[petsc-users] Linesearch type cp change from 3.7.6 to 3.9.1
Carles Bona-Casas carles.bona at uib.es
Mon Jul 2 04:54:14 CDT 2018
Dear all,
I have been running a code with the option -snes_linesearch_type cp using
petsc 3.7.6.
I have updated my code to use petsc 3.9.1. If I run a simulation with the
updated code and the option -snes_linesearch_type cp included, I obtain the
same behaviour in the solution for a while, but then it suddenly stops
converging for no apparent reason.
If I run the same example with both petsc versions without using
-snes_linesearch_type cp then I obtain exactly the same behaviour.
My code currently runs quite faster with that option activated. Is there
some default behaviour regarding -snes_linesearch_type cp that has been
changed from petsc 3.7 to petsc 3.9?
I attach my 3 outputs. With petsc 3.7.6 and cp option activated. With petsc
3.9.1 and cp option activated (not converging). And without cp option
activated (only one file, same result with both petsc versions).
I am also open to suggestions of different solvers that could work better
than using -snes_linesearch_type cp.
Many thanks,
Carles
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180702/b5a51e82/attachment-0001.html>
muS = 2.000000e-03
cS = 5.000000e+00
kappaS = 1.000000e-12
IGA: name=(null) prefix=geo_
IGA: dim=3 dof=1 order=2 geometry=3 rational=0 property=0
Axis 0: basis=BSPLINE[2,1] rule=LEGENDRE[3] periodic=1 nnp=20 nel=20
Axis 1: basis=BSPLINE[2,1] rule=LEGENDRE[3] periodic=1 nnp=20 nel=20
Axis 2: basis=BSPLINE[2,1] rule=LEGENDRE[3] periodic=0 nnp=22 nel=20
Partition - MPI: processors=[1,1,2] total=2
Partition - nnp: sum=8800 min=4000 max=4800 max/min=1.2
Partition - nel: sum=8000 min=4000 max=4000 max/min=1.
IGA: name=(null) prefix=u_
IGA: dim=3 dof=1 order=1 geometry=0 rational=0 property=0
Axis 0: basis=BSPLINE[3,2] rule=LEGENDRE[3] periodic=1 nnp=20 nel=20
IGA: name=(null) prefix=v_
Axis 1: basis=BSPLINE[3,2] rule=LEGENDRE[3] periodic=1 nnp=20 nel=20
IGA: name=(null) prefix=w_
Axis 2: basis=BSPLINE[3,2] rule=LEGENDRE[3] periodic=0 nnp=23 nel=20
Partition - nnp: sum=9200 min=4000 max=5200 max/min=1.3
IGA: name=(null) prefix=p_
nquadghost*commsize*user->safetyquadghost = 574452, nquadghost*nghost*user->safetyquadghost = 287226, nquadghost*user->safetyquadghost = 287226
 nquadreal*commsize*user->safetyquad = 1531904, nquadreal*nghost*user->safetyquad = 765952, nquadreal*user->safetyquad = 765952
user.Alpha_f: 6.666667e-01 user.Alpha_m: 8.333333e-01 user.gamma: 6.666667e-01 th->shift_V: 1.875000e+04
 0 TS dt 0.0001 time 0.
Linear solve converged due to CONVERGED_ATOL iterations 0
 FirstNewton = 0
    0 SNES Function norm 3.572897994044e+01
NORM2F: 3.572898e+01 NORM2F/NORM2F0: 1.000000e+00
NORM2dof0: 3.572898e+01 NORM2dof0/NORM2dof00: 1.000000e+00
NORM2dof1: 1.299331e-03 NORM2dof1/NORM2dof10: 1.000000e+00
NORM2dof2: 2.051284e-03 NORM2dof2/NORM2dof20: 1.000000e+00
NORM2dof3: 0.000000e+00 NORM2dof3/NORM2dof30: -nan
isolid: 0 NORM2S: 0.000000e+00 NORM2S/NORM2S0: -nan
 Tangent
       0 KSP Residual norm 3.572897994044e+01
      1 KSP Residual norm 4.590932150940e-03
      2 KSP Residual norm 1.083125383106e-03
      3 KSP Residual norm 2.663513431881e-04
      4 KSP Residual norm 8.855948174613e-05
      5 KSP Residual norm 1.384048225253e-05
      6 KSP Residual norm 3.967355444542e-06
      7 KSP Residual norm 6.673586109137e-07
      8 KSP Residual norm 2.483423008390e-07
      9 KSP Residual norm 6.132481698570e-08
     10 KSP Residual norm 9.689659347469e-09
    Linear solve converged due to CONVERGED_ATOL iterations 10
Linear solve converged due to CONVERGED_RTOL iterations 7
 FirstNewton = 0
 FirstNewton = 0
    1 SNES Function norm 1.090748487093e-02
NORM2F: 1.090748e-02 NORM2F/NORM2F0: 3.052840e-04
NORM2dof0: 7.230531e-03 NORM2dof0/NORM2dof00: 2.023716e-04
NORM2dof1: 5.503796e-03 NORM2dof1/NORM2dof10: 4.235868e+00
NORM2dof2: 6.033314e-03 NORM2dof2/NORM2dof20: 2.941237e+00
NORM2dof3: 8.833762e-09 NORM2dof3/NORM2dof30: inf
isolid: 0 NORM2S: 1.830489e-10 NORM2S/NORM2S0: inf
  Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 1
1 TS dt 0.0001 time 0.0001
 FirstNewton = 0
    0 SNES Function norm 1.785763644723e+01
NORM2F: 1.785764e+01 NORM2F/NORM2F0: 1.000000e+00
NORM2dof0: 1.785762e+01 NORM2dof0/NORM2dof00: 1.000000e+00
NORM2dof1: 1.556293e-02 NORM2dof1/NORM2dof10: 1.000000e+00
NORM2dof2: 1.702734e-02 NORM2dof2/NORM2dof20: 1.000000e+00
NORM2dof3: 1.325064e-08 NORM2dof3/NORM2dof30: 1.000000e+00
isolid: 0 NORM2S: 9.701488e-10 NORM2S/NORM2S0: 1.000000e+00
 Tangent
       0 KSP Residual norm 1.785763644723e+01
      1 KSP Residual norm 5.049628562672e-02
      2 KSP Residual norm 3.604517028341e-03
      3 KSP Residual norm 7.619397990279e-04
      4 KSP Residual norm 1.195867329688e-04
      5 KSP Residual norm 2.195409915994e-05
      6 KSP Residual norm 4.518605013445e-06
      7 KSP Residual norm 1.857558801337e-06
      8 KSP Residual norm 2.412824487070e-07
      9 KSP Residual norm 9.323085453228e-08
     10 KSP Residual norm 2.206166843857e-08
     11 KSP Residual norm 4.267397332011e-09
    Linear solve converged due to CONVERGED_ATOL iterations 11
 FirstNewton = 0
 FirstNewton = 0
    1 SNES Function norm 2.844794057916e-03
NORM2F: 2.844794e-03 NORM2F/NORM2F0: 1.593041e-04
NORM2dof0: 2.062497e-03 NORM2dof0/NORM2dof00: 1.154967e-04
NORM2dof1: 1.454168e-03 NORM2dof1/NORM2dof10: 9.343790e-02
NORM2dof2: 1.313147e-03 NORM2dof2/NORM2dof20: 7.711992e-02
NORM2dof3: 4.141942e-09 NORM2dof3/NORM2dof30: 3.125842e-01
isolid: 0 NORM2S: 4.985943e-11 NORM2S/NORM2S0: 5.139359e-02
      0 KSP Residual norm 2.844794057916e-03
      1 KSP Residual norm 2.295043475141e-03
      2 KSP Residual norm 1.583104677387e-04
      3 KSP Residual norm 1.490919842246e-05
      4 KSP Residual norm 1.548465044309e-06
      5 KSP Residual norm 2.640015039860e-07
      6 KSP Residual norm 4.322481936532e-08
      7 KSP Residual norm 1.473218623954e-08
      8 KSP Residual norm 2.888610560249e-09
    Linear solve converged due to CONVERGED_ATOL iterations 8
 FirstNewton = 0
 FirstNewton = 0
    2 SNES Function norm 1.254901830802e-04
NORM2F: 1.254902e-04 NORM2F/NORM2F0: 7.027256e-06
NORM2dof0: 6.833894e-05 NORM2dof0/NORM2dof00: 3.826878e-06
NORM2dof1: 5.101309e-05 NORM2dof1/NORM2dof10: 3.277859e-03
NORM2dof2: 9.206107e-05 NORM2dof2/NORM2dof20: 5.406660e-03
NORM2dof3: 2.733176e-09 NORM2dof3/NORM2dof30: 2.062674e-01
isolid: 0 NORM2S: 5.337186e-12 NORM2S/NORM2S0: 5.501410e-03
      0 KSP Residual norm 1.254901830802e-04
      1 KSP Residual norm 1.003678752334e-04
      2 KSP Residual norm 1.193320199479e-05
      3 KSP Residual norm 5.187856996866e-07
      4 KSP Residual norm 6.216090455420e-08
      5 KSP Residual norm 1.241994457144e-08
      6 KSP Residual norm 3.149627739665e-09
    Linear solve converged due to CONVERGED_ATOL iterations 6
 FirstNewton = 0
 FirstNewton = 0
    3 SNES Function norm 8.107335723850e-06
NORM2F: 8.107336e-06 NORM2F/NORM2F0: 4.539983e-07
NORM2dof0: 4.912488e-06 NORM2dof0/NORM2dof00: 2.750920e-07
NORM2dof1: 3.357647e-06 NORM2dof1/NORM2dof10: 2.157464e-04
NORM2dof2: 5.506592e-06 NORM2dof2/NORM2dof20: 3.233970e-04
NORM2dof3: 3.023016e-09 NORM2dof3/NORM2dof30: 2.281411e-01
isolid: 0 NORM2S: 5.802563e-13 NORM2S/NORM2S0: 5.981107e-04
  Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 3
2 TS dt 0.0001 time 0.0002
 FirstNewton = 0
    0 SNES Function norm 8.924122178623e+00
NORM2F: 8.924122e+00 NORM2F/NORM2F0: 1.000000e+00
NORM2dof0: 8.924122e+00 NORM2dof0/NORM2dof00: 1.000000e+00
NORM2dof1: 2.326868e-03 NORM2dof1/NORM2dof10: 1.000000e+00
NORM2dof2: 2.202884e-03 NORM2dof2/NORM2dof20: 1.000000e+00
NORM2dof3: 8.367864e-09 NORM2dof3/NORM2dof30: 1.000000e+00
isolid: 0 NORM2S: 7.201607e-10 NORM2S/NORM2S0: 1.000000e+00
 Tangent
       0 KSP Residual norm 8.924122178623e+00
      1 KSP Residual norm 6.607063311348e-03
      2 KSP Residual norm 3.141865121251e-04
      3 KSP Residual norm 6.120575062805e-05
      4 KSP Residual norm 9.242740946611e-06
      5 KSP Residual norm 1.330632161167e-06
      6 KSP Residual norm 5.727762329876e-07
      7 KSP Residual norm 9.569604811720e-08
      8 KSP Residual norm 2.510214586422e-08
      9 KSP Residual norm 5.482441707317e-09
    Linear solve converged due to CONVERGED_ATOL iterations 9
 FirstNewton = 0
 FirstNewton = 0
    1 SNES Function norm 3.845740765508e-03
NORM2F: 3.845741e-03 NORM2F/NORM2F0: 4.309377e-04
NORM2dof0: 2.666434e-03 NORM2dof0/NORM2dof00: 2.987895e-04
NORM2dof1: 1.926033e-03 NORM2dof1/NORM2dof10: 8.277363e-01
NORM2dof2: 1.992548e-03 NORM2dof2/NORM2dof20: 9.045182e-01
NORM2dof3: 5.467552e-09 NORM2dof3/NORM2dof30: 6.533988e-01
isolid: 0 NORM2S: 8.819637e-11 NORM2S/NORM2S0: 1.224676e-01
      0 KSP Residual norm 3.845740765508e-03
      1 KSP Residual norm 3.268192036307e-03
      2 KSP Residual norm 4.485759584760e-04
      3 KSP Residual norm 5.155662226308e-05
      4 KSP Residual norm 4.845743277285e-06
      5 KSP Residual norm 1.439807997801e-06
      6 KSP Residual norm 1.043760500828e-07
      7 KSP Residual norm 3.976004664704e-08
      8 KSP Residual norm 7.196889051981e-09
 FirstNewton = 0
 FirstNewton = 0
    2 SNES Function norm 1.523034956621e-04
NORM2F: 1.523035e-04 NORM2F/NORM2F0: 1.706650e-05
NORM2dof0: 1.001345e-04 NORM2dof0/NORM2dof00: 1.122066e-05
NORM2dof1: 6.852295e-05 NORM2dof1/NORM2dof10: 2.944857e-02
NORM2dof2: 9.205456e-05 NORM2dof2/NORM2dof20: 4.178821e-02
NORM2dof3: 6.848339e-09 NORM2dof3/NORM2dof30: 8.184095e-01
isolid: 0 NORM2S: 9.759938e-12 NORM2S/NORM2S0: 1.355244e-02
      0 KSP Residual norm 1.523034956621e-04
      1 KSP Residual norm 1.193197002149e-04
      2 KSP Residual norm 1.286757063817e-05
      3 KSP Residual norm 1.947459077256e-06
      4 KSP Residual norm 5.526459925181e-07
      5 KSP Residual norm 5.326425071623e-08
      6 KSP Residual norm 4.721859648901e-09
 FirstNewton = 0
 FirstNewton = 0
    3 SNES Function norm 1.411908637308e-05
NORM2F: 1.411909e-05 NORM2F/NORM2F0: 1.582126e-06
NORM2dof0: 7.713374e-06 NORM2dof0/NORM2dof00: 8.643286e-07
NORM2dof1: 5.780273e-06 NORM2dof1/NORM2dof10: 2.484143e-03
NORM2dof2: 1.031702e-05 NORM2dof2/NORM2dof20: 4.683416e-03
NORM2dof3: 4.547591e-09 NORM2dof3/NORM2dof30: 5.434590e-01
isolid: 0 NORM2S: 1.069509e-12 NORM2S/NORM2S0: 1.485097e-03
      0 KSP Residual norm 1.411908637308e-05
      1 KSP Residual norm 1.147024084834e-05
      2 KSP Residual norm 1.642505389573e-06
      3 KSP Residual norm 9.393394026575e-08
      4 KSP Residual norm 3.802608131827e-08
      5 KSP Residual norm 3.488335303587e-09
    Linear solve converged due to CONVERGED_ATOL iterations 5
 FirstNewton = 0
 FirstNewton = 0
    4 SNES Function norm 1.219642897375e-06
NORM2F: 1.219643e-06 NORM2F/NORM2F0: 1.366681e-07
NORM2dof0: 7.904453e-07 NORM2dof0/NORM2dof00: 8.857402e-08
NORM2dof1: 5.299586e-07 NORM2dof1/NORM2dof10: 2.277562e-04
NORM2dof2: 7.627955e-07 NORM2dof2/NORM2dof20: 3.462714e-04
NORM2dof3: 3.457406e-09 NORM2dof3/NORM2dof30: 4.131767e-01
isolid: 0 NORM2S: 1.174284e-13 NORM2S/NORM2S0: 1.630586e-04
  Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 4
3 TS dt 0.0001 time 0.0003
 FirstNewton = 0
    0 SNES Function norm 4.459023414102e+00
NORM2F: 4.459023e+00 NORM2F/NORM2F0: 1.000000e+00
NORM2dof0: 4.459018e+00 NORM2dof0/NORM2dof00: 1.000000e+00
NORM2dof1: 4.580802e-03 NORM2dof1/NORM2dof10: 1.000000e+00
NORM2dof2: 5.158376e-03 NORM2dof2/NORM2dof20: 1.000000e+00
NORM2dof3: 6.755218e-09 NORM2dof3/NORM2dof30: 1.000000e+00
isolid: 0 NORM2S: 7.331618e-10 NORM2S/NORM2S0: 1.000000e+00
 Tangent
       0 KSP Residual norm 4.459023414102e+00
      1 KSP Residual norm 1.551248642940e-02
      2 KSP Residual norm 1.181711188808e-03
      3 KSP Residual norm 2.267481587314e-04
      4 KSP Residual norm 2.354870533968e-05
      5 KSP Residual norm 6.843344194293e-06
      6 KSP Residual norm 1.323194294602e-06
      7 KSP Residual norm 6.111386767871e-07
      8 KSP Residual norm 6.462270983371e-08
      9 KSP Residual norm 2.618035020596e-08
     10 KSP Residual norm 4.913681339401e-09
 FirstNewton = 0
 FirstNewton = 0
    1 SNES Function norm 1.235058837418e-03
NORM2F: 1.235059e-03 NORM2F/NORM2F0: 2.769797e-04
NORM2dof0: 6.981526e-04 NORM2dof0/NORM2dof00: 1.565709e-04
NORM2dof1: 4.902291e-04 NORM2dof1/NORM2dof10: 1.070182e-01
NORM2dof2: 8.931006e-04 NORM2dof2/NORM2dof20: 1.731360e-01
NORM2dof3: 4.742660e-09 NORM2dof3/NORM2dof30: 7.020735e-01
isolid: 0 NORM2S: 8.727352e-11 NORM2S/NORM2S0: 1.190372e-01
      0 KSP Residual norm 1.235058837418e-03
      1 KSP Residual norm 1.069627681061e-03
      2 KSP Residual norm 1.751562909186e-04
      3 KSP Residual norm 2.703186524530e-05
      4 KSP Residual norm 5.488929738991e-06
      5 KSP Residual norm 7.719484131288e-07
      6 KSP Residual norm 7.094194677354e-08
      7 KSP Residual norm 1.982339781034e-08
      8 KSP Residual norm 4.747189973889e-09
 FirstNewton = 0
 FirstNewton = 0
    2 SNES Function norm 9.078241410441e-05
NORM2F: 9.078241e-05 NORM2F/NORM2F0: 2.035926e-05
NORM2dof0: 5.151981e-05 NORM2dof0/NORM2dof00: 1.155407e-05
NORM2dof1: 3.540856e-05 NORM2dof1/NORM2dof10: 7.729773e-03
NORM2dof2: 6.582849e-05 NORM2dof2/NORM2dof20: 1.276148e-02
NORM2dof3: 4.701207e-09 NORM2dof3/NORM2dof30: 6.959371e-01
isolid: 0 NORM2S: 9.561275e-12 NORM2S/NORM2S0: 1.304115e-02
      0 KSP Residual norm 9.078241410441e-05
      1 KSP Residual norm 7.519329586572e-05
      2 KSP Residual norm 1.378553745900e-05
      3 KSP Residual norm 1.089007081012e-06
      4 KSP Residual norm 4.184123441247e-07
      5 KSP Residual norm 4.472071463938e-08
      6 KSP Residual norm 3.767042899970e-09
 FirstNewton = 0
 FirstNewton = 0
    3 SNES Function norm 9.925973941521e-06
NORM2F: 9.925974e-06 NORM2F/NORM2F0: 2.226042e-06
NORM2dof0: 7.244159e-06 NORM2dof0/NORM2dof00: 1.624608e-06
NORM2dof1: 4.332858e-06 NORM2dof1/NORM2dof10: 9.458732e-04
NORM2dof2: 5.222399e-06 NORM2dof2/NORM2dof20: 1.012412e-03
NORM2dof3: 3.828590e-09 NORM2dof3/NORM2dof30: 5.667603e-01
isolid: 0 NORM2S: 1.046812e-12 NORM2S/NORM2S0: 1.427805e-03
      0 KSP Residual norm 9.925973941521e-06
      1 KSP Residual norm 7.973871208680e-06
      2 KSP Residual norm 9.575431070645e-07
      3 KSP Residual norm 1.480552171494e-07
      4 KSP Residual norm 4.630259649424e-08
      5 KSP Residual norm 3.443641759732e-09
 FirstNewton = 0
 FirstNewton = 0
    4 SNES Function norm 1.227659573145e-06
NORM2F: 1.227660e-06 NORM2F/NORM2F0: 2.753203e-07
NORM2dof0: 7.906333e-07 NORM2dof0/NORM2dof00: 1.773111e-07
NORM2dof1: 4.780907e-07 NORM2dof1/NORM2dof10: 1.043683e-04
NORM2dof2: 8.083717e-07 NORM2dof2/NORM2dof20: 1.567105e-04
NORM2dof3: 3.386631e-09 NORM2dof3/NORM2dof30: 5.013356e-01
isolid: 0 NORM2S: 1.151816e-13 NORM2S/NORM2S0: 1.571026e-04
4 TS dt 0.0001 time 0.0004
 FirstNewton = 0
    0 SNES Function norm 2.227652021285e+00
NORM2F: 2.227652e+00 NORM2F/NORM2F0: 1.000000e+00
NORM2dof0: 2.227651e+00 NORM2dof0/NORM2dof00: 1.000000e+00
NORM2dof1: 9.388411e-04 NORM2dof1/NORM2dof10: 1.000000e+00
NORM2dof2: 1.525870e-03 NORM2dof2/NORM2dof20: 1.000000e+00
NORM2dof3: 4.190710e-09 NORM2dof3/NORM2dof30: 1.000000e+00
isolid: 0 NORM2S: 7.712497e-10 NORM2S/NORM2S0: 1.000000e+00
 Tangent
       0 KSP Residual norm 2.227652021285e+00
      1 KSP Residual norm 3.786666383186e-03
      2 KSP Residual norm 3.701315772265e-04
      3 KSP Residual norm 1.262250621903e-04
      4 KSP Residual norm 1.679275296591e-05
      5 KSP Residual norm 3.701940311263e-06
      6 KSP Residual norm 8.991893299755e-07
      7 KSP Residual norm 3.274255166243e-07
      8 KSP Residual norm 4.205190863902e-08
      9 KSP Residual norm 1.016597417602e-08
     10 KSP Residual norm 2.186992150925e-09
 FirstNewton = 0
 FirstNewton = 0
    1 SNES Function norm 1.277951785028e-03
NORM2F: 1.277952e-03 NORM2F/NORM2F0: 5.736766e-04
NORM2dof0: 8.837677e-04 NORM2dof0/NORM2dof00: 3.967262e-04
NORM2dof1: 5.862336e-04 NORM2dof1/NORM2dof10: 6.244226e-01
NORM2dof2: 7.130537e-04 NORM2dof2/NORM2dof20: 4.673097e-01
NORM2dof3: 2.150732e-09 NORM2dof3/NORM2dof30: 5.132143e-01
isolid: 0 NORM2S: 7.794527e-11 NORM2S/NORM2S0: 1.010636e-01
      0 KSP Residual norm 1.277951785028e-03
      1 KSP Residual norm 1.108159885768e-03
      2 KSP Residual norm 2.090485440396e-04
      3 KSP Residual norm 2.561905167721e-05
      4 KSP Residual norm 5.783875463940e-06
      5 KSP Residual norm 7.758000687848e-07
      6 KSP Residual norm 6.231373273124e-08
      7 KSP Residual norm 2.150745162428e-08
