[petsc-users] MatMPIAIJGetSeqAIJ implemented for fortran?
Matthew Knepley
knepley at gmail.com
Mon Jul 9 21:04:12 CDT 2018
On Mon, Jul 9, 2018 at 10:02 PM Marius Buerkle <mbuerkle at web.de> wrote:
> MatGetSubmatrix is in the current PETSc released called
> MatCreateSubmatrix. Is this correct ?
Yep. I am old and cannot follow API changes anymore.
Matt
> On Mon, Jul 9, 2018 at 8:38 PM Marius Buerkle <mbuerkle at web.de> wrote:
>> I see. What I want to do is to calculate the matrix product C=A*B'
>> between two sparse matrices A=(A11 0 , A21 0) and B=(B11 0 , B21 0) where
>> C will be dense in the end but I just want to calculate some selected
>> entries C_ij of C. At the moment I extract submatricies for the
>> corresponding rows and columns,
> I think that is the right way, but you should only need MatGetSubmatrix
> for that.
> Thanks,
> Matt
>> so I was wondering if there is a simpler or performancer-wise faster way.
>> I assume there is not such thing as a restricted MatMatMul which just
>> calculated the lets say predefined nonzero entries of C.
>> These are "internal" routines that we rarely expect end users to use
>> since they are specific for particular matrix implementations. As such they
>> are also kind of strange to use from Fortran since none of the AIJ data
>> structures can be made visible to Fortran.
>> Could you explain why you want them from Fortran and maybe we'll have
>> alternative suggestions on how you can achieve the same effect.
>> Barry
>> > On Jul 5, 2018, at 3:05 AM, Marius Buerkle <mbuerkle at web.de> wrote:
>> > or MatMPIAIJGetLocalMatCondensed for that matter.
>> > Hi !
>> > Is MatMPIAIJGetSeqAIJ implemented for fortran?
>> > best,
>> > Marius
> experiments lead.
> -- Norbert Wiener
> <http://www.caam.rice.edu/~mk51/>
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180709/e36977c7/attachment.html>
