode ComputeMatrix(KSP ksp, Mat A, Mat jac, void *user){
  PetscErrorCode ierr;
  AppCtx         *ctx = (AppCtx*)user;
  PetscFunctionBegin;
  ierr = MatSetType(A, MATSHELL);CHKERRQ(ierr);
  ierr =
MatCreateShell(PETSC_COMM_WORLD,ctx->high-ctx->low,ctx->high-ctx->low,\
    PETSC_DETERMINE, PETSC_DETERMINE, (void*)ctx, &A);CHKERRQ(ierr);
  ierr = MatShellSetOperation(A,MATOP_MULT,(void(*)(void))MyMatMult);
    CHKERRQ(ierr);
  ierr = MatSetUp(A);CHKERRQ(ierr);
  ierr = MatSetType(jac, MATSHELL);CHKERRQ(ierr);
  ierr =
    PETSC_DETERMINE, PETSC_DETERMINE, (void*)ctx, &jac);CHKERRQ(ierr);
  ierr = MatShellSetOperation(jac,MATOP_MULT,(void(*)(void))MyMatMult);
    CHKERRQ(ierr);
  ierr = MatSetUp(jac);CHKERRQ(ierr);
  PetscFunctionReturn(ierr);
When I try to run KSPSolve, I get the following error message:
joseph at Otto ~/petsc-3.9.3/Diffusion $ mpirun -n 1 ./diffu2matfree -x 3 -y 3
shell
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Object is in wrong state
[0]PETSC ERROR: Must call MatXXXSetPreallocation() or MatSetUp() on
argument 1 "mat" before MatMult()
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.9.3, Jul, 02, 2018
[0]PETSC ERROR: ./diffu2matfree on a arch-linux2-c-debug named Otto by
joseph Thu Jul 19 17:53:00 2018
[0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
--with-fc=gfortran --download-mpich --download-fblaslapack
[0]PETSC ERROR: #1 MatMult() line 2306 in
/home/joseph/petsc-3.9.3/src/mat/interface/matrix.c
[0]PETSC ERROR: #2 PCApplyBAorAB() line 682 in
/home/joseph/petsc-3.9.3/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #3 KSP_PCApplyBAorAB() line 304 in
/home/joseph/petsc-3.9.3/include/petsc/private/kspimpl.h
[0]PETSC ERROR: #4 KSPGMRESCycle() line 152 in
/home/joseph/petsc-3.9.3/src/ksp/ksp/impls/gmres/gmres.c
[0]PETSC ERROR: #5 KSPSolve_GMRES() line 234 in
[0]PETSC ERROR: #6 KSPSolve() line 669 in
/home/joseph/petsc-3.9.3/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #7 main() line 110 in
/home/joseph/petsc-3.9.3/Diffusion/diffu2matfree.cpp
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -x 3
[0]PETSC ERROR: -y 3
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 73) - process 0
Does anybody know what's going on here? I've also tried to make the
algorithm work without KSPSetDM and KSPSetComputeOperators, but my MatMult
step is dependent on DMDA, which is no longer used for the vectors in the
KSP if I don't use KSPSetDM. I've attached my code in full if there are any
questions as to the structure of my code.
Joseph Essman
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180719/1ce18ca7/attachment-0001.html>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180719/1ce18ca7/attachment-0001.bin>