      8 KSP Residual norm 4.524271362583e-09
 FirstNewton = 0
 FirstNewton = 0
    2 SNES Function norm 8.254873642334e-05
NORM2F: 8.254874e-05 NORM2F/NORM2F0: 3.705639e-05
NORM2dof0: 5.506456e-05 NORM2dof0/NORM2dof00: 2.471866e-05
NORM2dof1: 4.168084e-05 NORM2dof1/NORM2dof10: 4.439605e-02
NORM2dof2: 4.522052e-05 NORM2dof2/NORM2dof20: 2.963590e-02
NORM2dof3: 4.467248e-09 NORM2dof3/NORM2dof30: 1.065988e+00
isolid: 0 NORM2S: 8.595316e-12 NORM2S/NORM2S0: 1.114466e-02
      0 KSP Residual norm 8.254873642334e-05
      1 KSP Residual norm 6.729252136059e-05
      2 KSP Residual norm 8.788120855611e-06
      3 KSP Residual norm 1.201268287855e-06
      4 KSP Residual norm 4.988194555893e-07
      5 KSP Residual norm 2.223026886510e-08
      6 KSP Residual norm 4.505928485128e-09
 FirstNewton = 0
 FirstNewton = 0
    3 SNES Function norm 8.239534215470e-06
NORM2F: 8.239534e-06 NORM2F/NORM2F0: 3.698753e-06
NORM2dof0: 5.660320e-06 NORM2dof0/NORM2dof00: 2.540936e-06
NORM2dof1: 3.405783e-06 NORM2dof1/NORM2dof10: 3.627645e-03
NORM2dof2: 4.924564e-06 NORM2dof2/NORM2dof20: 3.227381e-03
NORM2dof3: 4.599213e-09 NORM2dof3/NORM2dof30: 1.097478e+00
isolid: 0 NORM2S: 9.412050e-13 NORM2S/NORM2S0: 1.220363e-03
      0 KSP Residual norm 8.239534215470e-06
      1 KSP Residual norm 6.842412348586e-06
      2 KSP Residual norm 1.256835232271e-06
      3 KSP Residual norm 1.094224194536e-07
      4 KSP Residual norm 4.243344132633e-08
      5 KSP Residual norm 3.713281685403e-09
 FirstNewton = 0
 FirstNewton = 0
    4 SNES Function norm 1.011901923248e-06
NORM2F: 1.011902e-06 NORM2F/NORM2F0: 4.542460e-07
NORM2dof0: 6.804013e-07 NORM2dof0/NORM2dof00: 3.054344e-07
NORM2dof1: 4.824999e-07 NORM2dof1/NORM2dof10: 5.139314e-04
NORM2dof2: 5.728699e-07 NORM2dof2/NORM2dof20: 3.754383e-04
NORM2dof3: 3.679214e-09 NORM2dof3/NORM2dof30: 8.779451e-01
isolid: 0 NORM2S: 1.040252e-13 NORM2S/NORM2S0: 1.348788e-04
5 TS dt 0.0001 time 0.0005
 FirstNewton = 0
    0 SNES Function norm 1.112741935211e+00
NORM2F: 1.112742e+00 NORM2F/NORM2F0: 1.000000e+00
NORM2dof0: 1.112739e+00 NORM2dof0/NORM2dof00: 1.000000e+00
NORM2dof1: 1.687493e-03 NORM2dof1/NORM2dof10: 1.000000e+00
NORM2dof2: 2.151957e-03 NORM2dof2/NORM2dof20: 1.000000e+00
NORM2dof3: 4.819524e-09 NORM2dof3/NORM2dof30: 1.000000e+00
isolid: 0 NORM2S: 7.286157e-10 NORM2S/NORM2S0: 1.000000e+00
 Tangent
       0 KSP Residual norm 1.112741935211e+00
      1 KSP Residual norm 6.570699837645e-03
      2 KSP Residual norm 5.670137795539e-04
      3 KSP Residual norm 1.103059530678e-04
      4 KSP Residual norm 1.216088727932e-05
      5 KSP Residual norm 4.415523502414e-06
      6 KSP Residual norm 9.655680425077e-07
      7 KSP Residual norm 2.771156802885e-07
      8 KSP Residual norm 4.442862448976e-08
      9 KSP Residual norm 9.129876075118e-09
 FirstNewton = 0
 FirstNewton = 0
    1 SNES Function norm 1.015995837115e-03
NORM2F: 1.015996e-03 NORM2F/NORM2F0: 9.130561e-04
NORM2dof0: 6.305959e-04 NORM2dof0/NORM2dof00: 5.667062e-04
NORM2dof1: 4.264896e-04 NORM2dof1/NORM2dof10: 2.527356e-01
NORM2dof2: 6.728321e-04 NORM2dof2/NORM2dof20: 3.126606e-01
NORM2dof3: 8.394649e-09 NORM2dof3/NORM2dof30: 1.741800e+00
isolid: 0 NORM2S: 8.591898e-11 NORM2S/NORM2S0: 1.179209e-01
      0 KSP Residual norm 1.015995837115e-03
      1 KSP Residual norm 8.961031948738e-04
      2 KSP Residual norm 1.803075486093e-04
      3 KSP Residual norm 2.625118595007e-05
      4 KSP Residual norm 7.490927206153e-06
      5 KSP Residual norm 7.053295117139e-07
      6 KSP Residual norm 6.224399093315e-08
      7 KSP Residual norm 2.320153042766e-08
      8 KSP Residual norm 4.536035912660e-09
 FirstNewton = 0
 FirstNewton = 0
    2 SNES Function norm 7.443055823368e-05
NORM2F: 7.443056e-05 NORM2F/NORM2F0: 6.688933e-05
NORM2dof0: 4.310318e-05 NORM2dof0/NORM2dof00: 3.873612e-05
NORM2dof1: 3.418390e-05 NORM2dof1/NORM2dof10: 2.025721e-02
NORM2dof2: 5.013467e-05 NORM2dof2/NORM2dof20: 2.329725e-02
NORM2dof3: 4.557719e-09 NORM2dof3/NORM2dof30: 9.456783e-01
isolid: 0 NORM2S: 9.433112e-12 NORM2S/NORM2S0: 1.294662e-02
      0 KSP Residual norm 7.443055823368e-05
      1 KSP Residual norm 6.274316285393e-05
      2 KSP Residual norm 8.652669262381e-06
      3 KSP Residual norm 1.005540492343e-06
      4 KSP Residual norm 4.563068174216e-07
      5 KSP Residual norm 2.152406398234e-08
      6 KSP Residual norm 4.789585951088e-09
 FirstNewton = 0
 FirstNewton = 0
    3 SNES Function norm 7.692987800073e-06
NORM2F: 7.692988e-06 NORM2F/NORM2F0: 6.913542e-06
NORM2dof0: 5.335668e-06 NORM2dof0/NORM2dof00: 4.795078e-06
NORM2dof1: 3.195147e-06 NORM2dof1/NORM2dof10: 1.893428e-03
NORM2dof2: 4.528103e-06 NORM2dof2/NORM2dof20: 2.104180e-03
NORM2dof3: 4.957642e-09 NORM2dof3/NORM2dof30: 1.028658e+00
isolid: 0 NORM2S: 1.034012e-12 NORM2S/NORM2S0: 1.419146e-03
      0 KSP Residual norm 7.692987800073e-06
      1 KSP Residual norm 6.593187966360e-06
      2 KSP Residual norm 1.156033183066e-06
      3 KSP Residual norm 1.713473668329e-07
      4 KSP Residual norm 6.039939982309e-08
      5 KSP Residual norm 3.833553662672e-09
 FirstNewton = 0
 FirstNewton = 0
    4 SNES Function norm 1.050495442306e-06
NORM2F: 1.050495e-06 NORM2F/NORM2F0: 9.440603e-07
NORM2dof0: 7.102321e-07 NORM2dof0/NORM2dof00: 6.382740e-07
NORM2dof1: 4.404641e-07 NORM2dof1/NORM2dof10: 2.610168e-04
NORM2dof2: 6.364650e-07 NORM2dof2/NORM2dof20: 2.957611e-04
NORM2dof3: 3.839806e-09 NORM2dof3/NORM2dof30: 7.967189e-01
isolid: 0 NORM2S: 1.142188e-13 NORM2S/NORM2S0: 1.567614e-04
6 TS dt 0.0001 time 0.0006
 FirstNewton = 0
    0 SNES Function norm 5.557525996674e-01
NORM2F: 5.557526e-01 NORM2F/NORM2F0: 1.000000e+00
NORM2dof0: 5.557501e-01 NORM2dof0/NORM2dof00: 1.000000e+00
NORM2dof1: 9.210335e-04 NORM2dof1/NORM2dof10: 1.000000e+00
NORM2dof2: 1.393950e-03 NORM2dof2/NORM2dof20: 1.000000e+00
NORM2dof3: 4.445345e-09 NORM2dof3/NORM2dof30: 1.000000e+00
isolid: 0 NORM2S: 7.524837e-10 NORM2S/NORM2S0: 1.000000e+00
 Tangent
       0 KSP Residual norm 5.557525996674e-01
      1 KSP Residual norm 4.020605119036e-03
      2 KSP Residual norm 3.993968677548e-04
      3 KSP Residual norm 7.858906693256e-05
      4 KSP Residual norm 1.187156829761e-05
      5 KSP Residual norm 2.853870444655e-06
      6 KSP Residual norm 5.910350554108e-07
      7 KSP Residual norm 1.907378330253e-07
      8 KSP Residual norm 4.109214096616e-08
      9 KSP Residual norm 8.187331871712e-09
 FirstNewton = 0
 FirstNewton = 0
    1 SNES Function norm 8.005861073118e-04
NORM2F: 8.005861e-04 NORM2F/NORM2F0: 1.440544e-03
NORM2dof0: 5.305707e-04 NORM2dof0/NORM2dof00: 9.546930e-04
NORM2dof1: 3.314747e-04 NORM2dof1/NORM2dof10: 3.598943e-01
NORM2dof2: 4.995572e-04 NORM2dof2/NORM2dof20: 3.583753e-01
NORM2dof3: 8.096245e-09 NORM2dof3/NORM2dof30: 1.821286e+00
isolid: 0 NORM2S: 8.036640e-11 NORM2S/NORM2S0: 1.068015e-01
      0 KSP Residual norm 8.005861073118e-04
      1 KSP Residual norm 7.105563993615e-04
      2 KSP Residual norm 1.569400455800e-04
      3 KSP Residual norm 2.148260696075e-05
      4 KSP Residual norm 7.577783405191e-06
      5 KSP Residual norm 4.940178488635e-07
      6 KSP Residual norm 5.881184293810e-08
      7 KSP Residual norm 1.681579433994e-08
      8 KSP Residual norm 3.550381279058e-09
 FirstNewton = 0
 FirstNewton = 0
    2 SNES Function norm 6.639356173983e-05
NORM2F: 6.639356e-05 NORM2F/NORM2F0: 1.194660e-04
NORM2dof0: 4.252628e-05 NORM2dof0/NORM2dof00: 7.652052e-05
NORM2dof1: 3.279431e-05 NORM2dof1/NORM2dof10: 3.560598e-02
NORM2dof2: 3.904041e-05 NORM2dof2/NORM2dof20: 2.800704e-02
NORM2dof3: 3.699852e-09 NORM2dof3/NORM2dof30: 8.322980e-01
isolid: 0 NORM2S: 8.825986e-12 NORM2S/NORM2S0: 1.172914e-02
      0 KSP Residual norm 6.639356173983e-05
      1 KSP Residual norm 5.533750957699e-05
      2 KSP Residual norm 5.486233489635e-06
      3 KSP Residual norm 8.245430728972e-07
      4 KSP Residual norm 3.400428911218e-07
      5 KSP Residual norm 1.251556457453e-08
      6 KSP Residual norm 4.601696859316e-09
 FirstNewton = 0
 FirstNewton = 0
    3 SNES Function norm 8.166871579835e-06
NORM2F: 8.166872e-06 NORM2F/NORM2F0: 1.469516e-05
NORM2dof0: 5.917787e-06 NORM2dof0/NORM2dof00: 1.064829e-05
NORM2dof1: 3.376949e-06 NORM2dof1/NORM2dof10: 3.666478e-03
NORM2dof2: 4.502641e-06 NORM2dof2/NORM2dof20: 3.230131e-03
NORM2dof3: 4.676454e-09 NORM2dof3/NORM2dof30: 1.051989e+00
isolid: 0 NORM2S: 9.699273e-13 NORM2S/NORM2S0: 1.288968e-03
      0 KSP Residual norm 8.166871579835e-06
      1 KSP Residual norm 7.070302120658e-06
      2 KSP Residual norm 1.380763296070e-06
      3 KSP Residual norm 1.822364755135e-07
      4 KSP Residual norm 7.424261694518e-08
      5 KSP Residual norm 3.818437565938e-09
 FirstNewton = 0
 FirstNewton = 0
    4 SNES Function norm 1.020601918719e-06
NORM2F: 1.020602e-06 NORM2F/NORM2F0: 1.836432e-06
NORM2dof0: 7.263342e-07 NORM2dof0/NORM2dof00: 1.306944e-06
NORM2dof1: 4.600303e-07 NORM2dof1/NORM2dof10: 4.994718e-04
NORM2dof2: 5.499312e-07 NORM2dof2/NORM2dof20: 3.945129e-04
NORM2dof3: 3.829265e-09 NORM2dof3/NORM2dof30: 8.614101e-01
isolid: 0 NORM2S: 1.070798e-13 NORM2S/NORM2S0: 1.423018e-04
7 TS dt 0.0001 time 0.0007
 FirstNewton = 0
    0 SNES Function norm 2.775343560554e-01
NORM2F: 2.775344e-01 NORM2F/NORM2F0: 1.000000e+00
NORM2dof0: 2.775296e-01 NORM2dof0/NORM2dof00: 1.000000e+00
NORM2dof1: 9.197075e-04 NORM2dof1/NORM2dof10: 1.000000e+00
NORM2dof2: 1.341120e-03 NORM2dof2/NORM2dof20: 1.000000e+00
NORM2dof3: 4.039119e-09 NORM2dof3/NORM2dof30: 1.000000e+00
isolid: 0 NORM2S: 7.359843e-10 NORM2S/NORM2S0: 1.000000e+00
 Tangent
       0 KSP Residual norm 2.775343560554e-01
      1 KSP Residual norm 4.234920558509e-03
      2 KSP Residual norm 4.101297407319e-04
      3 KSP Residual norm 6.220774614011e-05
      4 KSP Residual norm 1.856125916344e-05
      5 KSP Residual norm 1.147809993928e-06
      6 KSP Residual norm 2.206587564519e-07
      7 KSP Residual norm 4.407254089560e-08
      8 KSP Residual norm 5.910241359258e-09
 FirstNewton = 0
 FirstNewton = 0
    1 SNES Function norm 7.939773687909e-04
NORM2F: 7.939774e-04 NORM2F/NORM2F0: 2.860826e-03
NORM2dof0: 5.117460e-04 NORM2dof0/NORM2dof00: 1.843933e-03
NORM2dof1: 3.327861e-04 NORM2dof1/NORM2dof10: 3.618391e-01
NORM2dof2: 5.077100e-04 NORM2dof2/NORM2dof20: 3.785718e-01
NORM2dof3: 5.798578e-09 NORM2dof3/NORM2dof30: 1.435605e+00
isolid: 0 NORM2S: 8.291750e-11 NORM2S/NORM2S0: 1.126620e-01
      0 KSP Residual norm 7.939773687909e-04
      1 KSP Residual norm 7.098870331169e-04
      2 KSP Residual norm 1.545057322866e-04
      3 KSP Residual norm 2.239762735179e-05
      4 KSP Residual norm 8.601875261907e-06
      5 KSP Residual norm 4.432969221500e-07
      6 KSP Residual norm 7.368980834511e-08
      7 KSP Residual norm 1.931444058250e-08
      8 KSP Residual norm 3.568614645931e-09
 FirstNewton = 0
 FirstNewton = 0
    2 SNES Function norm 6.928122087929e-05
NORM2F: 6.928122e-05 NORM2F/NORM2F0: 2.496312e-04
NORM2dof0: 4.394462e-05 NORM2dof0/NORM2dof00: 1.583421e-04
NORM2dof1: 3.220739e-05 NORM2dof1/NORM2dof10: 3.501917e-02
NORM2dof2: 4.279535e-05 NORM2dof2/NORM2dof20: 3.191017e-02
NORM2dof3: 3.501366e-09 NORM2dof3/NORM2dof30: 8.668639e-01
isolid: 0 NORM2S: 9.097217e-12 NORM2S/NORM2S0: 1.236061e-02
      0 KSP Residual norm 6.928122087929e-05
      1 KSP Residual norm 5.796650034384e-05
      2 KSP Residual norm 5.822934982617e-06
      3 KSP Residual norm 8.504018160118e-07
      4 KSP Residual norm 3.473419243295e-07
      5 KSP Residual norm 1.254797217550e-08
      6 KSP Residual norm 4.397946011480e-09
 FirstNewton = 0
 FirstNewton = 0
    3 SNES Function norm 9.057240589981e-06
NORM2F: 9.057241e-06 NORM2F/NORM2F0: 3.263466e-05
NORM2dof0: 6.675267e-06 NORM2dof0/NORM2dof00: 2.405245e-05
NORM2dof1: 3.733159e-06 NORM2dof1/NORM2dof10: 4.059072e-03
NORM2dof2: 4.851589e-06 NORM2dof2/NORM2dof20: 3.617566e-03
NORM2dof3: 4.459935e-09 NORM2dof3/NORM2dof30: 1.104185e+00
isolid: 0 NORM2S: 1.000563e-12 NORM2S/NORM2S0: 1.359490e-03
      0 KSP Residual norm 9.057240589981e-06
      1 KSP Residual norm 7.848573259684e-06
      2 KSP Residual norm 1.415531009310e-06
      3 KSP Residual norm 2.090477216219e-07
      4 KSP Residual norm 8.778616371171e-08
      5 KSP Residual norm 3.917243258697e-09
 FirstNewton = 0
 FirstNewton = 0
    4 SNES Function norm 1.128990046196e-06
NORM2F: 1.128990e-06 NORM2F/NORM2F0: 4.067929e-06
NORM2dof0: 8.085753e-07 NORM2dof0/NORM2dof00: 2.913474e-06
NORM2dof1: 4.836531e-07 NORM2dof1/NORM2dof10: 5.258771e-04
NORM2dof2: 6.220040e-07 NORM2dof2/NORM2dof20: 4.637946e-04
NORM2dof3: 3.887829e-09 NORM2dof3/NORM2dof30: 9.625438e-01
isolid: 0 NORM2S: 1.103398e-13 NORM2S/NORM2S0: 1.499214e-04
8 TS dt 0.0001 time 0.0008
 FirstNewton = 0
    0 SNES Function norm 1.385849581340e-01
NORM2F: 1.385850e-01 NORM2F/NORM2F0: 1.000000e+00
NORM2dof0: 1.385776e-01 NORM2dof0/NORM2dof00: 1.000000e+00
NORM2dof1: 8.010985e-04 NORM2dof1/NORM2dof10: 1.000000e+00
NORM2dof2: 1.183445e-03 NORM2dof2/NORM2dof20: 1.000000e+00
NORM2dof3: 4.108561e-09 NORM2dof3/NORM2dof30: 1.000000e+00
isolid: 0 NORM2S: 7.401836e-10 NORM2S/NORM2S0: 1.000000e+00
 Tangent
       0 KSP Residual norm 1.385849581340e-01
      1 KSP Residual norm 3.795277329624e-03
      2 KSP Residual norm 3.620738698674e-04
      3 KSP Residual norm 5.684093723273e-05
      4 KSP Residual norm 2.107087522506e-05
      5 KSP Residual norm 8.654267157263e-07
      6 KSP Residual norm 2.119521401284e-07
      7 KSP Residual norm 5.288058582681e-08
      8 KSP Residual norm 7.166323508088e-09
 FirstNewton = 0
 FirstNewton = 0
    1 SNES Function norm 7.436038015632e-04
NORM2F: 7.436038e-04 NORM2F/NORM2F0: 5.365689e-03
NORM2dof0: 4.954851e-04 NORM2dof0/NORM2dof00: 3.575507e-03
NORM2dof1: 3.102044e-04 NORM2dof1/NORM2dof10: 3.872237e-01
NORM2dof2: 4.595806e-04 NORM2dof2/NORM2dof20: 3.883413e-01
NORM2dof3: 6.972809e-09 NORM2dof3/NORM2dof30: 1.697141e+00
isolid: 0 NORM2S: 8.136219e-11 NORM2S/NORM2S0: 1.099216e-01
      0 KSP Residual norm 7.436038015632e-04
      1 KSP Residual norm 6.662293245257e-04
      2 KSP Residual norm 1.413956125033e-04
      3 KSP Residual norm 2.108582723653e-05
      4 KSP Residual norm 8.858941280713e-06
      5 KSP Residual norm 3.654990999848e-07
      6 KSP Residual norm 9.586321175573e-08
      7 KSP Residual norm 2.762663610396e-08
      8 KSP Residual norm 3.998792805484e-09
 FirstNewton = 0
 FirstNewton = 0
    2 SNES Function norm 6.401830454268e-05
NORM2F: 6.401830e-05 NORM2F/NORM2F0: 4.619427e-04
NORM2dof0: 4.448204e-05 NORM2dof0/NORM2dof00: 3.209901e-04
NORM2dof1: 2.897829e-05 NORM2dof1/NORM2dof10: 3.617319e-02
NORM2dof2: 3.577640e-05 NORM2dof2/NORM2dof20: 3.023072e-02
NORM2dof3: 3.731667e-09 NORM2dof3/NORM2dof30: 9.082661e-01
isolid: 0 NORM2S: 8.919674e-12 NORM2S/NORM2S0: 1.205062e-02
      0 KSP Residual norm 6.401830454268e-05
      1 KSP Residual norm 5.313000718007e-05
      2 KSP Residual norm 4.667333074756e-06
      3 KSP Residual norm 7.091731589709e-07
      4 KSP Residual norm 2.703713228598e-07
      5 KSP Residual norm 1.059749901104e-08
      6 KSP Residual norm 3.193872235940e-09
 FirstNewton = 0
 FirstNewton = 0
    3 SNES Function norm 9.295793273187e-06
NORM2F: 9.295793e-06 NORM2F/NORM2F0: 6.707650e-05
NORM2dof0: 6.778351e-06 NORM2dof0/NORM2dof00: 4.891376e-05
NORM2dof1: 3.880551e-06 NORM2dof1/NORM2dof10: 4.844037e-03
NORM2dof2: 5.040540e-06 NORM2dof2/NORM2dof20: 4.259209e-03
NORM2dof3: 3.225597e-09 NORM2dof3/NORM2dof30: 7.850916e-01
isolid: 0 NORM2S: 9.832155e-13 NORM2S/NORM2S0: 1.328340e-03
      0 KSP Residual norm 9.295793273187e-06
      1 KSP Residual norm 8.122103991633e-06
      2 KSP Residual norm 1.448552073625e-06
      3 KSP Residual norm 2.236736711700e-07
      4 KSP Residual norm 9.711651165709e-08
      5 KSP Residual norm 4.059417366128e-09
 FirstNewton = 0
 FirstNewton = 0
    4 SNES Function norm 1.145371023432e-06
NORM2F: 1.145371e-06 NORM2F/NORM2F0: 8.264757e-06
NORM2dof0: 8.001733e-07 NORM2dof0/NORM2dof00: 5.774190e-06
NORM2dof1: 4.949525e-07 NORM2dof1/NORM2dof10: 6.178422e-04
NORM2dof2: 6.531490e-07 NORM2dof2/NORM2dof20: 5.519047e-04
NORM2dof3: 3.992162e-09 NORM2dof3/NORM2dof30: 9.716691e-01
isolid: 0 NORM2S: 1.082875e-13 NORM2S/NORM2S0: 1.462982e-04
9 TS dt 0.0001 time 0.0009
 FirstNewton = 0
    0 SNES Function norm 6.920543911323e-02
NORM2F: 6.920544e-02 NORM2F/NORM2F0: 1.000000e+00
NORM2dof0: 6.919171e-02 NORM2dof0/NORM2dof00: 1.000000e+00
NORM2dof1: 7.826959e-04 NORM2dof1/NORM2dof10: 1.000000e+00
NORM2dof2: 1.134674e-03 NORM2dof2/NORM2dof20: 1.000000e+00
