[petsc-users] Problem in SNES
Matthew Knepley
knepley at gmail.com
Thu Jul 12 10:30:15 CDT 2018
On Thu, Jul 12, 2018 at 11:14 AM Ali Reza Khaz'ali <arkhazali at cc.iut.ac.ir>
wrote:
> Thanks very much for your answer,
> I am experimenting with SNES for now, however, my purpose is to solve a
> multi-physics large system with unstructured grids (Enhanced Oil Recovery
> simulation in fractured petroleum reservoirs to be specific, phase
> equilibrium and three phase flow equations must be solved simultaneously),
> where to the extend of my knowledge, no existing PETSc vector structure can
> be used. Therefore, I started with solving simple ODEs with SNES without
> using those structures.
The intention is that you use DMPlex for this.
> An interesting fact about my code samples is, with increasing the number
> of MPI workers, the number of SNES iterations (and hence, the precision of
> the solution) decrease. I'm sure there is a flaw in my code (I do not have
> much MPI experience), but I can't find it.
We really do not have the resources to debug raw MPI code. That is why we
have the examples.
Matt
> Best wishes,
> Ali
> On 7/12/2018 3:58 PM, Matthew Knepley wrote:
> On Thu, Jul 12, 2018 at 6:30 AM Ali Reza Khaz'ali <arkhazali at cc.iut.ac.ir>
> wrote:
>> Hi,
>> I have to apologize if I'm asking a noob question. I am trying to solve
>> y"-(1-x/5)yy'=x with boundary condition of y(1)=2 and y(3)=-1 with
>> finite difference method. The discretized equations is to be solved by
>> SNES. I wrote the follwoing code, however, it only works if number of
>> MPI processes is set to one. for more workers, it does not seem to give
>> valid results. I'd be grateful if anybody can guide me to debug the
>> code, please.
> Why not just use DMDA? There are lots of examples (SNES ex5 for instance)
> and it
> handles the parallelism for you. This problem could be done in a few hours
> I think.
> Thanks,
> Matt
>> Regards,
>> Ali
>> static char help[] = "Newton's method for a non-linear ODE system.\n\n";
>> double h;
>> int nParts;
>> #include <petscsnes.h>
>> User-defined routines
>> extern PetscErrorCode FormJacobian(SNES, Vec, Mat, Mat, void*);
>> extern PetscErrorCode FormFunction(SNES, Vec, Vec, void*);
>> int main(int argc, char **argv)
>> SNES snes; /* nonlinear solver context */
>> KSP ksp; /* linear solver context */
>> PC pc; /* preconditioner context */
>> Vec x, r; /* solution, residual vectors */
>> Mat J; /* Jacobian matrix */
>> PetscErrorCode ierr;
>> PetscMPIInt size;
>> PetscScalar pfive = 0, *xx;
>> int rank;
>> int i, j;
>> Vec f;
>> nParts = 30;
>> h = (3.0 - 1.0) / nParts;
>> ierr = PetscInitialize(&argc, &argv, (char*)0, help); if (ierr)
>> return ierr;
>> ierr = MPI_Comm_size(PETSC_COMM_WORLD, &size); CHKERRQ(ierr);
>> ierr = SNESCreate(PETSC_COMM_WORLD, &snes); CHKERRQ(ierr);
>> ierr = VecCreateMPI(PETSC_COMM_WORLD, PETSC_DECIDE, nParts-1, &x);
>> CHKERRQ(ierr);
>> ierr = VecDuplicate(x, &r); CHKERRQ(ierr);
>> ierr = MatCreateAIJ(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE,
>> nParts - 1, nParts - 1, 3, NULL, 3, NULL, &J); CHKERRQ(ierr);
>> ierr = SNESSetFunction(snes, r, FormFunction, NULL); CHKERRQ(ierr);
>> ierr = SNESSetJacobian(snes, J, J, FormJacobian, NULL);
>> CHKERRQ(ierr);
>> ierr = SNESGetKSP(snes, &ksp); CHKERRQ(ierr);
>> ierr = KSPGetPC(ksp, &pc); CHKERRQ(ierr);
>> ierr = KSPSetTolerances(ksp, 1.e-8, 1e-16, PETSC_DEFAULT, 200);
>> CHKERRQ(ierr);
>> ierr = SNESSetTolerances(snes, 1.e-8, 1e-16, PETSC_DEFAULT, 200,
>> 200); CHKERRQ(ierr);
>> ierr = SNESSetType(snes, SNESNEWTONLS); CHKERRQ(ierr);
>> ierr = KSPSetType(ksp, KSPCG); CHKERRQ(ierr);
>> ierr = SNESSetFromOptions(snes); CHKERRQ(ierr);
