[petsc-users] DMLabelFilter start index 0 question
Emiel van de Ven emiel.van.de.ven at gmail.com
Thu Jul 19 05:17:54 CDT 2018
Dear PETSc users,
I have a mesh where I have a label that contains some elements. If I
understand correctly, after uniform refinement, the label also contains the
refined faces and vertices. Since I'd like to have only cells in the label,
I thought to remove the rest using something like:
DMPlexGetDepthStratum(dm, 3, &vStart, &vEnd);
DMLabelFilter(label, vStart, vEnd);
However, I don't fully understand the functioning of DMLabelFilter. When
vStart>0, it works as I would expect, but when vStart=0, it simply removes
all the points from the label. Why is this happening?
Since for the cells vStart usually is 0, I can't use this method. Am I
missing something?
Attached is a minimal working example.
Best,
Emiel
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180719/cc156416/attachment.html>
Type: application/gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180719/cc156416/attachment.bin>