NORM2dof3: 4.044615e-09 NORM2dof3/NORM2dof30: 1.000000e+00
isolid: 0 NORM2S: 7.352641e-10 NORM2S/NORM2S0: 1.000000e+00
 Tangent
       0 KSP Residual norm 6.920543911323e-02
      1 KSP Residual norm 3.838256459620e-03
      2 KSP Residual norm 3.510324160726e-04
      3 KSP Residual norm 5.431659267182e-05
      4 KSP Residual norm 2.278975999573e-05
      5 KSP Residual norm 9.811155532599e-07
      6 KSP Residual norm 2.283277281734e-07
      7 KSP Residual norm 6.419176632026e-08
      8 KSP Residual norm 9.712248434270e-09
 FirstNewton = 0
 FirstNewton = 0
    1 SNES Function norm 7.543897594395e-04
NORM2F: 7.543898e-04 NORM2F/NORM2F0: 1.090073e-02
NORM2dof0: 5.111752e-04 NORM2dof0/NORM2dof00: 7.387810e-03
NORM2dof1: 3.164793e-04 NORM2dof1/NORM2dof10: 4.043452e-01
NORM2dof2: 4.556804e-04 NORM2dof2/NORM2dof20: 4.015958e-01
NORM2dof3: 9.463672e-09 NORM2dof3/NORM2dof30: 2.339820e+00
isolid: 0 NORM2S: 8.159367e-11 NORM2S/NORM2S0: 1.109719e-01
      0 KSP Residual norm 7.543897594395e-04
      1 KSP Residual norm 6.779421207165e-04
      2 KSP Residual norm 1.389710000060e-04
      3 KSP Residual norm 2.154186771758e-05
      4 KSP Residual norm 9.288592492057e-06
      5 KSP Residual norm 3.637246988448e-07
      6 KSP Residual norm 1.189806558533e-07
      7 KSP Residual norm 3.446205571478e-08
      8 KSP Residual norm 4.261989924471e-09
 FirstNewton = 0
 FirstNewton = 0
    2 SNES Function norm 6.335607148875e-05
NORM2F: 6.335607e-05 NORM2F/NORM2F0: 9.154782e-04
NORM2dof0: 4.386965e-05 NORM2dof0/NORM2dof00: 6.340304e-04
NORM2dof1: 2.808424e-05 NORM2dof1/NORM2dof10: 3.588141e-02
NORM2dof2: 3.606552e-05 NORM2dof2/NORM2dof20: 3.178491e-02
NORM2dof3: 3.835533e-09 NORM2dof3/NORM2dof30: 9.483059e-01
isolid: 0 NORM2S: 8.941439e-12 NORM2S/NORM2S0: 1.216085e-02
      0 KSP Residual norm 6.335607148875e-05
      1 KSP Residual norm 5.260333974931e-05
      2 KSP Residual norm 4.526058539996e-06
      3 KSP Residual norm 7.065769231872e-07
      4 KSP Residual norm 2.656748864253e-07
      5 KSP Residual norm 1.055820588803e-08
      6 KSP Residual norm 2.914593642662e-09
 FirstNewton = 0
 FirstNewton = 0
    3 SNES Function norm 9.501611098620e-06
NORM2F: 9.501611e-06 NORM2F/NORM2F0: 1.372957e-04
NORM2dof0: 6.864630e-06 NORM2dof0/NORM2dof00: 9.921175e-05
NORM2dof1: 4.064798e-06 NORM2dof1/NORM2dof10: 5.193330e-03
NORM2dof2: 5.160898e-06 NORM2dof2/NORM2dof20: 4.548352e-03
NORM2dof3: 2.921009e-09 NORM2dof3/NORM2dof30: 7.221970e-01
isolid: 0 NORM2S: 9.863644e-13 NORM2S/NORM2S0: 1.341510e-03
      0 KSP Residual norm 9.501611098620e-06
      1 KSP Residual norm 8.379522147750e-06
      2 KSP Residual norm 1.468612165223e-06
      3 KSP Residual norm 2.384601373074e-07
      4 KSP Residual norm 1.034426483411e-07
      5 KSP Residual norm 4.383898257933e-09
 FirstNewton = 0
 FirstNewton = 0
    4 SNES Function norm 1.119356548797e-06
NORM2F: 1.119357e-06 NORM2F/NORM2F0: 1.617440e-05
NORM2dof0: 8.229122e-07 NORM2dof0/NORM2dof00: 1.189322e-05
NORM2dof1: 4.832121e-07 NORM2dof1/NORM2dof10: 6.173689e-04
NORM2dof2: 5.850318e-07 NORM2dof2/NORM2dof20: 5.155945e-04
NORM2dof3: 4.296044e-09 NORM2dof3/NORM2dof30: 1.062164e+00
isolid: 0 NORM2S: 1.085892e-13 NORM2S/NORM2S0: 1.476873e-04
10 TS dt 0.0001 time 0.001
TS Object: 2 MPI processes
  type: alpha1
  maximum steps=10
  maximum time=5000.
  total number of nonlinear solver iterations=36
  total number of nonlinear solve failures=0
  total number of linear solver iterations=258
  total number of rejected steps=0
    Alpha_m=0.833333, Alpha_f=0.666667, Gamma=0.666667
  TSAdapt Object:   2 MPI processes
    type: none
    number of candidates 0
  SNES Object:   2 MPI processes
    type: newtonls
    maximum iterations=150, maximum function evaluations=10000
    tolerances: relative=0.001, absolute=1e-50, solution=1e-08
    total number of linear solver iterations=27
    total number of function evaluations=9
    norm schedule ALWAYS
    Jacobian is rebuilt every 20 SNES iterations
    SNESLineSearch Object:     2 MPI processes
      type: cp
      maxstep=1.000000e+08, minlambda=1.000000e-12
      tolerances: relative=1.000000e-08, absolute=1.000000e-15, lambda=1.000000e-08
    KSP Object:     2 MPI processes
      type: fgmres
        GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
        GMRES: happy breakdown tolerance 1e-30
      maximum iterations=10000, initial guess is zero
      tolerances:  relative=0., absolute=1e-08, divergence=10000.
      right preconditioning
      using UNPRECONDITIONED norm type for convergence test
    PC Object:     2 MPI processes
      type: fieldsplit
        FieldSplit with Schur preconditioner, factorization UPPER
        Preconditioner for the Schur complement formed from user provided matrix
        Split info:
        Split number 0 Defined by IS
        Split number 1 Defined by IS
        KSP solver for A00 block
          KSP Object:          (fieldsplit_m_)           2 MPI processes
            type: fgmres
            maximum iterations=5, initial guess is zero
            tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
            using NONE norm type for convergence test
          PC Object:          (fieldsplit_m_)           2 MPI processes
            type: bjacobi
              block Jacobi: number of blocks = 2
              Local solve is same for all blocks, in the following KSP and PC objects:
            KSP Object:            (fieldsplit_m_sub_)             1 MPI processes
              type: preonly
              left preconditioning
            PC Object:            (fieldsplit_m_sub_)             1 MPI processes
              type: ilu
                ILU: out-of-place factorization
                0 levels of fill
                tolerance for zero pivot 2.22045e-14
                matrix ordering: natural
                factor fill ratio given 1., needed 1.
                  Factored matrix follows:
                    Mat Object:                     1 MPI processes
                      type: seqaij
                      rows=12000, cols=12000
                      package used to perform factorization: petsc
                      total: nonzeros=5527200, allocated nonzeros=5527200
                      total number of mallocs used during MatSetValues calls =0
                        not using I-node routines
              linear system matrix = precond matrix:
              Mat Object:              (fieldsplit_m_)               1 MPI processes
                type: seqaij
            Mat Object:            (fieldsplit_m_)             2 MPI processes
              type: mpiaij
              rows=26800, cols=26800
              total: nonzeros=13445200, allocated nonzeros=13445200
                not using I-node (on process 0) routines
        KSP solver for S = A11 - A10 inv(A00) A01
          KSP Object:          (fieldsplit_p_)           2 MPI processes
            type: preonly
          PC Object:          (fieldsplit_p_)           2 MPI processes
            type: ksp
            KSP and PC on KSP preconditioner follow
              KSP Object:              (fieldsplit_p_ksp_)               2 MPI processes
                type: cg
              PC Object:              (fieldsplit_p_ksp_)               2 MPI processes
                type: bjacobi
                KSP Object:                (fieldsplit_p_ksp_sub_)                 1 MPI processes
                  type: preonly
                PC Object:                (fieldsplit_p_ksp_sub_)                 1 MPI processes
                  type: ilu
                    0 levels of fill
                          type: seqaij
                          rows=4000, cols=4000
                          total: nonzeros=440000, allocated nonzeros=440000
                    type: seqaij
                Mat Object:                 2 MPI processes
                  type: mpiaij
                  rows=8800, cols=8800
                  total: nonzeros=1040000, allocated nonzeros=1040000
            linear system matrix followed by preconditioner matrix:
            Mat Object:            (fieldsplit_p_)             2 MPI processes
              type: schurcomplement
                Schur complement A11 - A10 inv(A00) A01
                A11
                    type: mpiaij
                A10
                    type: mpiaij
                    rows=8800, cols=26800
                    total: nonzeros=3756000, allocated nonzeros=3756000
                KSP of A00
                    type: fgmres
                    type: bjacobi
                      type: preonly
                      type: ilu
                        0 levels of fill
                              type: seqaij
                        type: seqaij
                      type: mpiaij
                A01
                    type: mpiaij
                    rows=26800, cols=8800
              type: mpiaij
        type: mpiaij
        rows=35600, cols=35600
        total: nonzeros=21997200, allocated nonzeros=21997200
solve: ndof=    35600 time= 4.885358e+02 time/ndof= 1.372292e-02
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./fsisurface on a optimO3fftw named ubuntu with 2 processors, by hcasquer Mon Apr 30 12:03:20 2018
Using Petsc Release Version 3.7.6, unknown
                         Max       Max/Min        Avg      Total
Time (sec):           5.359e+02      1.00000   5.359e+02
Objects:              2.952e+03      2.77183   2.008e+03
Flops:                1.138e+11      1.04041   1.116e+11  2.232e+11
Flops/sec:            2.123e+08      1.04041   2.082e+08  4.164e+08
MPI Messages:         4.924e+03      1.00000   4.924e+03  9.849e+03
MPI Message Lengths:  1.353e+09      1.00009   2.748e+05  2.707e+09
MPI Reductions:       1.169e+04      1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 5.3588e+02 100.0%  2.2317e+11 100.0%  9.849e+03 100.0%  2.748e+05      100.0%  1.169e+04 100.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
IGAFormScalar         11 1.0 4.9933e+00 1.0 4.75e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     2
IGAFormSystem          1 1.0 4.5438e-01 1.0 1.63e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   719
IGAFormIFunction      82 1.0 1.0503e+02 1.0 2.47e+09 1.0 0.0e+00 0.0e+00 0.0e+00 20  2  0  0  0  20  2  0  0  0    47
IGAFormIJacobian      10 1.0 2.3141e+02 1.0 4.07e+10 1.0 0.0e+00 0.0e+00 0.0e+00 43 36  0  0  0  43 36  0  0  0   352
VecView               48 1.0 9.8464e-03 1.0 0.00e+00 0.0 4.8e+01 4.8e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecDot                72 1.0 1.0435e-02 1.3 2.82e+06 1.2 0.0e+00 0.0e+00 7.2e+01  0  0  0  0  1   0  0  0  0  1   491
VecMDot             2115 1.4 5.3507e+0020.7 1.59e+08 1.0 0.0e+00 0.0e+00 1.5e+03  1  0  0  0 13   1  0  0  0 13    59
VecTDot             2595 1.0 6.2390e-01 2.0 2.49e+07 1.2 0.0e+00 0.0e+00 2.6e+03  0  0  0  0 22   0  0  0  0 22    73
VecNorm             2744 1.3 2.4158e+00 9.4 5.97e+07 1.0 0.0e+00 0.0e+00 2.0e+03  0  0  0  0 18   0  0  0  0 18    49
VecScale            2830 1.3 1.3459e-02 1.1 3.41e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4916
VecCopy             1061 1.1 9.5375e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet              5711 1.5 4.3843e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY             3226 1.1 1.3904e-02 1.0 4.17e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  5637
VecAYPX             1203 1.0 4.1418e-03 1.2 1.64e+07 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  7234
VecAXPBYCZ           348 0.0 2.4459e-03 0.0 7.61e+06 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3110
VecWAXPY             339 1.4 6.9184e-03 1.2 4.82e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1357
VecMAXPY            2490 1.4 4.6477e-02 1.0 2.06e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  8866
VecAssemblyBegin    1550 1.1 2.4032e+0121.3 0.00e+00 0.0 1.6e+03 5.3e+05 4.4e+03  2  0 17 32 38   2  0 17 32 38     0
VecAssemblyEnd      1550 1.1 1.5775e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecLoad                1 1.0 1.1816e-03 1.0 0.00e+00 0.0 1.0e+00 1.9e+05 3.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin     5747 1.0 1.4383e-01 1.1 0.00e+00 0.0 7.9e+03 6.3e+04 0.0e+00  0  0 80 18  0   0  0 80 18  0     0
VecScatterEnd       5747 1.0 2.1346e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecReduceArith       108 1.0 3.1109e-03 1.2 4.23e+06 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2472
VecReduceComm         36 1.0 6.4516e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 3.6e+01  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         649 0.0 6.2337e-03 0.0 1.31e+07 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2109
MatMult             3670 1.2 1.7203e+01 1.2 2.81e+10 1.2 6.2e+03 1.7e+04 0.0e+00  3 23 63  4  0   3 23 63  4  0  3007
MatSolve            3238 1.3 1.1799e+01 1.2 1.95e+10 1.2 0.0e+00 0.0e+00 0.0e+00  2 16  0  0  0   2 16  0  0  0  3064
MatLUFactorNum        94 7.8 9.6308e+00 1.0 2.52e+10 1.1 0.0e+00 0.0e+00 0.0e+00  2 21  0  0  0   2 21  0  0  0  4939
MatILUFactorSym       8528.3 7.0743e-02 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               1 1.0 5.5289e-04 1.2 5.70e+05 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1881
MatAssemblyBegin     361 1.3 6.0246e+0027.3 0.00e+00 0.0 3.3e+01 4.0e+07 1.5e+02  1  0  0 49  1   1  0  0 49  1     0
MatAssemblyEnd       361 1.3 4.1197e+00 5.3 0.00e+00 0.0 9.2e+01 2.4e+03 1.8e+02  0  0  1  0  2   0  0  1  0  2     0
MatGetRow         249600 1.2 3.2938e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ           8528.3 1.5736e-0516.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix       44 1.0 1.3199e+01 1.0 0.00e+00 0.0 1.6e+01 3.8e+03 1.9e+02  2  0  0  0  2   2  0  0  0  2     0
MatGetOrdering        8528.3 1.4243e-0310.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatZeroEntries       133 2.6 4.8704e-01 4.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatView                9 1.8 2.1822e-03 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPGMRESOrthog      2115 1.4 5.3908e+0018.3 3.18e+08 1.0 0.0e+00 0.0e+00 1.5e+03  1  0  0  0 13   1  0  0  0 13   118
KSPSetUp             152 2.2 2.5470e-03 4.8 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve             119 3.2 5.6646e+01 1.1 7.04e+10 1.1 6.2e+03 1.7e+04 6.2e+03 10 61 63  4 53  10 61 63  4 53  2409
PCSetUp              117 3.3 2.5130e+01 1.1 2.52e+10 1.1 2.4e+01 1.4e+04 2.8e+02  4 21  0  0  2   4 21  0  0  2  1893
PCSetUpOnBlocks      517 1.0 9.6650e+00 1.3 2.23e+10 1.3 0.0e+00 0.0e+00 0.0e+00  2 18  0  0  0   2 18  0  0  0  4067
PCApply              920 3.4 3.5882e+01 1.0 6.40e+10 1.2 5.7e+03 1.5e+04 5.4e+03  7 52 58  3 46   7 52 58  3 46  3216
KSPSolve_FS_0        258 1.0 3.2824e+01 1.0 6.00e+10 1.3 2.6e+03 2.6e+04 2.8e+03  6 48 26  2 24   6 48 26  2 24  3254
KSPSolve_FS_Schu     258 1.0 2.1657e+00 1.0 2.93e+09 1.2 2.6e+03 6.4e+03 2.6e+03  0  2 26  1 22   0  2 26  1 22  2464
TSStep                10 1.0 4.7033e+02 1.0 1.14e+11 1.0 9.4e+03 2.9e+05 1.1e+04 88100 96100 93  88100 96100 93   474
TSFunctionEval        82 1.0 1.8310e+02 1.0 1.32e+10 5.3 3.1e+03 4.1e+05 3.8e+03 34  7 32 47 32  34  7 32 47 32    86
TSJacobianEval        10 1.0 2.3556e+02 1.0 4.07e+10 1.0 1.1e+02 1.2e+07 2.0e+01 44 36  1 49  0  44 36  1 49  0   345
SNESSolve             10 1.0 4.7033e+02 1.0 1.14e+11 1.0 9.4e+03 2.9e+05 1.1e+04 88100 96100 93  88100 96100 93   474
SNESFunctionEval      82 1.0 1.8311e+02 1.0 1.32e+10 5.3 3.1e+03 4.1e+05 3.8e+03 34  7 32 47 32  34  7 32 47 32    86
SNESJacobianEval      10 1.0 2.3556e+02 1.0 4.07e+10 1.0 1.1e+02 1.2e+07 2.0e+01 44 36  1 49  0  44 36  1 49  0   345
SNESLineSearch        36 1.0 1.6004e+02 1.0 1.16e+10 5.3 2.7e+03 4.1e+05 3.4e+03 30  6 28 41 29  30  6 28 41 29    86
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
                 IGA     5              5         6200     0.
                IGAM     2              2         4640     0.
              Viewer    58             56        45744     0.
              Vector  1569           1555     88469584     0.
      Vector Scatter    48             47      1086224     0.
           Index Set   397            397      3577968     0.
   IS L to G Mapping   314            311      7887424     0.
   Application Order     6              6       224176     0.
              Matrix   321            320   1247373260     0.