>> ierr = VecSet(x, pfive); CHKERRQ(ierr);
>> ierr = SNESSolve(snes, NULL, x); CHKERRQ(ierr);
>> ierr = SNESGetFunction(snes, &f, 0, 0); CHKERRQ(ierr);
>> ierr = VecDestroy(&x); CHKERRQ(ierr); ierr = VecDestroy(&r);
>> CHKERRQ(ierr);
>> ierr = MatDestroy(&J); CHKERRQ(ierr); ierr = SNESDestroy(&snes);
>> CHKERRQ(ierr);
>> ierr = PetscFinalize();
>> return ierr;
>> PetscErrorCode FormFunction(SNES snes, Vec x, Vec f, void *ctx)
>> const PetscScalar *xx;
>> PetscScalar *ff;
>> PetscInt vstart, vend;
>> int i, j, rank, size, xlength;
>> double xp, xxstart, xxend, x1, x2;
>> MPI_Status MyStat;
>> xxstart = 0;
>> xxend = 0;
>> MPI_Comm_rank(PETSC_COMM_WORLD, &rank);
>> ierr = VecGetOwnershipRange(x, &vstart, &vend); CHKERRQ(ierr);
>> xlength = vend - vstart;
>> ierr = VecGetArrayRead(x, &xx); CHKERRQ(ierr);
>> ierr = VecGetArray(f, &ff); CHKERRQ(ierr);
>> ierr = VecView(x, PETSC_VIEWER_STDOUT_WORLD);
>> if (size > 1) {
>> if (rank == 0) {
>> ierr = MPI_Send(&xx[xlength - 1], 1, MPI_DOUBLE, 1, 0,
>> PETSC_COMM_WORLD);
>> ierr = MPI_Recv(&xxend, 1, MPI_DOUBLE, 1, 1,
>> PETSC_COMM_WORLD, &MyStat);
>> else if (rank == (size - 1)) {
>> ierr = MPI_Recv(&xxstart, 1, MPI_DOUBLE, rank - 1, rank -
>> 1, PETSC_COMM_WORLD, &MyStat);
>> ierr = MPI_Send(&xx[0], 1, MPI_DOUBLE, rank - 1, rank,
>> PETSC_COMM_WORLD);
>> else {
>> ierr = MPI_Send(&xx[xlength - 1], 1, MPI_DOUBLE, rank + 1,
>> rank, PETSC_COMM_WORLD);
>> ierr = MPI_Recv(&xxend, 1, MPI_DOUBLE, rank + 1, rank + 1,
>> PETSC_COMM_WORLD);
>> for (i = vstart; i < vend; i++) {
>> xp = 1 + i * h;
>> j = i - vstart;
>> if (i == vstart) x1 = xxstart;
>> else x1 = xx[j - 1];
>> if (i == (vend - 1)) x2 = xxend;
>> else x2 = xx[j + 1];
>> if (i==0) ff[j] = (x2 - 2 * xx[j] + 2) / (h*h) - (1 - xp /
>> 5)*xx[j] * (x2 - 2) / (2 * h) - xp;
>> else if (i==(nParts-2)) ff[j]=(-1 - 2 * xx[j] + x1) / (h*h) -
>> (1 - xp / 5)*xx[j] * (-1 - x1) / (2 * h) - xp;
>> else ff[j] = (x2 - 2 * xx[j] + x1) / (h*h) - (1 - xp / 5)*xx[j]
>> * (x2 - x1) / (2 * h) - xp;
>> /* Restore vectors */
>> ierr = VecRestoreArrayRead(x, &xx); CHKERRQ(ierr);
>> ierr = VecRestoreArray(f, &ff); CHKERRQ(ierr);
>> return 0;
>> PetscErrorCode FormJacobian(SNES snes, Vec x, Mat jac, Mat B, void *dummy)
>> double rrow[3];
>> int col[3];
>> MPI_Status MyStat;
>> ierr = MatZeroEntries(jac); CHKERRQ(ierr);
>> xxstart = 0;
>> xxend = 0;
>> Get pointer to vector data.0+1
>> if (size > 1) {
>> if (rank == 0) {
>> PETSC_COMM_WORLD);
>> xxstart = 1e12;
>> PETSC_COMM_WORLD);
>> xxend = 1e12;
>> else {
>> PETSC_COMM_WORLD);
>> xp = 1 + i * h;
>> j = i - vstart;
>> if (i == 0) {
>> rrow[0] = -2 / (h*h) - (1 - xp / 5)*(x2 - 2) / (2 * h);
>> rrow[1] = 1 / (h*h) - (1 + xp / 5)*xx[j] / (2 * h);
>> col[0] = i;
>> col[1] = i + 1;
>> ierr = MatSetValues(jac, 1, &i, 2, col, rrow,
>> INSERT_VALUES); CHKERRQ(ierr);
>> else if (i == (nParts-2)) {
>> rrow[0] = 1 / (h*h) + (1 + xp / 5)*xx[j] / (2 * h);
>> rrow[1] = -2 / (h*h) - (1 - xp / 5)*(-1 - x1) / (2 * h);
>> col[0] = i - 1;
>> col[1] = i;
>> else {
>> rrow[1] = -2 / (h*h) - (1 - xp / 5)*(x2 - x1) / (2 * h);
>> rrow[2] = 1 / (h*h) - (1 + xp / 5)*xx[j] / (2 * h);
>> col[0] = i-1;
>> col[1] = i;
>> col[2] = i + 1;
>> ierr = MatSetValues(jac, 1, &i, 3, col, rrow,
>> Restore vector
>> Assemble matrix
>> B = jac;
>> ierr = MatAssemblyBegin(B, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
>> ierr = MatAssemblyEnd(B, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
>> ierr = MatAssemblyBegin(jac, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
>> ierr = MatAssemblyEnd(jac, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
>> return 0;
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180712/10fd4976/attachment.html>
