[petsc-users] Changing the jacobian matrix during SNES iterations
Wed Jul 18 14:34:52 CDT 2018
On Wed, Jul 18, 2018 at 3:25 PM David Knezevic <david.knezevic at akselos.com>
wrote:
> On Wed, Jul 18, 2018 at 1:59 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Wed, Jul 18, 2018 at 1:31 PM David Knezevic <
>> david.knezevic at akselos.com> wrote:
>>> I'm using SNES for a finite element contact solve, in which the sparsity
>>> pattern of the jacobian can change from one Newton iteration to the next
>>> (since the nodes on the contact surface move).
>>> In order to handle this I figured the best way would be to destroy the
>>> jacobian matrix and re-allocate it with a new sparsity pattern inside each
>>> call to FormJacobian, does that seem like a reasonable approach in this
>>> context?
>> Yes.
>>> Also, I recall from an earlier discussion that this matrix re-allocation
>>> inside FormJacobian is supported by SNES, but I just wanted to confirm that?
>> Yes.
>>> Also, I was wondering if there is any example where the matrix is
>>> re-allocated inside SNES iterations so that I can make sure that I do it
>>> correctly?
>> No, unfortunately. Contributions always welcome :)
> OK, as a test case I'd like to modify snes/tutorials/ex1.c to destroy and
> reallocate the jacobian matrix with the same sparsity pattern
> inside FormJacobian1 (once I can do that with the same sparsity pattern,
> then it should be straightforward to do the same thing with a modified
> sparsity pattern). To do that, I tried adding the following code inside
> FormJacobian1:
>   ierr = MatDestroy(&B);
You do not want to destroy the matrix. There would be no way to get another
Mat back out of the function.
>   ierr = MatCreate(PETSC_COMM_WORLD,&B);CHKERRQ(ierr);
And do not recreate it.
>   ierr = MatSetSizes(B,PETSC_DECIDE,PETSC_DECIDE,2,2);CHKERRQ(ierr);
Nor reset the sizes. However, you do want to call
  MatSetPreallocationXAIJ();
which should work
>   ierr = MatSetFromOptions(B);CHKERRQ(ierr);
>   ierr = MatSetUp(B);CHKERRQ(ierr);
  THanks,
    Matt
> That gives a segfault, so I gather something else is needed here, any
> suggestions on what I need to do? I guess I need to do something else in
> order to make sure that the SNES uses the newly created matrix (e.g. update
> the original Mat J)?
> Thanks,
> David
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180718/7d272081/attachment-0001.html>