    Distributed Mesh    10             10        45896     0.
Star Forest Bipartite Graph    20             20        15840     0.
     Discrete System    10             10         8640     0.
       Krylov Solver    92             92      1556536     0.
     DMKSP interface     1              1          648     0.
      Preconditioner    92             92        91336     0.
             TSAdapt     1              1         1216     0.
                  TS     1              1         1840     0.
                DMTS     1              1          736     0.
                SNES     1              1         1332     0.
      SNESLineSearch     1              1          992     0.
              DMSNES     2              2         1328     0.
Average time to get PetscTime(): 2.38419e-08
Average time for MPI_Barrier(): 5.19753e-05
Average time for zero size MPI_Send(): 2.11e-05
#PETSc Option Table entries:
-fieldsplit_m_ksp_convergence_test skip
-fieldsplit_m_ksp_max_it 5
-fieldsplit_m_ksp_norm_type none
-fieldsplit_m_ksp_type fgmres
-fieldsplit_m_pc_type bjacobi
-fieldsplit_m_sub_ksp_type preonly
-fieldsplit_m_sub_pc_factor_levels 0
-fieldsplit_m_sub_pc_type ilu
-fieldsplit_p_ksp_ksp_convergence_test skip
-fieldsplit_p_ksp_ksp_max_it 5
-fieldsplit_p_ksp_ksp_norm_type none
-fieldsplit_p_ksp_ksp_type cg
-fieldsplit_p_ksp_pc_type bjacobi
-fieldsplit_p_ksp_type preonly
-fieldsplit_p_pc_type ksp
-geo_iga_load em3d_geo.dat
-geo_iga_order 2
-geo_iga_periodic 1,1,0
-geo_iga_quadrature 3,3,3
-iga_view
-igam_view
-ksp_atol 1e-8
-ksp_converged_reason
-ksp_monitor
-ksp_norm_type unpreconditioned
-ksp_rtol 0.0
-ksp_type fgmres
-log_view
-p_iga_load em3d_p.dat
-p_iga_order 1
-p_iga_periodic 1,1,0
-p_iga_quadrature 3,3,3
-pc_fieldsplit_schur_fact_type upper
-pc_fieldsplit_schur_precondition user
-pc_fieldsplit_type schur
-pc_type fieldsplit
-press_ksp_rtol 1e-10
-snes_converged_reason
-snes_lag_jacobian 20
-snes_max_it 150
-snes_monitor
-snes_rtol 1e-3
-ts_max_snes_failures 20000
-ts_monitor
-ts_view
-u_iga_load em3d_u.dat
-u_iga_order 1
-u_iga_periodic 1,1,0
-u_iga_quadrature 3,3,3
-v_iga_load em3d_v.dat
-v_iga_order 1
-v_iga_periodic 1,1,0
-v_iga_quadrature 3,3,3
-w_iga_load em3d_w.dat
-w_iga_order 1
-w_iga_periodic 1,1,0
-w_iga_quadrature 3,3,3
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --with-cc=gcc --with-fc=gfortran --download-fblaslapack --download-mpich --with-debugging=0 COPTFLAGS=-O3 FOPTFLAGS=-O3 CXXOPTFLAGS=-O3 PETSC_ARCH=optimO3fftw --download-mumps --download-hypre --download-scalapack --download-parmetis --download-metis --download-fftw --download-cmake
Libraries compiled on Thu Feb 22 11:36:47 2018 on ubuntu
Machine characteristics: Linux-4.13.0-32-generic-x86_64-with-Ubuntu-16.04-xenial
Using PETSc directory: /home/hcasquer/petsc-3.7.6
Using PETSc arch: optimO3fftw
Using C compiler: /home/hcasquer/petsc-3.7.6/optimO3fftw/bin/mpicc    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /home/hcasquer/petsc-3.7.6/optimO3fftw/bin/mpif90    -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3  ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/home/hcasquer/petsc-3.7.6/optimO3fftw/include -I/home/hcasquer/petsc-3.7.6/include -I/home/hcasquer/petsc-3.7.6/include -I/home/hcasquer/petsc-3.7.6/optimO3fftw/include
Using C linker: /home/hcasquer/petsc-3.7.6/optimO3fftw/bin/mpicc
Using Fortran linker: /home/hcasquer/petsc-3.7.6/optimO3fftw/bin/mpif90
Using libraries: -Wl,-rpath,/home/hcasquer/petsc-3.7.6/optimO3fftw/lib -L/home/hcasquer/petsc-3.7.6/optimO3fftw/lib -lpetsc -Wl,-rpath,/home/hcasquer/petsc-3.7.6/optimO3fftw/lib -L/home/hcasquer/petsc-3.7.6/optimO3fftw/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/5 -L/usr/lib/gcc/x86_64-linux-gnu/5 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lpthread -lparmetis -lmetis -lfftw3_mpi -lfftw3 -lHYPRE -lmpicxx -lstdc++ -lm -lscalapack -lflapack -lfblas -lpthread -lm -lmpifort -lgfortran -lm -lgfortran -lm -lquadmath -lmpicxx -lstdc++ -lm -ldl -lmpi -lgcc_s -ldl
muS = 2.000000e-03
cS = 5.000000e+00
 FirstNewton = 0
 Tangent
      4 KSP Residual norm 8.855948174614e-05
      6 KSP Residual norm 3.967355444540e-06
      8 KSP Residual norm 2.483423008400e-07
      9 KSP Residual norm 6.132481698670e-08
     10 KSP Residual norm 9.689659346506e-09
 FirstNewton = 0
 FirstNewton = 0
NORM2dof3: 8.833763e-09 NORM2dof3/NORM2dof30: inf
 FirstNewton = 0
 Tangent
      2 KSP Residual norm 3.604517028340e-03
      8 KSP Residual norm 2.412824487049e-07
      9 KSP Residual norm 9.323085453447e-08
     10 KSP Residual norm 2.206166844090e-08
     11 KSP Residual norm 4.267397332757e-09
 FirstNewton = 0
 FirstNewton = 0
    1 SNES Function norm 2.844794057914e-03
      0 KSP Residual norm 2.844794057914e-03
      1 KSP Residual norm 2.295043475140e-03
      2 KSP Residual norm 1.583104677397e-04
      3 KSP Residual norm 1.490919842249e-05
      4 KSP Residual norm 1.548465044314e-06
      5 KSP Residual norm 2.640015039882e-07
      6 KSP Residual norm 4.322481936505e-08
      7 KSP Residual norm 1.473218623930e-08
      8 KSP Residual norm 2.888610560303e-09
 FirstNewton = 0
 FirstNewton = 0
    2 SNES Function norm 1.254901830764e-04
      0 KSP Residual norm 1.254901830764e-04
      1 KSP Residual norm 1.003678752319e-04
      2 KSP Residual norm 1.193320199662e-05
      3 KSP Residual norm 5.187856997250e-07
      4 KSP Residual norm 6.216090456497e-08
      5 KSP Residual norm 1.241994457162e-08
      6 KSP Residual norm 3.149627739638e-09
 FirstNewton = 0
 FirstNewton = 0
    3 SNES Function norm 8.107335727411e-06
 FirstNewton = 0
 Tangent
      1 KSP Residual norm 6.607063311337e-03
      2 KSP Residual norm 3.141865121249e-04
      3 KSP Residual norm 6.120575062793e-05
      4 KSP Residual norm 9.242740946536e-06
      5 KSP Residual norm 1.330632161204e-06
      6 KSP Residual norm 5.727762329871e-07
      7 KSP Residual norm 9.569604813401e-08
      8 KSP Residual norm 2.510214585840e-08
      9 KSP Residual norm 5.482441703249e-09
 FirstNewton = 0
 FirstNewton = 0
    1 SNES Function norm 3.845740765509e-03
      0 KSP Residual norm 3.845740765509e-03
      1 KSP Residual norm 3.268192036308e-03
      2 KSP Residual norm 4.485759584749e-04
      3 KSP Residual norm 5.155662226310e-05
      4 KSP Residual norm 4.845743277427e-06
      5 KSP Residual norm 1.439807997833e-06
      6 KSP Residual norm 1.043760500879e-07
      7 KSP Residual norm 3.976004664735e-08
      8 KSP Residual norm 7.196889052151e-09
 FirstNewton = 0
 FirstNewton = 0
    2 SNES Function norm 1.523034956682e-04
      0 KSP Residual norm 1.523034956682e-04
      1 KSP Residual norm 1.193197002186e-04
      2 KSP Residual norm 1.286757063887e-05
      3 KSP Residual norm 1.947459077245e-06
      4 KSP Residual norm 5.526459923945e-07
      5 KSP Residual norm 5.326425072565e-08
      6 KSP Residual norm 4.721859648580e-09
 FirstNewton = 0
 FirstNewton = 0
    3 SNES Function norm 1.411908637477e-05
      0 KSP Residual norm 1.411908637477e-05
      1 KSP Residual norm 1.147024084989e-05
      2 KSP Residual norm 1.642505389042e-06
      3 KSP Residual norm 9.393394019526e-08
      4 KSP Residual norm 3.802608124054e-08
      5 KSP Residual norm 3.488335294398e-09
    4 SNES Function norm 1.411908637477e-05
    5 SNES Function norm 1.411908637477e-05
    6 SNES Function norm 1.411908637477e-05
    7 SNES Function norm 1.411908637477e-05
    8 SNES Function norm 1.411908637477e-05
    9 SNES Function norm 1.411908637477e-05
   10 SNES Function norm 1.411908637477e-05
   11 SNES Function norm 1.411908637477e-05
   12 SNES Function norm 1.411908637477e-05
   13 SNES Function norm 1.411908637477e-05
   14 SNES Function norm 1.411908637477e-05
   15 SNES Function norm 1.411908637477e-05
   16 SNES Function norm 1.411908637477e-05
   17 SNES Function norm 1.411908637477e-05
   18 SNES Function norm 1.411908637477e-05
   19 SNES Function norm 1.411908637477e-05
   20 SNES Function norm 1.411908637477e-05
 Tangent
      1 KSP Residual norm 1.147023578592e-05
      2 KSP Residual norm 1.642507630910e-06
      3 KSP Residual norm 9.393490366608e-08
      4 KSP Residual norm 3.802566188907e-08
      5 KSP Residual norm 3.488598835081e-09
   21 SNES Function norm 1.411908637477e-05
   22 SNES Function norm 1.411908637477e-05
   23 SNES Function norm 1.411908637477e-05
   24 SNES Function norm 1.411908637477e-05
   25 SNES Function norm 1.411908637477e-05
   26 SNES Function norm 1.411908637477e-05
   27 SNES Function norm 1.411908637477e-05
   28 SNES Function norm 1.411908637477e-05
   29 SNES Function norm 1.411908637477e-05
   30 SNES Function norm 1.411908637477e-05
   31 SNES Function norm 1.411908637477e-05
   32 SNES Function norm 1.411908637477e-05
   33 SNES Function norm 1.411908637477e-05
   34 SNES Function norm 1.411908637477e-05
   35 SNES Function norm 1.411908637477e-05
   36 SNES Function norm 1.411908637477e-05
   37 SNES Function norm 1.411908637477e-05
   38 SNES Function norm 1.411908637477e-05
   39 SNES Function norm 1.411908637477e-05
   40 SNES Function norm 1.411908637477e-05
 Tangent
   41 SNES Function norm 1.411908637477e-05
   42 SNES Function norm 1.411908637477e-05
   43 SNES Function norm 1.411908637477e-05
   44 SNES Function norm 1.411908637477e-05
   45 SNES Function norm 1.411908637477e-05
   46 SNES Function norm 1.411908637477e-05
   47 SNES Function norm 1.411908637477e-05
   48 SNES Function norm 1.411908637477e-05
   49 SNES Function norm 1.411908637477e-05
   50 SNES Function norm 1.411908637477e-05
  Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 50
 FirstNewton = 0
    0 SNES Function norm 4.459023374308e+00
NORM2dof1: 4.578319e-03 NORM2dof1/NORM2dof10: 1.000000e+00
NORM2dof2: 5.151374e-03 NORM2dof2/NORM2dof20: 1.000000e+00
NORM2dof3: 8.168056e-09 NORM2dof3/NORM2dof30: 1.000000e+00
isolid: 0 NORM2S: 7.330777e-10 NORM2S/NORM2S0: 1.000000e+00
 Tangent
       0 KSP Residual norm 4.459023374308e+00
      1 KSP Residual norm 1.550613487152e-02
      2 KSP Residual norm 1.183783138283e-03
      3 KSP Residual norm 2.267886395266e-04
      4 KSP Residual norm 2.353995026891e-05
      5 KSP Residual norm 6.835200755683e-06
      6 KSP Residual norm 1.321943427943e-06
      7 KSP Residual norm 6.109725800169e-07
      8 KSP Residual norm 6.446081981328e-08
      9 KSP Residual norm 2.632010042493e-08
     10 KSP Residual norm 4.920689591102e-09
 FirstNewton = 0
 FirstNewton = 0
    1 SNES Function norm 1.236926864027e-03
NORM2F: 1.236927e-03 NORM2F/NORM2F0: 2.773986e-04
NORM2dof0: 6.991018e-04 NORM2dof0/NORM2dof00: 1.567838e-04
NORM2dof1: 4.909298e-04 NORM2dof1/NORM2dof10: 1.072292e-01
NORM2dof2: 8.945573e-04 NORM2dof2/NORM2dof20: 1.736541e-01
NORM2dof3: 4.747502e-09 NORM2dof3/NORM2dof30: 5.812279e-01
isolid: 0 NORM2S: 8.726198e-11 NORM2S/NORM2S0: 1.190351e-01
      0 KSP Residual norm 1.236926864027e-03
      1 KSP Residual norm 1.071127264500e-03
      2 KSP Residual norm 1.751214473962e-04
      3 KSP Residual norm 2.704156117881e-05
      4 KSP Residual norm 5.488005113558e-06
      5 KSP Residual norm 7.722886659587e-07
      6 KSP Residual norm 7.098438747194e-08
      7 KSP Residual norm 1.983193288033e-08
      8 KSP Residual norm 4.748543039977e-09
 FirstNewton = 0
 FirstNewton = 0
    2 SNES Function norm 9.096330543561e-05
NORM2F: 9.096331e-05 NORM2F/NORM2F0: 2.039983e-05
NORM2dof0: 5.166861e-05 NORM2dof0/NORM2dof00: 1.158744e-05
NORM2dof1: 3.547412e-05 NORM2dof1/NORM2dof10: 7.748284e-03
NORM2dof2: 6.592621e-05 NORM2dof2/NORM2dof20: 1.279779e-02
NORM2dof3: 4.701915e-09 NORM2dof3/NORM2dof30: 5.756467e-01
isolid: 0 NORM2S: 9.560042e-12 NORM2S/NORM2S0: 1.304097e-02
      0 KSP Residual norm 9.096330543561e-05
      1 KSP Residual norm 7.533403951589e-05
      2 KSP Residual norm 1.381728268481e-05
      3 KSP Residual norm 1.091611453418e-06
      4 KSP Residual norm 4.192008920668e-07
      5 KSP Residual norm 4.482015838680e-08
      6 KSP Residual norm 3.774406616492e-09
 FirstNewton = 0
 FirstNewton = 0
    3 SNES Function norm 9.951450618798e-06
NORM2F: 9.951451e-06 NORM2F/NORM2F0: 2.231756e-06
NORM2dof0: 7.264841e-06 NORM2dof0/NORM2dof00: 1.629247e-06
NORM2dof1: 4.344457e-06 NORM2dof1/NORM2dof10: 9.489196e-04
NORM2dof2: 5.232507e-06 NORM2dof2/NORM2dof20: 1.015750e-03
NORM2dof3: 3.834626e-09 NORM2dof3/NORM2dof30: 4.694662e-01
isolid: 0 NORM2S: 1.046678e-12 NORM2S/NORM2S0: 1.427786e-03
      0 KSP Residual norm 9.951450618798e-06
      1 KSP Residual norm 7.990857028187e-06
      2 KSP Residual norm 9.578210213199e-07
      3 KSP Residual norm 1.479683659993e-07
      4 KSP Residual norm 4.631330261324e-08
      5 KSP Residual norm 3.440725247739e-09
    4 SNES Function norm 9.951450618798e-06
    5 SNES Function norm 9.951450618798e-06
    6 SNES Function norm 9.951450618798e-06
    7 SNES Function norm 9.951450618798e-06
    8 SNES Function norm 9.951450618798e-06
    9 SNES Function norm 9.951450618798e-06
   10 SNES Function norm 9.951450618798e-06
   11 SNES Function norm 9.951450618798e-06
   12 SNES Function norm 9.951450618798e-06
   13 SNES Function norm 9.951450618798e-06
   14 SNES Function norm 9.951450618798e-06
   15 SNES Function norm 9.951450618798e-06
   16 SNES Function norm 9.951450618798e-06
   17 SNES Function norm 9.951450618798e-06
   18 SNES Function norm 9.951450618798e-06
   19 SNES Function norm 9.951450618798e-06
   20 SNES Function norm 9.951450618798e-06
 Tangent
      1 KSP Residual norm 7.990856944949e-06
      2 KSP Residual norm 9.578210894798e-07
      3 KSP Residual norm 1.479686480708e-07
      4 KSP Residual norm 4.631312748017e-08
      5 KSP Residual norm 3.440843607197e-09
   21 SNES Function norm 9.951450618798e-06
   22 SNES Function norm 9.951450618798e-06
   23 SNES Function norm 9.951450618798e-06
   24 SNES Function norm 9.951450618798e-06
   25 SNES Function norm 9.951450618798e-06
   26 SNES Function norm 9.951450618798e-06
   27 SNES Function norm 9.951450618798e-06
   28 SNES Function norm 9.951450618798e-06
   29 SNES Function norm 9.951450618798e-06
   30 SNES Function norm 9.951450618798e-06
   31 SNES Function norm 9.951450618798e-06
   32 SNES Function norm 9.951450618798e-06
   33 SNES Function norm 9.951450618798e-06
   34 SNES Function norm 9.951450618798e-06
   35 SNES Function norm 9.951450618798e-06
   36 SNES Function norm 9.951450618798e-06
   37 SNES Function norm 9.951450618798e-06
   38 SNES Function norm 9.951450618798e-06
   39 SNES Function norm 9.951450618798e-06
   40 SNES Function norm 9.951450618798e-06
 Tangent
   41 SNES Function norm 9.951450618798e-06
   42 SNES Function norm 9.951450618798e-06
   43 SNES Function norm 9.951450618798e-06
   44 SNES Function norm 9.951450618798e-06
   45 SNES Function norm 9.951450618798e-06
   46 SNES Function norm 9.951450618798e-06
   47 SNES Function norm 9.951450618798e-06
   48 SNES Function norm 9.951450618798e-06
   49 SNES Function norm 9.951450618798e-06
   50 SNES Function norm 9.951450618798e-06
 FirstNewton = 0
    0 SNES Function norm 2.227652018978e+00
NORM2dof1: 9.432557e-04 NORM2dof1/NORM2dof10: 1.000000e+00
NORM2dof2: 1.534747e-03 NORM2dof2/NORM2dof20: 1.000000e+00
NORM2dof3: 5.335951e-09 NORM2dof3/NORM2dof30: 1.000000e+00
isolid: 0 NORM2S: 7.711838e-10 NORM2S/NORM2S0: 1.000000e+00
 Tangent
 [mpiexec at ubuntu] Sending Ctrl-C to processes as requested
[mpiexec at ubuntu] Press Ctrl-C again to force abort
muS = 2.000000e-03
cS = 5.000000e+00
 FirstNewton = 0
 Tangent
 FirstNewton = 0
    1 SNES Function norm 8.179534168795e-03
NORM2F: 8.179534e-03 NORM2F/NORM2F0: 2.289328e-04
NORM2dof0: 5.417333e-03 NORM2dof0/NORM2dof00: 1.516229e-04
NORM2dof1: 4.128207e-03 NORM2dof1/NORM2dof10: 3.177177e+00
NORM2dof2: 4.529371e-03 NORM2dof2/NORM2dof20: 2.208066e+00
NORM2dof3: 8.833843e-09 NORM2dof3/NORM2dof30: inf
isolid: 0 NORM2S: 5.491667e-10 NORM2S/NORM2S0: inf
 FirstNewton = 0
    0 SNES Function norm 1.785811875746e+01
NORM2F: 1.785812e+01 NORM2F/NORM2F0: 1.000000e+00
NORM2dof0: 1.785811e+01 NORM2dof0/NORM2dof00: 1.000000e+00
NORM2dof1: 1.322644e-02 NORM2dof1/NORM2dof10: 1.000000e+00
NORM2dof2: 1.447647e-02 NORM2dof2/NORM2dof20: 1.000000e+00
NORM2dof3: 1.325076e-08 NORM2dof3/NORM2dof30: 1.000000e+00
isolid: 0 NORM2S: 9.335547e-10 NORM2S/NORM2S0: 1.000000e+00
 Tangent
       0 KSP Residual norm 1.785811875746e+01
      1 KSP Residual norm 4.296571408960e-02
      2 KSP Residual norm 3.122248048448e-03
      3 KSP Residual norm 7.130517384309e-04
      4 KSP Residual norm 1.200695618806e-04
      5 KSP Residual norm 2.051457303686e-05
      6 KSP Residual norm 4.752085930166e-06
      7 KSP Residual norm 1.460661506211e-06
      8 KSP Residual norm 2.174375435375e-07
      9 KSP Residual norm 6.433692523485e-08
     10 KSP Residual norm 1.394483067890e-08
     11 KSP Residual norm 2.009854195400e-09
 FirstNewton = 0
    1 SNES Function norm 1.807740322922e-03
NORM2F: 1.807740e-03 NORM2F/NORM2F0: 1.012279e-04
NORM2dof0: 1.314040e-03 NORM2dof0/NORM2dof00: 7.358226e-05
NORM2dof1: 9.149102e-04 NORM2dof1/NORM2dof10: 6.917281e-02
NORM2dof2: 8.391445e-04 NORM2dof2/NORM2dof20: 5.796611e-02
NORM2dof3: 1.948126e-09 NORM2dof3/NORM2dof30: 1.470199e-01
isolid: 0 NORM2S: 1.371767e-10 NORM2S/NORM2S0: 1.469402e-01
      0 KSP Residual norm 1.807740322922e-03
      1 KSP Residual norm 1.451506444230e-03
      2 KSP Residual norm 9.510919862795e-05
      3 KSP Residual norm 8.399504895801e-06
      4 KSP Residual norm 8.657398775652e-07
      5 KSP Residual norm 1.485686856288e-07
      6 KSP Residual norm 2.630954389838e-08
      7 KSP Residual norm 9.208863855727e-09
    Linear solve converged due to CONVERGED_ATOL iterations 7
 FirstNewton = 0
    2 SNES Function norm 3.562298901787e-04
NORM2F: 3.562299e-04 NORM2F/NORM2F0: 1.994778e-05
NORM2dof0: 2.576370e-04 NORM2dof0/NORM2dof00: 1.442689e-05
NORM2dof1: 1.827372e-04 NORM2dof1/NORM2dof10: 1.381605e-02
NORM2dof2: 1.647119e-04 NORM2dof2/NORM2dof20: 1.137791e-02
NORM2dof3: 8.991546e-09 NORM2dof3/NORM2dof30: 6.785681e-01
isolid: 0 NORM2S: 4.523333e-11 NORM2S/NORM2S0: 4.845279e-02
      0 KSP Residual norm 3.562298901787e-04
      1 KSP Residual norm 2.874774960479e-04
      2 KSP Residual norm 1.377691650681e-05
      3 KSP Residual norm 1.649125322363e-06
      4 KSP Residual norm 2.048704731035e-07
      5 KSP Residual norm 2.862642640770e-08
      6 KSP Residual norm 6.184460810271e-09
 FirstNewton = 0
    3 SNES Function norm 7.432116405686e-05
NORM2F: 7.432116e-05 NORM2F/NORM2F0: 4.161758e-06
NORM2dof0: 5.292265e-05 NORM2dof0/NORM2dof00: 2.963508e-06
NORM2dof1: 3.812343e-05 NORM2dof1/NORM2dof10: 2.882364e-03
NORM2dof2: 3.562910e-05 NORM2dof2/NORM2dof20: 2.461173e-03
NORM2dof3: 6.104188e-09 NORM2dof3/NORM2dof30: 4.606668e-01
isolid: 0 NORM2S: 1.495513e-11 NORM2S/NORM2S0: 1.601955e-02
      0 KSP Residual norm 7.432116405686e-05
      1 KSP Residual norm 6.012965573878e-05
      2 KSP Residual norm 1.290383408559e-06
      3 KSP Residual norm 2.827520158979e-07
      4 KSP Residual norm 4.658855980387e-08
      5 KSP Residual norm 1.136337746901e-08
      6 KSP Residual norm 1.609818301928e-09
Linear solve converged due to CONVERGED_RTOL iterations 7
 FirstNewton = 0
    4 SNES Function norm 1.654931139050e-05
NORM2F: 1.654931e-05 NORM2F/NORM2F0: 9.267108e-07
NORM2dof0: 1.148377e-05 NORM2dof0/NORM2dof00: 6.430562e-07
NORM2dof1: 8.318505e-06 NORM2dof1/NORM2dof10: 6.289299e-04
NORM2dof2: 8.532599e-06 NORM2dof2/NORM2dof20: 5.894117e-04
NORM2dof3: 1.570635e-09 NORM2dof3/NORM2dof30: 1.185316e-01
isolid: 0 NORM2S: 4.951918e-12 NORM2S/NORM2S0: 5.304368e-03
      0 KSP Residual norm 1.654931139050e-05
      1 KSP Residual norm 1.338742562915e-05
      2 KSP Residual norm 4.528291440124e-07
      3 KSP Residual norm 6.304923603869e-08
      4 KSP Residual norm 1.035515227239e-08
      5 KSP Residual norm 2.609822453988e-09
 FirstNewton = 0
    5 SNES Function norm 3.956058392676e-06
NORM2F: 3.956058e-06 NORM2F/NORM2F0: 2.215272e-07
NORM2dof0: 2.659137e-06 NORM2dof0/NORM2dof00: 1.489036e-07
NORM2dof1: 1.899924e-06 NORM2dof1/NORM2dof10: 1.436459e-04
NORM2dof2: 2.229276e-06 NORM2dof2/NORM2dof20: 1.539931e-04
NORM2dof3: 2.513204e-09 NORM2dof3/NORM2dof30: 1.896648e-01
isolid: 0 NORM2S: 1.641180e-12 NORM2S/NORM2S0: 1.757990e-03
      0 KSP Residual norm 3.956058392676e-06
      1 KSP Residual norm 3.197570977809e-06
      2 KSP Residual norm 2.748057468149e-07
      3 KSP Residual norm 2.299688960592e-08
      4 KSP Residual norm 5.261852437122e-09
    Linear solve converged due to CONVERGED_ATOL iterations 4
 FirstNewton = 0
    6 SNES Function norm 1.018303282453e-06
NORM2F: 1.018303e-06 NORM2F/NORM2F0: 5.702187e-08
NORM2dof0: 6.638374e-07 NORM2dof0/NORM2dof00: 3.717289e-08
NORM2dof1: 4.552106e-07 NORM2dof1/NORM2dof10: 3.441671e-05
NORM2dof2: 6.237124e-07 NORM2dof2/NORM2dof20: 4.308457e-05
NORM2dof3: 5.252224e-09 NORM2dof3/NORM2dof30: 3.963714e-01
isolid: 0 NORM2S: 5.442581e-13 NORM2S/NORM2S0: 5.829954e-04
  Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 6
 FirstNewton = 0
    0 SNES Function norm 8.924366614113e+00
NORM2F: 8.924367e+00 NORM2F/NORM2F0: 1.000000e+00
NORM2dof0: 8.924366e+00 NORM2dof0/NORM2dof00: 1.000000e+00
NORM2dof1: 1.039285e-03 NORM2dof1/NORM2dof10: 1.000000e+00
NORM2dof2: 1.311270e-03 NORM2dof2/NORM2dof20: 1.000000e+00
NORM2dof3: 1.078482e-08 NORM2dof3/NORM2dof30: 1.000000e+00
isolid: 0 NORM2S: 7.282375e-10 NORM2S/NORM2S0: 1.000000e+00
 Tangent
       0 KSP Residual norm 8.924366614113e+00
      1 KSP Residual norm 2.948318247217e-03
      2 KSP Residual norm 1.609798634706e-04
      3 KSP Residual norm 3.198849647624e-05
      4 KSP Residual norm 1.174804810293e-05
      5 KSP Residual norm 1.554033028085e-06
      6 KSP Residual norm 4.588793184781e-07
      7 KSP Residual norm 1.024666188198e-07
      8 KSP Residual norm 2.252862941671e-08
      9 KSP Residual norm 4.561377911766e-09
 FirstNewton = 0
    1 SNES Function norm 2.871784646094e-03
NORM2F: 2.871785e-03 NORM2F/NORM2F0: 3.217914e-04
NORM2dof0: 1.983381e-03 NORM2dof0/NORM2dof00: 2.222433e-04
NORM2dof1: 1.434857e-03 NORM2dof1/NORM2dof10: 1.380619e+00
NORM2dof2: 1.501511e-03 NORM2dof2/NORM2dof20: 1.145081e+00
NORM2dof3: 4.311166e-09 NORM2dof3/NORM2dof30: 3.997439e-01
isolid: 0 NORM2S: 2.671486e-10 NORM2S/NORM2S0: 3.668427e-01
      0 KSP Residual norm 2.871784646094e-03
      1 KSP Residual norm 2.441603019966e-03
      2 KSP Residual norm 3.357514143288e-04
      3 KSP Residual norm 3.867792059380e-05
      4 KSP Residual norm 3.448954948914e-06
      5 KSP Residual norm 1.054948539852e-06
      6 KSP Residual norm 7.390933578667e-08
      7 KSP Residual norm 2.899606997760e-08
      8 KSP Residual norm 5.225461480120e-09
    Linear solve converged due to CONVERGED_ATOL iterations 8
 FirstNewton = 0
    2 SNES Function norm 6.342201955712e-04
NORM2F: 6.342202e-04 NORM2F/NORM2F0: 7.106613e-05
NORM2dof0: 4.300068e-04 NORM2dof0/NORM2dof00: 4.818345e-05
NORM2dof1: 3.060014e-04 NORM2dof1/NORM2dof10: 2.944346e-01
NORM2dof2: 3.516995e-04 NORM2dof2/NORM2dof20: 2.682130e-01
NORM2dof3: 5.087391e-09 NORM2dof3/NORM2dof30: 4.717177e-01
isolid: 0 NORM2S: 8.873816e-11 NORM2S/NORM2S0: 1.218533e-01
      0 KSP Residual norm 6.342201955712e-04
      1 KSP Residual norm 5.445764200090e-04
      2 KSP Residual norm 8.367942390528e-05
      3 KSP Residual norm 9.995349815534e-06
      4 KSP Residual norm 1.100800320727e-06
      5 KSP Residual norm 2.893113064436e-07
      6 KSP Residual norm 2.243754504028e-08
      7 KSP Residual norm 6.401638759353e-09
 FirstNewton = 0
    3 SNES Function norm 1.444641188825e-04
NORM2F: 1.444641e-04 NORM2F/NORM2F0: 1.618760e-05
NORM2dof0: 9.681361e-05 NORM2dof0/NORM2dof00: 1.084823e-05
NORM2dof1: 6.600938e-05 NORM2dof1/NORM2dof10: 6.351423e-02
NORM2dof2: 8.449715e-05 NORM2dof2/NORM2dof20: 6.443918e-02
NORM2dof3: 6.222114e-09 NORM2dof3/NORM2dof30: 5.769325e-01
isolid: 0 NORM2S: 2.950147e-11 NORM2S/NORM2S0: 4.051078e-02
      0 KSP Residual norm 1.444641188825e-04
      1 KSP Residual norm 1.250825921546e-04
      2 KSP Residual norm 2.183478739945e-05
      3 KSP Residual norm 2.634141022942e-06
      4 KSP Residual norm 3.484980278422e-07
      5 KSP Residual norm 7.770556133046e-08
      6 KSP Residual norm 6.439444025435e-09
    Linear solve converged due to CONVERGED_ATOL iterations 6
 FirstNewton = 0
    4 SNES Function norm 3.404974125735e-05
NORM2F: 3.404974e-05 NORM2F/NORM2F0: 3.815368e-06
NORM2dof0: 2.272249e-05 NORM2dof0/NORM2dof00: 2.546118e-06
NORM2dof1: 1.436132e-05 NORM2dof1/NORM2dof10: 1.381846e-02
NORM2dof2: 2.090038e-05 NORM2dof2/NORM2dof20: 1.593904e-02
NORM2dof3: 6.333960e-09 NORM2dof3/NORM2dof30: 5.873031e-01
isolid: 0 NORM2S: 9.810853e-12 NORM2S/NORM2S0: 1.347205e-02
      0 KSP Residual norm 3.404974125735e-05
      1 KSP Residual norm 2.968795832402e-05
      2 KSP Residual norm 5.933576632059e-06
      3 KSP Residual norm 7.097281375035e-07
      4 KSP Residual norm 1.099662748181e-07
      5 KSP Residual norm 2.121937393132e-08
      6 KSP Residual norm 1.780091758034e-09
 FirstNewton = 0
    5 SNES Function norm 8.394933416134e-06
NORM2F: 8.394933e-06 NORM2F/NORM2F0: 9.406755e-07
NORM2dof0: 5.600056e-06 NORM2dof0/NORM2dof00: 6.275018e-07
NORM2dof1: 3.170236e-06 NORM2dof1/NORM2dof10: 3.050401e-03
NORM2dof2: 5.391093e-06 NORM2dof2/NORM2dof20: 4.111353e-03
NORM2dof3: 1.751450e-09 NORM2dof3/NORM2dof30: 1.623996e-01
isolid: 0 NORM2S: 3.262880e-12 NORM2S/NORM2S0: 4.480516e-03
      0 KSP Residual norm 8.394933416134e-06
      1 KSP Residual norm 7.356164396242e-06
      2 KSP Residual norm 1.668067457609e-06
      3 KSP Residual norm 1.953889313819e-07
      4 KSP Residual norm 3.441296077683e-08
      5 KSP Residual norm 5.873915380746e-09
 FirstNewton = 0
    6 SNES Function norm 2.197166986925e-06
NORM2F: 2.197167e-06 NORM2F/NORM2F0: 2.461986e-07
NORM2dof0: 1.463049e-06 NORM2dof0/NORM2dof00: 1.639387e-07
NORM2dof1: 7.280334e-07 NORM2dof1/NORM2dof10: 7.005137e-04
NORM2dof2: 1.468661e-06 NORM2dof2/NORM2dof20: 1.120029e-03
NORM2dof3: 5.818840e-09 NORM2dof3/NORM2dof30: 5.395397e-01
isolid: 0 NORM2S: 1.085165e-12 NORM2S/NORM2S0: 1.490125e-03
      0 KSP Residual norm 2.197166986925e-06
      1 KSP Residual norm 1.929059425192e-06
      2 KSP Residual norm 4.829978507880e-07
      3 KSP Residual norm 5.487586753744e-08
      4 KSP Residual norm 1.087871661245e-08
      5 KSP Residual norm 1.815733500571e-09
    Linear solve converged due to CONVERGED_ATOL iterations 5
 FirstNewton = 0
    7 SNES Function norm 6.149432005351e-07
NORM2F: 6.149432e-07 NORM2F/NORM2F0: 6.890609e-08
NORM2dof0: 4.063714e-07 NORM2dof0/NORM2dof00: 4.553504e-08
NORM2dof1: 1.823771e-07 NORM2dof1/NORM2dof10: 1.754833e-04
NORM2dof2: 4.239726e-07 NORM2dof2/NORM2dof20: 3.233298e-04
NORM2dof3: 1.799799e-09 NORM2dof3/NORM2dof30: 1.668826e-01
isolid: 0 NORM2S: 3.608987e-13 NORM2S/NORM2S0: 4.955783e-04
  Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 7
3 TS dt 0.0001 time 0.0003
 FirstNewton = 0
    0 SNES Function norm 4.459144715069e+00
NORM2F: 4.459145e+00 NORM2F/NORM2F0: 1.000000e+00
NORM2dof0: 4.459140e+00 NORM2dof0/NORM2dof00: 1.000000e+00
NORM2dof1: 4.223876e-03 NORM2dof1/NORM2dof10: 1.000000e+00
NORM2dof2: 4.770992e-03 NORM2dof2/NORM2dof20: 1.000000e+00
NORM2dof3: 5.816681e-09 NORM2dof3/NORM2dof30: 1.000000e+00
isolid: 0 NORM2S: 7.322273e-10 NORM2S/NORM2S0: 1.000000e+00
 Tangent
       0 KSP Residual norm 4.459144715069e+00
      1 KSP Residual norm 1.430054211791e-02
      2 KSP Residual norm 1.099723491566e-03
      3 KSP Residual norm 2.191178105926e-04
      4 KSP Residual norm 2.347923388451e-05
      5 KSP Residual norm 6.913259216773e-06
      6 KSP Residual norm 1.244769342719e-06
      7 KSP Residual norm 6.494962371580e-07
      8 KSP Residual norm 6.840468608238e-08
      9 KSP Residual norm 1.623380135908e-08
     10 KSP Residual norm 4.267476189880e-09
    Linear solve converged due to CONVERGED_ATOL iterations 10
 FirstNewton = 0
    1 SNES Function norm 1.009931624841e-03
NORM2F: 1.009932e-03 NORM2F/NORM2F0: 2.264855e-04
NORM2dof0: 5.690566e-04 NORM2dof0/NORM2dof00: 1.276158e-04
NORM2dof1: 4.148465e-04 NORM2dof1/NORM2dof10: 9.821465e-02
NORM2dof2: 7.239053e-04 NORM2dof2/NORM2dof20: 1.517306e-01
NORM2dof3: 4.074435e-09 NORM2dof3/NORM2dof30: 7.004743e-01
isolid: 0 NORM2S: 2.614560e-10 NORM2S/NORM2S0: 3.570694e-01
      0 KSP Residual norm 1.009931624841e-03
      1 KSP Residual norm 8.783994285493e-04
      2 KSP Residual norm 1.441108550593e-04
      3 KSP Residual norm 2.176288364317e-05
      4 KSP Residual norm 3.918465127387e-06
      5 KSP Residual norm 6.299082990315e-07
      6 KSP Residual norm 5.907647901706e-08
      7 KSP Residual norm 1.494853339682e-08
      8 KSP Residual norm 3.675688476351e-09
 FirstNewton = 0
    2 SNES Function norm 2.425866717982e-04
NORM2F: 2.425867e-04 NORM2F/NORM2F0: 5.440206e-05
NORM2dof0: 1.411812e-04 NORM2dof0/NORM2dof00: 3.166109e-05
NORM2dof1: 9.619262e-05 NORM2dof1/NORM2dof10: 2.277354e-02
NORM2dof2: 1.722299e-04 NORM2dof2/NORM2dof20: 3.609938e-02
NORM2dof3: 3.638929e-09 NORM2dof3/NORM2dof30: 6.256023e-01
isolid: 0 NORM2S: 8.679633e-11 NORM2S/NORM2S0: 1.185374e-01
      0 KSP Residual norm 2.425866717982e-04
      1 KSP Residual norm 2.126906752798e-04
      2 KSP Residual norm 4.235059789636e-05
      3 KSP Residual norm 6.016024694895e-06
      4 KSP Residual norm 1.238075519193e-06
      5 KSP Residual norm 1.733977911998e-07
      6 KSP Residual norm 1.519524757192e-08
      7 KSP Residual norm 3.731285653323e-09
 FirstNewton = 0
    3 SNES Function norm 6.214796770176e-05
NORM2F: 6.214797e-05 NORM2F/NORM2F0: 1.393719e-05
NORM2dof0: 3.732738e-05 NORM2dof0/NORM2dof00: 8.370981e-06
NORM2dof1: 2.335159e-05 NORM2dof1/NORM2dof10: 5.528474e-03
NORM2dof2: 4.386046e-05 NORM2dof2/NORM2dof20: 9.193152e-03
NORM2dof3: 3.614204e-09 NORM2dof3/NORM2dof30: 6.213516e-01
isolid: 0 NORM2S: 2.882395e-11 NORM2S/NORM2S0: 3.936476e-02
      0 KSP Residual norm 6.214796770176e-05
      1 KSP Residual norm 5.480359919001e-05
      2 KSP Residual norm 1.264551707739e-05
      3 KSP Residual norm 1.693095445848e-06
      4 KSP Residual norm 3.905820075265e-07
      5 KSP Residual norm 4.858554198022e-08
      6 KSP Residual norm 3.997373438492e-09
 FirstNewton = 0
    4 SNES Function norm 1.714543439076e-05
NORM2F: 1.714543e-05 NORM2F/NORM2F0: 3.845005e-06
NORM2dof0: 1.051444e-05 NORM2dof0/NORM2dof00: 2.357952e-06
NORM2dof1: 6.099625e-06 NORM2dof1/NORM2dof10: 1.444082e-03
NORM2dof2: 1.209161e-05 NORM2dof2/NORM2dof20: 2.534402e-03
NORM2dof3: 3.895744e-09 NORM2dof3/NORM2dof30: 6.697539e-01
isolid: 0 NORM2S: 9.573609e-12 NORM2S/NORM2S0: 1.307464e-02
      0 KSP Residual norm 1.714543439076e-05
      1 KSP Residual norm 1.515496624794e-05
      2 KSP Residual norm 3.835547279511e-06
      3 KSP Residual norm 4.864209198956e-07
      4 KSP Residual norm 1.241513578241e-07
      5 KSP Residual norm 1.379658721534e-08
      6 KSP Residual norm 1.110182651776e-09
 FirstNewton = 0
    5 SNES Function norm 5.065175701161e-06
NORM2F: 5.065176e-06 NORM2F/NORM2F0: 1.135907e-06
NORM2dof0: 3.123073e-06 NORM2dof0/NORM2dof00: 7.003757e-07
NORM2dof1: 1.744299e-06 NORM2dof1/NORM2dof10: 4.129618e-04
NORM2dof2: 3.586061e-06 NORM2dof2/NORM2dof20: 7.516385e-04
NORM2dof3: 1.081461e-09 NORM2dof3/NORM2dof30: 1.859242e-01
isolid: 0 NORM2S: 3.180103e-12 NORM2S/NORM2S0: 4.343055e-03
      0 KSP Residual norm 5.065175701161e-06
      1 KSP Residual norm 4.472023238259e-06
      2 KSP Residual norm 1.182936934229e-06
      3 KSP Residual norm 1.432720165026e-07
      4 KSP Residual norm 3.953945500222e-08
      5 KSP Residual norm 3.985711262214e-09
 FirstNewton = 0
    6 SNES Function norm 1.570301324742e-06
NORM2F: 1.570301e-06 NORM2F/NORM2F0: 3.521530e-07
NORM2dof0: 9.646941e-07 NORM2dof0/NORM2dof00: 2.163408e-07
NORM2dof1: 5.382009e-07 NORM2dof1/NORM2dof10: 1.274187e-04
NORM2dof2: 1.116036e-06 NORM2dof2/NORM2dof20: 2.339211e-04
NORM2dof3: 3.958295e-09 NORM2dof3/NORM2dof30: 6.805076e-01
isolid: 0 NORM2S: 1.056443e-12 NORM2S/NORM2S0: 1.442780e-03
      0 KSP Residual norm 1.570301324742e-06
      1 KSP Residual norm 1.382157925031e-06
      2 KSP Residual norm 3.704819182722e-07
      3 KSP Residual norm 4.332114937773e-08
      4 KSP Residual norm 1.271531123606e-08
      5 KSP Residual norm 1.242030316262e-09
 FirstNewton = 0
    7 SNES Function norm 5.004889615780e-07
NORM2F: 5.004890e-07 NORM2F/NORM2F0: 1.122388e-07
NORM2dof0: 3.055851e-07 NORM2dof0/NORM2dof00: 6.853004e-08
NORM2dof1: 1.737459e-07 NORM2dof1/NORM2dof10: 4.113423e-05
NORM2dof2: 3.562553e-07 NORM2dof2/NORM2dof20: 7.467110e-05
NORM2dof3: 1.234573e-09 NORM2dof3/NORM2dof30: 2.122469e-01
isolid: 0 NORM2S: 3.509873e-13 NORM2S/NORM2S0: 4.793420e-04
4 TS dt 0.0001 time 0.0004
 FirstNewton = 0
    0 SNES Function norm 2.227714008716e+00
NORM2F: 2.227714e+00 NORM2F/NORM2F0: 1.000000e+00
NORM2dof0: 2.227713e+00 NORM2dof0/NORM2dof00: 1.000000e+00
NORM2dof1: 1.190619e-03 NORM2dof1/NORM2dof10: 1.000000e+00
NORM2dof2: 1.831842e-03 NORM2dof2/NORM2dof20: 1.000000e+00
NORM2dof3: 2.590378e-09 NORM2dof3/NORM2dof30: 1.000000e+00
isolid: 0 NORM2S: 7.719967e-10 NORM2S/NORM2S0: 1.000000e+00
 Tangent
       0 KSP Residual norm 2.227714008716e+00
      1 KSP Residual norm 4.746600445376e-03
      2 KSP Residual norm 4.409010411023e-04
      3 KSP Residual norm 1.404618920809e-04
      4 KSP Residual norm 1.831888618610e-05
      5 KSP Residual norm 5.018350224586e-06
      6 KSP Residual norm 1.017646288532e-06
      7 KSP Residual norm 3.671995304249e-07
      8 KSP Residual norm 6.091669143225e-08
      9 KSP Residual norm 1.379709606698e-08
     10 KSP Residual norm 3.278672639947e-09
 FirstNewton = 0
    1 SNES Function norm 9.799793450225e-04
NORM2F: 9.799793e-04 NORM2F/NORM2F0: 4.399036e-04
NORM2dof0: 6.756995e-04 NORM2dof0/NORM2dof00: 3.033153e-04
NORM2dof1: 4.505928e-04 NORM2dof1/NORM2dof10: 3.784525e-01
NORM2dof2: 5.484121e-04 NORM2dof2/NORM2dof20: 2.993774e-01
NORM2dof3: 3.197166e-09 NORM2dof3/NORM2dof30: 1.234247e+00
isolid: 0 NORM2S: 2.340774e-10 NORM2S/NORM2S0: 3.032104e-01
      0 KSP Residual norm 9.799793450225e-04
      1 KSP Residual norm 8.496336630538e-04
      2 KSP Residual norm 1.589845235952e-04
      3 KSP Residual norm 1.948264727094e-05
      4 KSP Residual norm 4.182027781665e-06
      5 KSP Residual norm 5.917861645028e-07
      6 KSP Residual norm 4.825781709476e-08
      7 KSP Residual norm 1.601322339760e-08
      8 KSP Residual norm 3.437092029191e-09
 FirstNewton = 0
    2 SNES Function norm 2.342429858616e-04
NORM2F: 2.342430e-04 NORM2F/NORM2F0: 1.051495e-04
NORM2dof0: 1.584271e-04 NORM2dof0/NORM2dof00: 7.111647e-05
NORM2dof1: 9.983075e-05 NORM2dof1/NORM2dof10: 8.384774e-02
NORM2dof2: 1.407283e-04 NORM2dof2/NORM2dof20: 7.682339e-02
NORM2dof3: 3.402101e-09 NORM2dof3/NORM2dof30: 1.313361e+00
isolid: 0 NORM2S: 7.782780e-11 NORM2S/NORM2S0: 1.008136e-01
      0 KSP Residual norm 2.342429858616e-04
      1 KSP Residual norm 2.054005492620e-04
      2 KSP Residual norm 4.367831164465e-05
      3 KSP Residual norm 5.474999473429e-06
      4 KSP Residual norm 1.351783042540e-06
      5 KSP Residual norm 1.630310541965e-07
      6 KSP Residual norm 1.255726348464e-08
      7 KSP Residual norm 4.091510648836e-09
 FirstNewton = 0
    3 SNES Function norm 6.005771479449e-05
NORM2F: 6.005771e-05 NORM2F/NORM2F0: 2.695935e-05
NORM2dof0: 3.989762e-05 NORM2dof0/NORM2dof00: 1.790968e-05
NORM2dof1: 2.357359e-05 NORM2dof1/NORM2dof10: 1.979943e-02
NORM2dof2: 3.820203e-05 NORM2dof2/NORM2dof20: 2.085443e-02
NORM2dof3: 4.033741e-09 NORM2dof3/NORM2dof30: 1.557202e+00
isolid: 0 NORM2S: 2.587554e-11 NORM2S/NORM2S0: 3.351768e-02
      0 KSP Residual norm 6.005771479449e-05
      1 KSP Residual norm 5.306036418346e-05
      2 KSP Residual norm 1.245994780079e-05
      3 KSP Residual norm 1.561736577105e-06
      4 KSP Residual norm 4.323812263761e-07
      5 KSP Residual norm 4.482279442384e-08
      6 KSP Residual norm 3.453753063290e-09
 FirstNewton = 0
    4 SNES Function norm 1.660946190357e-05
NORM2F: 1.660946e-05 NORM2F/NORM2F0: 7.455832e-06
NORM2dof0: 1.084439e-05 NORM2dof0/NORM2dof00: 4.867948e-06
NORM2dof1: 6.145127e-06 NORM2dof1/NORM2dof10: 5.161286e-03
NORM2dof2: 1.097774e-05 NORM2dof2/NORM2dof20: 5.992734e-03
NORM2dof3: 3.355275e-09 NORM2dof3/NORM2dof30: 1.295284e+00
isolid: 0 NORM2S: 8.602648e-12 NORM2S/NORM2S0: 1.114337e-02
      0 KSP Residual norm 1.660946190357e-05
      1 KSP Residual norm 1.472259829384e-05
      2 KSP Residual norm 3.677715881419e-06
      3 KSP Residual norm 4.549526942398e-07
      4 KSP Residual norm 1.385750017357e-07
      5 KSP Residual norm 1.247239451509e-08
      6 KSP Residual norm 1.016552372074e-09
 FirstNewton = 0
    5 SNES Function norm 4.914089751779e-06
NORM2F: 4.914090e-06 NORM2F/NORM2F0: 2.205889e-06
NORM2dof0: 3.155245e-06 NORM2dof0/NORM2dof00: 1.416361e-06
NORM2dof1: 1.785726e-06 NORM2dof1/NORM2dof10: 1.499829e-03
NORM2dof2: 3.317211e-06 NORM2dof2/NORM2dof20: 1.810861e-03
NORM2dof3: 9.936021e-10 NORM2dof3/NORM2dof30: 3.835742e-01
isolid: 0 NORM2S: 2.860044e-12 NORM2S/NORM2S0: 3.704736e-03
      0 KSP Residual norm 4.914089751779e-06
      1 KSP Residual norm 4.354582149670e-06
      2 KSP Residual norm 1.118207468724e-06
      3 KSP Residual norm 1.358387674944e-07
      4 KSP Residual norm 4.435465182538e-08
      5 KSP Residual norm 3.574530954571e-09
 FirstNewton = 0
    6 SNES Function norm 1.524523303637e-06
NORM2F: 1.524523e-06 NORM2F/NORM2F0: 6.843443e-07
NORM2dof0: 9.637973e-07 NORM2dof0/NORM2dof00: 4.326398e-07
NORM2dof1: 5.615417e-07 NORM2dof1/NORM2dof10: 4.716383e-04
NORM2dof2: 1.039194e-06 NORM2dof2/NORM2dof20: 5.672946e-04
NORM2dof3: 3.557071e-09 NORM2dof3/NORM2dof30: 1.373186e+00
isolid: 0 NORM2S: 9.508659e-13 NORM2S/NORM2S0: 1.231697e-03
      0 KSP Residual norm 1.524523303637e-06
      1 KSP Residual norm 1.347927283991e-06
      2 KSP Residual norm 3.478775443084e-07
      3 KSP Residual norm 4.151326399995e-08
      4 KSP Residual norm 1.427820037041e-08
      5 KSP Residual norm 1.096468854699e-09
 FirstNewton = 0
    7 SNES Function norm 4.863620680675e-07
NORM2F: 4.863621e-07 NORM2F/NORM2F0: 2.183234e-07
NORM2dof0: 3.034552e-07 NORM2dof0/NORM2dof00: 1.362183e-07
NORM2dof1: 1.835677e-07 NORM2dof1/NORM2dof10: 1.541783e-04
NORM2dof2: 3.328133e-07 NORM2dof2/NORM2dof20: 1.816823e-04
NORM2dof3: 1.091499e-09 NORM2dof3/NORM2dof30: 4.213667e-01
isolid: 0 NORM2S: 3.161405e-13 NORM2S/NORM2S0: 4.095102e-04
5 TS dt 0.0001 time 0.0005
 FirstNewton = 0
    0 SNES Function norm 1.112772476542e+00
NORM2F: 1.112772e+00 NORM2F/NORM2F0: 1.000000e+00
NORM2dof0: 1.112769e+00 NORM2dof0/NORM2dof00: 1.000000e+00
NORM2dof1: 1.671487e-03 NORM2dof1/NORM2dof10: 1.000000e+00
NORM2dof2: 2.138731e-03 NORM2dof2/NORM2dof20: 1.000000e+00
NORM2dof3: 1.952195e-09 NORM2dof3/NORM2dof30: 1.000000e+00
isolid: 0 NORM2S: 7.289709e-10 NORM2S/NORM2S0: 1.000000e+00
 Tangent
       0 KSP Residual norm 1.112772476542e+00
      1 KSP Residual norm 6.472728739530e-03
      2 KSP Residual norm 5.601863101878e-04
      3 KSP Residual norm 1.094219394202e-04
      4 KSP Residual norm 1.197827287652e-05
      5 KSP Residual norm 4.378624107836e-06
      6 KSP Residual norm 9.290213397784e-07
      7 KSP Residual norm 2.835332962942e-07
      8 KSP Residual norm 4.388258838829e-08
      9 KSP Residual norm 9.543217089365e-09
    Linear solve converged due to CONVERGED_ATOL iterations 9
 FirstNewton = 0
    1 SNES Function norm 8.051824030650e-04
NORM2F: 8.051824e-04 NORM2F/NORM2F0: 7.235822e-04
NORM2dof0: 4.994773e-04 NORM2dof0/NORM2dof00: 4.488597e-04
NORM2dof1: 3.419594e-04 NORM2dof1/NORM2dof10: 2.045840e-01
NORM2dof2: 5.309472e-04 NORM2dof2/NORM2dof20: 2.482533e-01
NORM2dof3: 8.746695e-09 NORM2dof3/NORM2dof30: 4.480442e+00
isolid: 0 NORM2S: 2.578678e-10 NORM2S/NORM2S0: 3.537422e-01
      0 KSP Residual norm 8.051824030650e-04
      1 KSP Residual norm 7.090032819305e-04
      2 KSP Residual norm 1.402280433079e-04
      3 KSP Residual norm 2.027457124984e-05
      4 KSP Residual norm 5.456807297022e-06
      5 KSP Residual norm 5.624581671686e-07
      6 KSP Residual norm 4.803604857781e-08
      7 KSP Residual norm 1.792602936119e-08
      8 KSP Residual norm 3.571251954485e-09
 FirstNewton = 0
    2 SNES Function norm 2.079650561694e-04
NORM2F: 2.079651e-04 NORM2F/NORM2F0: 1.868891e-04
NORM2dof0: 1.300995e-04 NORM2dof0/NORM2dof00: 1.169151e-04
NORM2dof1: 8.490213e-05 NORM2dof1/NORM2dof10: 5.079439e-02
NORM2dof2: 1.382578e-04 NORM2dof2/NORM2dof20: 6.464475e-02
NORM2dof3: 3.501022e-09 NORM2dof3/NORM2dof30: 1.793378e+00
isolid: 0 NORM2S: 8.567461e-11 NORM2S/NORM2S0: 1.175282e-01
      0 KSP Residual norm 2.079650561694e-04
      1 KSP Residual norm 1.846996180432e-04
      2 KSP Residual norm 4.105605943457e-05
      3 KSP Residual norm 5.743945556658e-06
      4 KSP Residual norm 1.730123345092e-06
      5 KSP Residual norm 1.504872522672e-07
      6 KSP Residual norm 1.310593371116e-08
      7 KSP Residual norm 4.416474747728e-09
 FirstNewton = 0
    3 SNES Function norm 5.778224711718e-05
NORM2F: 5.778225e-05 NORM2F/NORM2F0: 5.192638e-05
NORM2dof0: 3.629464e-05 NORM2dof0/NORM2dof00: 3.261651e-05
NORM2dof1: 2.282530e-05 NORM2dof1/NORM2dof10: 1.365569e-02
NORM2dof2: 3.873619e-05 NORM2dof2/NORM2dof20: 1.811176e-02
NORM2dof3: 4.397594e-09 NORM2dof3/NORM2dof30: 2.252641e+00
isolid: 0 NORM2S: 2.846670e-11 NORM2S/NORM2S0: 3.905053e-02
      0 KSP Residual norm 5.778224711718e-05
      1 KSP Residual norm 5.155382303382e-05
      2 KSP Residual norm 1.230697151862e-05
      3 KSP Residual norm 1.663890537019e-06
      4 KSP Residual norm 5.483282502290e-07
      5 KSP Residual norm 4.065415243116e-08
      6 KSP Residual norm 3.914285942363e-09
 FirstNewton = 0
    4 SNES Function norm 1.713258989773e-05
NORM2F: 1.713259e-05 NORM2F/NORM2F0: 1.539631e-05
NORM2dof0: 1.072836e-05 NORM2dof0/NORM2dof00: 9.641136e-06
NORM2dof1: 6.688508e-06 NORM2dof1/NORM2dof10: 4.001533e-03
NORM2dof2: 1.156252e-05 NORM2dof2/NORM2dof20: 5.406250e-03
NORM2dof3: 3.854522e-09 NORM2dof3/NORM2dof30: 1.974456e+00
isolid: 0 NORM2S: 9.458957e-12 NORM2S/NORM2S0: 1.297577e-02
      0 KSP Residual norm 1.713258989773e-05
      1 KSP Residual norm 1.530342181040e-05
      2 KSP Residual norm 3.771930825589e-06
      3 KSP Residual norm 4.954811130992e-07
      4 KSP Residual norm 1.751498854623e-07
      5 KSP Residual norm 1.137052190475e-08
      6 KSP Residual norm 1.254186450126e-09
 FirstNewton = 0
    5 SNES Function norm 5.315313005638e-06
NORM2F: 5.315313e-06 NORM2F/NORM2F0: 4.776640e-06
NORM2dof0: 3.306069e-06 NORM2dof0/NORM2dof00: 2.971028e-06
NORM2dof1: 2.090715e-06 NORM2dof1/NORM2dof10: 1.250812e-03
NORM2dof2: 3.598801e-06 NORM2dof2/NORM2dof20: 1.682680e-03
NORM2dof3: 1.242143e-09 NORM2dof3/NORM2dof30: 6.362801e-01
isolid: 0 NORM2S: 3.143207e-12 NORM2S/NORM2S0: 4.311841e-03
      0 KSP Residual norm 5.315313005638e-06
      1 KSP Residual norm 4.744030372790e-06
      2 KSP Residual norm 1.176886394857e-06
      3 KSP Residual norm 1.514605816840e-07
      4 KSP Residual norm 5.615624395027e-08
      5 KSP Residual norm 3.346379171650e-09
 FirstNewton = 0
    6 SNES Function norm 1.695456618283e-06
NORM2F: 1.695457e-06 NORM2F/NORM2F0: 1.523633e-06
NORM2dof0: 1.046231e-06 NORM2dof0/NORM2dof00: 9.402053e-07
NORM2dof1: 6.777162e-07 NORM2dof1/NORM2dof10: 4.054572e-04
NORM2dof2: 1.149201e-06 NORM2dof2/NORM2dof20: 5.373283e-04
NORM2dof3: 3.330341e-09 NORM2dof3/NORM2dof30: 1.705947e+00
isolid: 0 NORM2S: 1.044556e-12 NORM2S/NORM2S0: 1.432918e-03
      0 KSP Residual norm 1.695456618283e-06
      1 KSP Residual norm 1.510656824024e-06
      2 KSP Residual norm 3.722813769344e-07
      3 KSP Residual norm 4.726531573676e-08
      4 KSP Residual norm 1.814889574859e-08
      5 KSP Residual norm 1.043202985458e-09
 FirstNewton = 0
    7 SNES Function norm 5.488124243595e-07
NORM2F: 5.488124e-07 NORM2F/NORM2F0: 4.931937e-07
NORM2dof0: 3.362464e-07 NORM2dof0/NORM2dof00: 3.021708e-07
NORM2dof1: 2.231989e-07 NORM2dof1/NORM2dof10: 1.335332e-04
NORM2dof2: 3.719067e-07 NORM2dof2/NORM2dof20: 1.738913e-04
NORM2dof3: 1.037682e-09 NORM2dof3/NORM2dof30: 5.315466e-01
isolid: 0 NORM2S: 3.471553e-13 NORM2S/NORM2S0: 4.762266e-04
6 TS dt 0.0001 time 0.0006
 FirstNewton = 0
    0 SNES Function norm 5.557686257693e-01
NORM2F: 5.557686e-01 NORM2F/NORM2F0: 1.000000e+00
NORM2dof0: 5.557657e-01 NORM2dof0/NORM2dof00: 1.000000e+00
NORM2dof1: 1.001497e-03 NORM2dof1/NORM2dof10: 1.000000e+00
NORM2dof2: 1.492390e-03 NORM2dof2/NORM2dof20: 1.000000e+00
NORM2dof3: 1.030785e-09 NORM2dof3/NORM2dof30: 1.000000e+00
isolid: 0 NORM2S: 7.529011e-10 NORM2S/NORM2S0: 1.000000e+00
 Tangent
       0 KSP Residual norm 5.557686257693e-01
      1 KSP Residual norm 4.308101913233e-03
      2 KSP Residual norm 4.227719191423e-04
      3 KSP Residual norm 8.135234781502e-05
      4 KSP Residual norm 1.250720250306e-05
      5 KSP Residual norm 2.780025026224e-06
      6 KSP Residual norm 5.680845267956e-07
      7 KSP Residual norm 1.846336664972e-07
      8 KSP Residual norm 4.149654544471e-08
      9 KSP Residual norm 7.832714199902e-09
 FirstNewton = 0
    1 SNES Function norm 6.119195708233e-04
NORM2F: 6.119196e-04 NORM2F/NORM2F0: 1.101033e-03
NORM2dof0: 4.033700e-04 NORM2dof0/NORM2dof00: 7.257914e-04
NORM2dof1: 2.552043e-04 NORM2dof1/NORM2dof10: 2.548229e-01
NORM2dof2: 3.828955e-04 NORM2dof2/NORM2dof20: 2.565653e-01
NORM2dof3: 7.733372e-09 NORM2dof3/NORM2dof30: 7.502407e+00
isolid: 0 NORM2S: 2.412384e-10 NORM2S/NORM2S0: 3.204118e-01
      0 KSP Residual norm 6.119195708233e-04
      1 KSP Residual norm 5.428792080573e-04
      2 KSP Residual norm 1.197882344778e-04
      3 KSP Residual norm 1.633949861408e-05
      4 KSP Residual norm 5.557061306266e-06
      5 KSP Residual norm 3.922465545133e-07
      6 KSP Residual norm 4.267772662462e-08
      7 KSP Residual norm 1.303142028347e-08
      8 KSP Residual norm 2.692758385310e-09
 FirstNewton = 0
    2 SNES Function norm 1.696724438232e-04
NORM2F: 1.696724e-04 NORM2F/NORM2F0: 3.052933e-04
NORM2dof0: 1.086907e-04 NORM2dof0/NORM2dof00: 1.955692e-04
NORM2dof1: 6.868959e-05 NORM2dof1/NORM2dof10: 6.858694e-02
NORM2dof2: 1.107105e-04 NORM2dof2/NORM2dof20: 7.418335e-02
NORM2dof3: 2.657203e-09 NORM2dof3/NORM2dof30: 2.577843e+00
isolid: 0 NORM2S: 8.017256e-11 NORM2S/NORM2S0: 1.064848e-01
      0 KSP Residual norm 1.696724438232e-04
      1 KSP Residual norm 1.517390431674e-04
      2 KSP Residual norm 3.556628682970e-05
      3 KSP Residual norm 4.819195192174e-06
      4 KSP Residual norm 1.765384300045e-06
      5 KSP Residual norm 1.050503576150e-07
      6 KSP Residual norm 1.330083564334e-08
      7 KSP Residual norm 3.498472973310e-09
 FirstNewton = 0
    3 SNES Function norm 5.049959409725e-05
NORM2F: 5.049959e-05 NORM2F/NORM2F0: 9.086442e-05
NORM2dof0: 3.172853e-05 NORM2dof0/NORM2dof00: 5.708976e-05
NORM2dof1: 2.041142e-05 NORM2dof1/NORM2dof10: 2.038091e-02
NORM2dof2: 3.356909e-05 NORM2dof2/NORM2dof20: 2.249350e-02
NORM2dof3: 3.490439e-09 NORM2dof3/NORM2dof30: 3.386193e+00
isolid: 0 NORM2S: 2.664408e-11 NORM2S/NORM2S0: 3.538855e-02
      0 KSP Residual norm 5.049959409725e-05
      1 KSP Residual norm 4.530238901014e-05
      2 KSP Residual norm 1.085321676077e-05
      3 KSP Residual norm 1.456886257380e-06
      4 KSP Residual norm 5.618155714071e-07
      5 KSP Residual norm 2.967069149021e-08
      6 KSP Residual norm 4.372284443552e-09
 FirstNewton = 0
    4 SNES Function norm 1.574809898934e-05
NORM2F: 1.574810e-05 NORM2F/NORM2F0: 2.833571e-05
NORM2dof0: 9.766393e-06 NORM2dof0/NORM2dof00: 1.757286e-05
NORM2dof1: 6.454294e-06 NORM2dof1/NORM2dof10: 6.444649e-03
NORM2dof2: 1.053386e-05 NORM2dof2/NORM2dof20: 7.058383e-03
NORM2dof3: 4.348876e-09 NORM2dof3/NORM2dof30: 4.218993e+00
isolid: 0 NORM2S: 8.855007e-12 NORM2S/NORM2S0: 1.176118e-02
      0 KSP Residual norm 1.574809898934e-05
      1 KSP Residual norm 1.413040325835e-05
      2 KSP Residual norm 3.381260108228e-06
      3 KSP Residual norm 4.509547589190e-07
      4 KSP Residual norm 1.803036721979e-07
      5 KSP Residual norm 8.837335283035e-09
 FirstNewton = 0
    5 SNES Function norm 5.042908584888e-06
NORM2F: 5.042909e-06 NORM2F/NORM2F0: 9.073755e-06
NORM2dof0: 3.098911e-06 NORM2dof0/NORM2dof00: 5.575930e-06
NORM2dof1: 2.103952e-06 NORM2dof1/NORM2dof10: 2.100808e-03
NORM2dof2: 3.376535e-06 NORM2dof2/NORM2dof20: 2.262501e-03
NORM2dof3: 8.765087e-09 NORM2dof3/NORM2dof30: 8.503309e+00
isolid: 0 NORM2S: 2.943066e-12 NORM2S/NORM2S0: 3.908967e-03
      0 KSP Residual norm 5.042908584888e-06
      1 KSP Residual norm 4.519905967727e-06
      2 KSP Residual norm 1.068318382709e-06
      3 KSP Residual norm 1.420069385766e-07
      4 KSP Residual norm 5.830280955734e-08
      5 KSP Residual norm 2.750675538983e-09
 FirstNewton = 0
    6 SNES Function norm 1.635509967178e-06
NORM2F: 1.635510e-06 NORM2F/NORM2F0: 2.942789e-06
NORM2dof0: 9.990627e-07 NORM2dof0/NORM2dof00: 1.797633e-06
NORM2dof1: 6.934171e-07 NORM2dof1/NORM2dof10: 6.923809e-04
NORM2dof2: 1.093587e-06 NORM2dof2/NORM2dof20: 7.327752e-04
NORM2dof3: 2.722771e-09 NORM2dof3/NORM2dof30: 2.641453e+00
isolid: 0 NORM2S: 9.782353e-13 NORM2S/NORM2S0: 1.299288e-03
      0 KSP Residual norm 1.635509967178e-06
      1 KSP Residual norm 1.463952539788e-06
      2 KSP Residual norm 3.407079191494e-07
      3 KSP Residual norm 4.528042856809e-08
      4 KSP Residual norm 1.890678753386e-08
      5 KSP Residual norm 8.690371702212e-10
 FirstNewton = 0
    7 SNES Function norm 5.336804857256e-07
NORM2F: 5.336805e-07 NORM2F/NORM2F0: 9.602566e-07
NORM2dof0: 3.248093e-07 NORM2dof0/NORM2dof00: 5.844357e-07
NORM2dof1: 2.291741e-07 NORM2dof1/NORM2dof10: 2.288316e-04
NORM2dof2: 3.560790e-07 NORM2dof2/NORM2dof20: 2.385964e-04
NORM2dof3: 8.587620e-10 NORM2dof3/NORM2dof30: 8.331142e-01
isolid: 0 NORM2S: 3.251805e-13 NORM2S/NORM2S0: 4.319033e-04
7 TS dt 0.0001 time 0.0007
 FirstNewton = 0
    0 SNES Function norm 2.775423054247e-01
NORM2F: 2.775423e-01 NORM2F/NORM2F0: 1.000000e+00
NORM2dof0: 2.775373e-01 NORM2dof0/NORM2dof00: 1.000000e+00
NORM2dof1: 9.394023e-04 NORM2dof1/NORM2dof10: 1.000000e+00
NORM2dof2: 1.366894e-03 NORM2dof2/NORM2dof20: 1.000000e+00
NORM2dof3: 9.448906e-10 NORM2dof3/NORM2dof30: 1.000000e+00
isolid: 0 NORM2S: 7.363841e-10 NORM2S/NORM2S0: 1.000000e+00
 Tangent
       0 KSP Residual norm 2.775423054247e-01
      1 KSP Residual norm 4.269855711117e-03
      2 KSP Residual norm 4.137754623703e-04
      3 KSP Residual norm 6.257024540873e-05
      4 KSP Residual norm 1.830313448326e-05
      5 KSP Residual norm 1.182578644587e-06
      6 KSP Residual norm 2.163436584089e-07
      7 KSP Residual norm 4.685071780533e-08
      8 KSP Residual norm 6.152206756855e-09
 FirstNewton = 0
    1 SNES Function norm 6.058721968924e-04
NORM2F: 6.058722e-04 NORM2F/NORM2F0: 2.182990e-03
NORM2dof0: 3.913727e-04 NORM2dof0/NORM2dof00: 1.410162e-03
NORM2dof1: 2.543010e-04 NORM2dof1/NORM2dof10: 2.707051e-01
NORM2dof2: 3.863153e-04 NORM2dof2/NORM2dof20: 2.826227e-01
NORM2dof3: 6.005638e-09 NORM2dof3/NORM2dof30: 6.355908e+00
isolid: 0 NORM2S: 2.488856e-10 NORM2S/NORM2S0: 3.379834e-01
      0 KSP Residual norm 6.058721968924e-04
      1 KSP Residual norm 5.411553979768e-04
      2 KSP Residual norm 1.180236654315e-04
      3 KSP Residual norm 1.697724155124e-05
      4 KSP Residual norm 6.336195845718e-06
      5 KSP Residual norm 3.515628829243e-07
      6 KSP Residual norm 5.242311132852e-08
      7 KSP Residual norm 1.380587218576e-08
      8 KSP Residual norm 2.724453873676e-09
 FirstNewton = 0
    2 SNES Function norm 1.725039868181e-04
NORM2F: 1.725040e-04 NORM2F/NORM2F0: 6.215412e-04
NORM2dof0: 1.089620e-04 NORM2dof0/NORM2dof00: 3.926029e-04
NORM2dof1: 7.210643e-05 NORM2dof1/NORM2dof10: 7.675778e-02
NORM2dof2: 1.126303e-04 NORM2dof2/NORM2dof20: 8.239869e-02
NORM2dof3: 2.695597e-09 NORM2dof3/NORM2dof30: 2.852814e+00
isolid: 0 NORM2S: 8.270382e-11 NORM2S/NORM2S0: 1.123107e-01
      0 KSP Residual norm 1.725039868181e-04
      1 KSP Residual norm 1.553656482132e-04
      2 KSP Residual norm 3.565703589611e-05
      3 KSP Residual norm 5.076540574263e-06
      4 KSP Residual norm 2.004317949710e-06
      5 KSP Residual norm 9.606215545587e-08
      6 KSP Residual norm 1.699424479149e-08
      7 KSP Residual norm 4.430215416022e-09
 FirstNewton = 0
    3 SNES Function norm 5.253149651021e-05
NORM2F: 5.253150e-05 NORM2F/NORM2F0: 1.892738e-04
NORM2dof0: 3.278788e-05 NORM2dof0/NORM2dof00: 1.181386e-04
NORM2dof1: 2.212572e-05 NORM2dof1/NORM2dof10: 2.355298e-02
NORM2dof2: 3.456827e-05 NORM2dof2/NORM2dof20: 2.528965e-02
NORM2dof3: 4.415698e-09 NORM2dof3/NORM2dof30: 4.673238e+00
isolid: 0 NORM2S: 2.748235e-11 NORM2S/NORM2S0: 3.732067e-02
      0 KSP Residual norm 5.253149651021e-05
      1 KSP Residual norm 4.744942833481e-05
      2 KSP Residual norm 1.104106101204e-05
      3 KSP Residual norm 1.556191460705e-06
      4 KSP Residual norm 6.368539122699e-07
      5 KSP Residual norm 2.808233245834e-08
      6 KSP Residual norm 5.736661456826e-09
 FirstNewton = 0
    4 SNES Function norm 1.663887140036e-05
NORM2F: 1.663887e-05 NORM2F/NORM2F0: 5.995076e-05
NORM2dof0: 1.030264e-05 NORM2dof0/NORM2dof00: 3.712162e-05
NORM2dof1: 7.100550e-06 NORM2dof1/NORM2dof10: 7.558583e-03
NORM2dof2: 1.096767e-05 NORM2dof2/NORM2dof20: 8.023793e-03
NORM2dof3: 5.709079e-09 NORM2dof3/NORM2dof30: 6.042053e+00
isolid: 0 NORM2S: 9.132628e-12 NORM2S/NORM2S0: 1.240199e-02
      0 KSP Residual norm 1.663887140036e-05
      1 KSP Residual norm 1.503087551143e-05
      2 KSP Residual norm 3.475166392784e-06
      3 KSP Residual norm 4.871767640289e-07
      4 KSP Residual norm 2.043381513299e-07
      5 KSP Residual norm 8.605193317307e-09
 FirstNewton = 0
    5 SNES Function norm 5.376364923636e-06
NORM2F: 5.376365e-06 NORM2F/NORM2F0: 1.937133e-05
NORM2dof0: 3.308988e-06 NORM2dof0/NORM2dof00: 1.192268e-05
NORM2dof1: 2.324596e-06 NORM2dof1/NORM2dof10: 2.474548e-03
NORM2dof2: 3.542891e-06 NORM2dof2/NORM2dof20: 2.591929e-03
NORM2dof3: 8.464166e-09 NORM2dof3/NORM2dof30: 8.957826e+00
isolid: 0 NORM2S: 3.035018e-12 NORM2S/NORM2S0: 4.121516e-03
      0 KSP Residual norm 5.376364923636e-06
      1 KSP Residual norm 4.852079403286e-06
      2 KSP Residual norm 1.106012870919e-06
      3 KSP Residual norm 1.548652898390e-07
      4 KSP Residual norm 6.622322636931e-08
      5 KSP Residual norm 2.715252438436e-09
 FirstNewton = 0
    6 SNES Function norm 1.753075075882e-06
NORM2F: 1.753075e-06 NORM2F/NORM2F0: 6.316425e-06
NORM2dof0: 1.074629e-06 NORM2dof0/NORM2dof00: 3.872016e-06
NORM2dof1: 7.662426e-07 NORM2dof1/NORM2dof10: 8.156704e-04
NORM2dof2: 1.153824e-06 NORM2dof2/NORM2dof20: 8.441211e-04
NORM2dof3: 2.661484e-09 NORM2dof3/NORM2dof30: 2.816712e+00
isolid: 0 NORM2S: 1.008697e-12 NORM2S/NORM2S0: 1.369798e-03
      0 KSP Residual norm 1.753075075882e-06
      1 KSP Residual norm 1.580262431510e-06
      2 KSP Residual norm 3.546338640452e-07
      3 KSP Residual norm 4.967314561981e-08
      4 KSP Residual norm 2.147538404335e-08
      5 KSP Residual norm 8.683473688031e-10
 FirstNewton = 0
    7 SNES Function norm 5.738448616702e-07
NORM2F: 5.738449e-07 NORM2F/NORM2F0: 2.067594e-06
NORM2dof0: 3.508632e-07 NORM2dof0/NORM2dof00: 1.264202e-06
NORM2dof1: 2.529404e-07 NORM2dof1/NORM2dof10: 2.692568e-04
NORM2dof2: 3.771119e-07 NORM2dof2/NORM2dof20: 2.758896e-04
NORM2dof3: 8.491729e-10 NORM2dof3/NORM2dof30: 8.986997e-01
isolid: 0 NORM2S: 3.352726e-13 NORM2S/NORM2S0: 4.552959e-04
8 TS dt 0.0001 time 0.0008
 FirstNewton = 0
    0 SNES Function norm 1.385893632817e-01
NORM2F: 1.385894e-01 NORM2F/NORM2F0: 1.000000e+00
NORM2dof0: 1.385817e-01 NORM2dof0/NORM2dof00: 1.000000e+00
NORM2dof1: 8.167800e-04 NORM2dof1/NORM2dof10: 1.000000e+00
NORM2dof2: 1.209582e-03 NORM2dof2/NORM2dof20: 1.000000e+00
NORM2dof3: 8.506108e-10 NORM2dof3/NORM2dof30: 1.000000e+00
isolid: 0 NORM2S: 7.406001e-10 NORM2S/NORM2S0: 1.000000e+00
 Tangent
       0 KSP Residual norm 1.385893632817e-01
      1 KSP Residual norm 3.853548368170e-03
      2 KSP Residual norm 3.707357575994e-04
      3 KSP Residual norm 5.769861871248e-05
      4 KSP Residual norm 2.100381923635e-05
      5 KSP Residual norm 8.893431500320e-07
      6 KSP Residual norm 2.009416286560e-07
      7 KSP Residual norm 4.740466731912e-08
      8 KSP Residual norm 6.721899156094e-09
 FirstNewton = 0
    1 SNES Function norm 5.458960685713e-04
NORM2F: 5.458961e-04 NORM2F/NORM2F0: 3.938946e-03
NORM2dof0: 3.534774e-04 NORM2dof0/NORM2dof00: 2.550679e-03
NORM2dof1: 2.321890e-04 NORM2dof1/NORM2dof10: 2.842736e-01
NORM2dof2: 3.451732e-04 NORM2dof2/NORM2dof20: 2.853658e-01
NORM2dof3: 6.576758e-09 NORM2dof3/NORM2dof30: 7.731806e+00
isolid: 0 NORM2S: 2.442299e-10 NORM2S/NORM2S0: 3.297730e-01
      0 KSP Residual norm 5.458960685713e-04
      1 KSP Residual norm 4.912302501246e-04
      2 KSP Residual norm 1.074476565735e-04
      3 KSP Residual norm 1.586359196803e-05
      4 KSP Residual norm 6.575113039432e-06
      5 KSP Residual norm 2.804888911031e-07
      6 KSP Residual norm 6.744668665791e-08
      7 KSP Residual norm 1.905955898189e-08
      8 KSP Residual norm 2.902711698349e-09
 FirstNewton = 0
    2 SNES Function norm 1.632516979105e-04
NORM2F: 1.632517e-04 NORM2F/NORM2F0: 1.177953e-03
NORM2dof0: 1.029477e-04 NORM2dof0/NORM2dof00: 7.428668e-04
NORM2dof1: 7.062360e-05 NORM2dof1/NORM2dof10: 8.646588e-02
NORM2dof2: 1.051912e-04 NORM2dof2/NORM2dof20: 8.696494e-02
NORM2dof3: 2.823042e-09 NORM2dof3/NORM2dof30: 3.318841e+00
isolid: 0 NORM2S: 8.115202e-11 NORM2S/NORM2S0: 1.095760e-01
      0 KSP Residual norm 1.632516979105e-04
      1 KSP Residual norm 1.479469598427e-04
      2 KSP Residual norm 3.316404328354e-05
      3 KSP Residual norm 4.895260241875e-06
      4 KSP Residual norm 2.078626977422e-06
      5 KSP Residual norm 8.287175616146e-08
      6 KSP Residual norm 2.233493871857e-08
      7 KSP Residual norm 6.438601693487e-09
 FirstNewton = 0
    3 SNES Function norm 5.143135506878e-05
NORM2F: 5.143136e-05 NORM2F/NORM2F0: 3.711061e-04
NORM2dof0: 3.196418e-05 NORM2dof0/NORM2dof00: 2.306523e-04
NORM2dof1: 2.259882e-05 NORM2dof1/NORM2dof10: 2.766818e-02
NORM2dof2: 3.335819e-05 NORM2dof2/NORM2dof20: 2.757828e-02
NORM2dof3: 6.414181e-09 NORM2dof3/NORM2dof30: 7.540676e+00
isolid: 0 NORM2S: 2.696541e-11 NORM2S/NORM2S0: 3.641021e-02
      0 KSP Residual norm 5.143135506878e-05
      1 KSP Residual norm 4.669521743404e-05
      2 KSP Residual norm 1.043211373259e-05
      3 KSP Residual norm 1.536325540407e-06
      4 KSP Residual norm 6.617903550189e-07
      5 KSP Residual norm 2.561013724570e-08
      6 KSP Residual norm 7.374415839350e-09
 FirstNewton = 0
    4 SNES Function norm 1.659750028902e-05
NORM2F: 1.659750e-05 NORM2F/NORM2F0: 1.197603e-04
NORM2dof0: 1.024408e-05 NORM2dof0/NORM2dof00: 7.392087e-05
NORM2dof1: 7.385081e-06 NORM2dof1/NORM2dof10: 9.041701e-03
NORM2dof2: 1.077016e-05 NORM2dof2/NORM2dof20: 8.904039e-03
NORM2dof3: 7.327710e-09 NORM2dof3/NORM2dof30: 8.614645e+00
isolid: 0 NORM2S: 8.960617e-12 NORM2S/NORM2S0: 1.209913e-02
      0 KSP Residual norm 1.659750028902e-05
      1 KSP Residual norm 1.506654439073e-05
      2 KSP Residual norm 3.319389246244e-06
      3 KSP Residual norm 4.888640676423e-07
      4 KSP Residual norm 2.127800501644e-07
      5 KSP Residual norm 8.109316682656e-09
 FirstNewton = 0
    5 SNES Function norm 5.413916997573e-06
NORM2F: 5.413917e-06 NORM2F/NORM2F0: 3.906445e-05
NORM2dof0: 3.328422e-06 NORM2dof0/NORM2dof00: 2.401777e-05
NORM2dof1: 2.431531e-06 NORM2dof1/NORM2dof10: 2.976972e-03
NORM2dof2: 3.509942e-06 NORM2dof2/NORM2dof20: 2.901782e-03
NORM2dof3: 7.859930e-09 NORM2dof3/NORM2dof30: 9.240336e+00
isolid: 0 NORM2S: 2.977848e-12 NORM2S/NORM2S0: 4.020858e-03
      0 KSP Residual norm 5.413916997573e-06
      1 KSP Residual norm 4.910448170144e-06
      2 KSP Residual norm 1.065668630039e-06
      3 KSP Residual norm 1.574350385535e-07
      4 KSP Residual norm 6.925622667484e-08
      5 KSP Residual norm 2.607504720195e-09
 FirstNewton = 0
    6 SNES Function norm 1.773323109936e-06
NORM2F: 1.773323e-06 NORM2F/NORM2F0: 1.279552e-05
NORM2dof0: 1.087890e-06 NORM2dof0/NORM2dof00: 7.850174e-06
NORM2dof1: 8.018131e-07 NORM2dof1/NORM2dof10: 9.816757e-04
NORM2dof2: 1.148155e-06 NORM2dof2/NORM2dof20: 9.492162e-04
NORM2dof3: 2.517789e-09 NORM2dof3/NORM2dof30: 2.959978e+00
isolid: 0 NORM2S: 9.897092e-13 NORM2S/NORM2S0: 1.336361e-03
      0 KSP Residual norm 1.773323109936e-06
      1 KSP Residual norm 1.606955446659e-06
      2 KSP Residual norm 3.438603892077e-07
      3 KSP Residual norm 5.087307407291e-08
      4 KSP Residual norm 2.247817580603e-08
      5 KSP Residual norm 8.435326502553e-10
 FirstNewton = 0
    7 SNES Function norm 5.817914623605e-07
NORM2F: 5.817915e-07 NORM2F/NORM2F0: 4.197952e-06
NORM2dof0: 3.565108e-07 NORM2dof0/NORM2dof00: 2.572568e-06
NORM2dof1: 2.642915e-07 NORM2dof1/NORM2dof10: 3.235774e-04
NORM2dof2: 3.762056e-07 NORM2dof2/NORM2dof20: 3.110212e-04
NORM2dof3: 8.131382e-10 NORM2dof3/NORM2dof30: 9.559462e-01
isolid: 0 NORM2S: 3.289688e-13 NORM2S/NORM2S0: 4.441922e-04
9 TS dt 0.0001 time 0.0009
 FirstNewton = 0
    0 SNES Function norm 6.920784879396e-02
NORM2F: 6.920785e-02 NORM2F/NORM2F0: 1.000000e+00
NORM2dof0: 6.919380e-02 NORM2dof0/NORM2dof00: 1.000000e+00
NORM2dof1: 7.883678e-04 NORM2dof1/NORM2dof10: 1.000000e+00
NORM2dof2: 1.150385e-03 NORM2dof2/NORM2dof20: 1.000000e+00
NORM2dof3: 8.138305e-10 NORM2dof3/NORM2dof30: 1.000000e+00
isolid: 0 NORM2S: 7.356848e-10 NORM2S/NORM2S0: 1.000000e+00
 Tangent
       0 KSP Residual norm 6.920784879396e-02
      1 KSP Residual norm 3.840979919308e-03
      2 KSP Residual norm 3.543503013487e-04
      3 KSP Residual norm 5.444624827056e-05
      4 KSP Residual norm 2.262808790207e-05
      5 KSP Residual norm 1.003758193739e-06
      6 KSP Residual norm 2.193207147381e-07
      7 KSP Residual norm 6.067632530906e-08
      8 KSP Residual norm 9.551578683847e-09
 FirstNewton = 0
    1 SNES Function norm 5.466576051971e-04
NORM2F: 5.466576e-04 NORM2F/NORM2F0: 7.898780e-03
NORM2dof0: 3.521259e-04 NORM2dof0/NORM2dof00: 5.088981e-03
NORM2dof1: 2.375164e-04 NORM2dof1/NORM2dof10: 3.012762e-01
NORM2dof2: 3.441334e-04 NORM2dof2/NORM2dof20: 2.991463e-01
NORM2dof3: 9.319002e-09 NORM2dof3/NORM2dof30: 1.145079e+01
isolid: 0 NORM2S: 2.449213e-10 NORM2S/NORM2S0: 3.329160e-01
      0 KSP Residual norm 5.466576051971e-04
      1 KSP Residual norm 4.945864699566e-04
      2 KSP Residual norm 1.056549484421e-04
      3 KSP Residual norm 1.621174236636e-05
      4 KSP Residual norm 6.948662841776e-06
      5 KSP Residual norm 2.745449773792e-07
      6 KSP Residual norm 8.503882365282e-08
      7 KSP Residual norm 2.478941077827e-08
      8 KSP Residual norm 3.159115505876e-09
 FirstNewton = 0
    2 SNES Function norm 1.662785103877e-04
NORM2F: 1.662785e-04 NORM2F/NORM2F0: 2.402596e-03
NORM2dof0: 1.046141e-04 NORM2dof0/NORM2dof00: 1.511899e-03
NORM2dof1: 7.357758e-05 NORM2dof1/NORM2dof10: 9.332901e-02
NORM2dof2: 1.062581e-04 NORM2dof2/NORM2dof20: 9.236740e-02
NORM2dof3: 3.025326e-09 NORM2dof3/NORM2dof30: 3.717391e+00
isolid: 0 NORM2S: 8.138123e-11 NORM2S/NORM2S0: 1.106197e-01
      0 KSP Residual norm 1.662785103877e-04
      1 KSP Residual norm 1.514394275726e-04
      2 KSP Residual norm 3.293021013964e-05
      3 KSP Residual norm 5.065683666883e-06
      4 KSP Residual norm 2.197796599954e-06
      5 KSP Residual norm 8.377549835731e-08
      6 KSP Residual norm 2.763811642273e-08
      7 KSP Residual norm 8.053559466082e-09
 FirstNewton = 0
    3 SNES Function norm 5.297309933210e-05
NORM2F: 5.297310e-05 NORM2F/NORM2F0: 7.654204e-04
NORM2dof0: 3.294885e-05 NORM2dof0/NORM2dof00: 4.761821e-04
NORM2dof1: 2.376369e-05 NORM2dof1/NORM2dof10: 3.014290e-02
NORM2dof2: 3.399720e-05 NORM2dof2/NORM2dof20: 2.955289e-02
NORM2dof3: 8.031677e-09 NORM2dof3/NORM2dof30: 9.868979e+00
isolid: 0 NORM2S: 2.704128e-11 NORM2S/NORM2S0: 3.675661e-02
      0 KSP Residual norm 5.297309933210e-05
      1 KSP Residual norm 4.831742479884e-05
      2 KSP Residual norm 1.041821567953e-05
      3 KSP Residual norm 1.602912776375e-06
      4 KSP Residual norm 7.002728503792e-07
      5 KSP Residual norm 2.629298149031e-08
      6 KSP Residual norm 8.976249599680e-09
 FirstNewton = 0
    4 SNES Function norm 1.721496805320e-05
NORM2F: 1.721497e-05 NORM2F/NORM2F0: 2.487430e-04
NORM2dof0: 1.065078e-05 NORM2dof0/NORM2dof00: 1.539268e-04
NORM2dof1: 7.797521e-06 NORM2dof1/NORM2dof10: 9.890715e-03
NORM2dof2: 1.105055e-05 NORM2dof2/NORM2dof20: 9.605958e-03
NORM2dof3: 8.905869e-09 NORM2dof3/NORM2dof30: 1.094315e+01
isolid: 0 NORM2S: 8.985793e-12 NORM2S/NORM2S0: 1.221419e-02
      0 KSP Residual norm 1.721496805320e-05
      1 KSP Residual norm 1.569610862174e-05
      2 KSP Residual norm 3.332462853617e-06
      3 KSP Residual norm 5.131753815245e-07
      4 KSP Residual norm 2.254319663149e-07
      5 KSP Residual norm 8.406726529561e-09
 FirstNewton = 0
    5 SNES Function norm 5.635189172796e-06
NORM2F: 5.635189e-06 NORM2F/NORM2F0: 8.142413e-05
NORM2dof0: 3.478446e-06 NORM2dof0/NORM2dof00: 5.027106e-05
NORM2dof1: 2.568346e-06 NORM2dof1/NORM2dof10: 3.257801e-03
NORM2dof2: 3.613767e-06 NORM2dof2/NORM2dof20: 3.141354e-03
NORM2dof3: 8.062315e-09 NORM2dof3/NORM2dof30: 9.906626e+00
isolid: 0 NORM2S: 2.986208e-12 NORM2S/NORM2S0: 4.059086e-03
      0 KSP Residual norm 5.635189172796e-06
      1 KSP Residual norm 5.133841145077e-06
      2 KSP Residual norm 1.075280531297e-06
      3 KSP Residual norm 1.662274327203e-07
      4 KSP Residual norm 7.353559890411e-08
      5 KSP Residual norm 2.731409706923e-09
 FirstNewton = 0
    6 SNES Function norm 1.849165463014e-06
NORM2F: 1.849165e-06 NORM2F/NORM2F0: 2.671901e-05
NORM2dof0: 1.140254e-06 NORM2dof0/NORM2dof00: 1.647913e-05
NORM2dof1: 8.462086e-07 NORM2dof1/NORM2dof10: 1.073368e-03
NORM2dof2: 1.184550e-06 NORM2dof2/NORM2dof20: 1.029699e-03
NORM2dof3: 2.610444e-09 NORM2dof3/NORM2dof30: 3.207602e+00
isolid: 0 NORM2S: 9.924838e-13 NORM2S/NORM2S0: 1.349061e-03
      0 KSP Residual norm 1.849165463014e-06
      1 KSP Residual norm 1.683229821122e-06
      2 KSP Residual norm 3.481723775150e-07
      3 KSP Residual norm 5.386575445536e-08
      4 KSP Residual norm 2.387797527539e-08
      5 KSP Residual norm 8.874191797530e-10
 FirstNewton = 0
    7 SNES Function norm 6.071769270733e-07
NORM2F: 6.071769e-07 NORM2F/NORM2F0: 8.773238e-06
NORM2dof0: 3.742541e-07 NORM2dof0/NORM2dof00: 5.408782e-06
NORM2dof1: 2.785757e-07 NORM2dof1/NORM2dof10: 3.533575e-04
NORM2dof2: 3.885776e-07 NORM2dof2/NORM2dof20: 3.377804e-04
NORM2dof3: 8.472476e-10 NORM2dof3/NORM2dof30: 1.041061e+00
isolid: 0 NORM2S: 3.298895e-13 NORM2S/NORM2S0: 4.484114e-04
10 TS dt 0.0001 time 0.001
TS Object: 2 MPI processes
  type: alpha
    Alpha_m=0.833333, Alpha_f=0.666667, Gamma=0.666667
  maximum steps=10
  maximum time=5000.
  total number of nonlinear solver iterations=63
  total number of linear solver iterations=412
  total number of nonlinear solve failures=0
  total number of rejected steps=0
  using relative error tolerance of 0.0001,   using absolute error tolerance of 0.0001
  TSAdapt Object: 2 MPI processes
    type: none
  SNES Object: 2 MPI processes
    type: newtonls
    maximum iterations=150, maximum function evaluations=10000
    tolerances: relative=0.001, absolute=1e-50, solution=1e-08
    total number of linear solver iterations=44
    total number of function evaluations=8
    norm schedule ALWAYS
    Jacobian is rebuilt every 20 SNES iterations
    SNESLineSearch Object: 2 MPI processes
      type: bt
        interpolation: cubic
        alpha=1.000000e-04
      maxstep=1.000000e+08, minlambda=1.000000e-12
      tolerances: relative=1.000000e-08, absolute=1.000000e-15, lambda=1.000000e-08
      maximum iterations=40
    KSP Object: 2 MPI processes
      type: fgmres
        restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
        happy breakdown tolerance 1e-30
      maximum iterations=10000, initial guess is zero
      tolerances:  relative=0., absolute=1e-08, divergence=10000.
      right preconditioning
      using UNPRECONDITIONED norm type for convergence test
    PC Object: 2 MPI processes
      type: fieldsplit
        FieldSplit with Schur preconditioner, factorization UPPER
        Preconditioner for the Schur complement formed from user provided matrix
        Split info:
        Split number 0 Defined by IS
        Split number 1 Defined by IS
        KSP solver for A00 block
      KSP Object: (fieldsplit_m_) 2 MPI processes
        type: fgmres
        maximum iterations=5, initial guess is zero
        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
        using NONE norm type for convergence test
      PC Object: (fieldsplit_m_) 2 MPI processes
        type: bjacobi
          number of blocks = 2
          Local solve is same for all blocks, in the following KSP and PC objects:
        KSP Object: (fieldsplit_m_sub_) 1 MPI processes
          type: preonly
          left preconditioning
        PC Object: (fieldsplit_m_sub_) 1 MPI processes
          type: ilu
            out-of-place factorization
            0 levels of fill
            tolerance for zero pivot 2.22045e-14
            matrix ordering: natural
            factor fill ratio given 1., needed 1.
              Factored matrix follows:
                Mat Object: 1 MPI processes
                  type: seqaij
                  rows=12000, cols=12000
                  package used to perform factorization: petsc
                  total: nonzeros=5527200, allocated nonzeros=5527200
                  total number of mallocs used during MatSetValues calls =0
                    not using I-node routines
          linear system matrix = precond matrix:
          Mat Object: (fieldsplit_m_) 1 MPI processes
            type: seqaij
        Mat Object: (fieldsplit_m_) 2 MPI processes
          type: mpiaij
          rows=26800, cols=26800
          total: nonzeros=13445200, allocated nonzeros=13445200
            not using I-node (on process 0) routines
        KSP solver for S = A11 - A10 inv(A00) A01
      KSP Object: (fieldsplit_p_) 2 MPI processes
        type: preonly
      PC Object: (fieldsplit_p_) 2 MPI processes
        type: ksp
          KSP and PC on KSP preconditioner follow
        KSP Object: (fieldsplit_p_ksp_) 2 MPI processes
          type: cg
        PC Object: (fieldsplit_p_ksp_) 2 MPI processes
          type: bjacobi
          KSP Object: (fieldsplit_p_ksp_sub_) 1 MPI processes
            type: preonly
          PC Object: (fieldsplit_p_ksp_sub_) 1 MPI processes
            type: ilu
              0 levels of fill
                    type: seqaij
                    rows=4000, cols=4000
                    total: nonzeros=440000, allocated nonzeros=440000
              type: seqaij
          Mat Object: 2 MPI processes
            type: mpiaij
            rows=8800, cols=8800
            total: nonzeros=1040000, allocated nonzeros=1040000
        linear system matrix followed by preconditioner matrix:
        Mat Object: (fieldsplit_p_) 2 MPI processes
          type: schurcomplement
            Schur complement A11 - A10 inv(A00) A01
            A11
                type: mpiaij
            A10
                type: mpiaij
                rows=8800, cols=26800
                total: nonzeros=3756000, allocated nonzeros=3756000
            KSP of A00
        type: fgmres
        type: bjacobi
          type: preonly
          type: ilu
            0 levels of fill
                  type: seqaij
            type: seqaij
          type: mpiaij
            A01
                type: mpiaij
                rows=26800, cols=8800
          type: mpiaij
        type: mpiaij
        rows=35600, cols=35600
        total: nonzeros=21997200, allocated nonzeros=21997200
solve: ndof=    35600 time= 5.354099e+02 time/ndof= 1.503960e-02
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./fsisurface on a optimO3fftw391 named ubuntu with 2 processors, by hcasquer Mon Apr 30 13:52:22 2018
Using Petsc Release Version 3.9.1, unknown
                         Max       Max/Min        Avg      Total
Time (sec):           5.820e+02      1.00000   5.820e+02
Objects:              2.766e+03      2.54228   1.927e+03
Flop:                 1.438e+11      1.08887   1.379e+11  2.758e+11
Flop/sec:            2.470e+08      1.08887   2.369e+08  4.738e+08
MPI Messages:         6.960e+03      1.03333   6.848e+03  1.370e+04
MPI Message Lengths:  6.752e+08      1.00021   9.858e+04  1.350e+09
MPI Reductions:       1.124e+04      1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flop
                            and VecAXPY() for complex vectors of length N --> 8N flop
Summary of Stages:   ----- Time ------  ----- Flop -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 5.8203e+02 100.0%  2.7578e+11 100.0%  1.370e+04 100.0%  9.858e+04      100.0%  1.123e+04  99.9%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flop: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flop in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flop                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
BuildTwoSidedF      1511 1.0 8.6102e+0136.2 0.00e+00 0.0 1.8e+03 4.5e+05 0.0e+00  8  0 13 61  0   8  0 13 61  0     0
IGAFormScalar         11 1.0 4.9332e+00 1.0 4.75e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     2
IGAFormSystem          1 1.0 3.6169e-01 1.0 1.63e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   903
IGAFormIFunction      73 1.0 9.3228e+01 1.0 2.20e+09 1.0 0.0e+00 0.0e+00 0.0e+00 16  2  0  0  0  16  2  0  0  0    47
IGAFormIJacobian      10 1.0 2.2848e+02 1.0 4.07e+10 1.0 0.0e+00 0.0e+00 0.0e+00 39 30  0  0  0  39 30  0  0  0   356
VecView               48 1.0 7.2622e-03 1.0 0.00e+00 0.0 4.8e+01 4.8e+04 4.8e+01  0  0  0  0  0   0  0  0  0  0     0
VecDot                63 1.0 1.6343e-0118.4 2.47e+06 1.2 0.0e+00 0.0e+00 6.3e+01  0  0  0  0  1   0  0  0  0  1    27
VecMDot             2976 1.2 7.8163e+0020.3 2.47e+08 1.1 0.0e+00 0.0e+00 2.5e+03  1  0  0  0 22   1  0  0  0 22    61
VecTDot             4135 1.0 8.9700e-01 2.0 3.97e+07 1.2 0.0e+00 0.0e+00 4.1e+03  0  0  0  0 37   0  0  0  0 37    81
VecNorm             4038 1.2 2.5458e+00 6.3 1.00e+08 1.1 0.0e+00 0.0e+00 3.4e+03  0  0  0  0 30   0  0  0  0 30    75
VecScale            4008 1.2 1.9410e-02 1.2 5.34e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  5188
VecCopy             1559 1.1 1.2238e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet              7717 1.3 4.6788e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY             4848 1.0 1.8028e-02 1.1 5.87e+07 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  6064
VecAYPX             1801 1.0 5.2929e-03 1.1 2.16e+07 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  7467
VecAXPBYCZ           312 0.0 2.0902e-03 0.0 6.82e+06 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3261
VecWAXPY             366 1.3 5.7867e-03 1.1 5.53e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1833
VecMAXPY            3523 1.2 7.5719e-02 1.1 3.24e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  8206
VecAssemblyBegin    1514 1.1 2.3195e+01 4.9 0.00e+00 0.0 1.8e+03 3.0e+05 0.0e+00  2  0 13 41  0   2  0 13 41  0     0
VecAssemblyEnd      1514 1.1 1.0521e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecLoad                1 1.0 4.2033e-04 1.1 0.00e+00 0.0 1.0e+00 1.9e+05 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin     8129 1.0 1.6559e-01 1.0 0.00e+00 0.0 1.2e+04 4.5e+04 0.0e+00  0  0 84 38  0   0  0 84 38  0     0
VecScatterEnd       8129 1.0 2.0677e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecReduceArith       126 1.0 3.4466e-03 1.2 4.94e+06 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2603
VecReduceComm         63 1.0 5.3523e-03 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 6.3e+01  0  0  0  0  1   0  0  0  0  1     0
VecNormalize         577 0.0 5.6560e-03 0.0 1.17e+07 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2066
MatMult             5518 1.1 2.6675e+01 1.2 4.64e+10 1.2 1.0e+04 1.7e+04 0.0e+00  4 31 73 13  0   4 31 73 13  0  3170
MatSolve            4706 1.1 1.8594e+01 1.2 3.11e+10 1.2 0.0e+00 0.0e+00 0.0e+00  3 21  0  0  0   3 21  0  0  0  3056
MatLUFactorNum        85 7.1 9.4006e+00 1.1 2.43e+10 1.1 0.0e+00 0.0e+00 0.0e+00  2 17  0  0  0   2 17  0  0  0  4964
MatILUFactorSym       7625.3 8.2000e-02 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               1 1.0 4.7565e-04 1.3 5.70e+05 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2187
MatAssemblyBegin     400 1.2 6.4986e+01 1.0 0.00e+00 0.0 1.6e+01 1.6e+07 0.0e+00 11  0  0 20  0  11  0  0 20  0     0
MatAssemblyEnd       400 1.2 1.1507e+00 3.9 0.00e+00 0.0 9.2e+01 2.4e+03 1.8e+02  0  0  1  0  2   0  0  1  0  2     0
MatGetRow         249600 1.2 2.9696e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ           7625.3 1.8358e-0519.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCreateSubMat       44 1.0 1.9472e+00 1.0 0.00e+00 0.0 3.2e+01 1.9e+04 6.0e+01  0  0  0  0  1   0  0  0  0  1     0
MatGetOrdering        7625.3 1.1942e-0310.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatZeroEntries        84 7.6 2.3746e-01 5.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatView                9 1.8 1.4534e-03 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPGMRESOrthog      2976 1.2 7.8828e+0017.8 4.94e+08 1.1 0.0e+00 0.0e+00 2.5e+03  1  0  0  0 22   1  0  0  0 22   120
KSPSetUp             170 1.8 2.2168e-03 5.5 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve             137 2.1 6.0113e+01 1.1 9.91e+10 1.1 9.9e+03 1.7e+04 9.6e+03 10 68 72 12 86  10 68 72 12 86  3108
PCSetUp              108 3.1 1.1821e+01 1.0 2.43e+10 1.1 4.0e+01 2.2e+04 1.5e+02  2 17  0  0  1   2 17  0  0  1  3947
PCSetUpOnBlocks      825 1.0 9.4338e+00 1.3 2.23e+10 1.3 0.0e+00 0.0e+00 0.0e+00  1 14  0  0  0   1 14  0  0  0  4167
PCApply             1002 2.4 4.9566e+01 1.0 8.89e+10 1.3 9.1e+03 1.5e+04 8.6e+03  8 58 66 10 77   8 58 66 10 77  3226
KSPSolve_FS_0        412 1.0 4.5140e+01 1.0 8.25e+10 1.3 4.1e+03 2.6e+04 4.5e+03  8 53 30  8 40   8 53 30  8 40  3261
KSPSolve_FS_Schu     412 1.0 3.2677e+00 1.0 4.67e+09 1.2 4.1e+03 6.4e+03 4.1e+03  1  3 30  2 37   1  3 30  2 37  2601
TSStep                10 1.0 5.1851e+02 1.0 1.44e+11 1.1 1.3e+04 1.0e+05 1.0e+04 89100 97 99 92  89100 97 99 92   531
TSFunctionEval        73 1.0 1.6781e+02 1.0 1.17e+10 5.3 3.1e+03 2.9e+05 7.3e+01 29  5 23 67  1  29  5 23 67  1    83
TSJacobianEval        10 1.0 2.9273e+02 1.0 4.07e+10 1.0 9.5e+01 2.8e+06 0.0e+00 50 30  1 20  0  50 30  1 20  0   278
SNESSolve             10 1.0 5.1851e+02 1.0 1.44e+11 1.1 1.3e+04 1.0e+05 1.0e+04 89100 97 99 92  89100 97 99 92   531
SNESFunctionEval      73 1.0 1.6781e+02 1.0 1.18e+10 5.3 3.1e+03 2.9e+05 7.3e+01 29  5 23 67  1  29  5 23 67  1    83
SNESJacobianEval      10 1.0 2.9273e+02 1.0 4.07e+10 1.0 9.5e+01 2.8e+06 0.0e+00 50 30  1 20  0  50 30  1 20  0   278
SNESLineSearch        63 1.0 1.4530e+02 1.0 1.14e+10 3.3 2.8e+03 2.8e+05 3.2e+02 25  5 21 58  3  25  5 21 58  3   102
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
                 IGA     5              5         6240     0.
                IGAM     2              2         4656     0.
              Viewer    59             58        48720     0.
              Vector  1428           1414     81136264     0.
           Index Set   378            378      5213512     0.
   IS L to G Mapping   314            311      7897376     0.
         Vec Scatter    48             47      1093744     0.
   Application Order     6              6       224224     0.
              Matrix   312            311   1055303020     0.
    Distributed Mesh    10             10        47016     0.
   Star Forest Graph    20             20        16000     0.
     Discrete System    10             10         9200     0.
       Krylov Solver    83             83      1392264     0.
     DMKSP interface     1              1          656     0.
      Preconditioner    83             83        83016     0.
             TSAdapt     1              1         1224     0.
                  TS     1              1         1984     0.
                DMTS     1              1          744     0.
                SNES     1              1         1372     0.
      SNESLineSearch     1              1         1000     0.
              DMSNES     2              2         1344     0.
Average time to get PetscTime(): 2.38419e-08
Average time for MPI_Barrier(): 5.05924e-05
Average time for zero size MPI_Send(): 1.57356e-05
#PETSc Option Table entries:
-fieldsplit_m_ksp_convergence_test skip
-fieldsplit_m_ksp_max_it 5
-fieldsplit_m_ksp_norm_type none
-fieldsplit_m_ksp_type fgmres
-fieldsplit_m_pc_type bjacobi
-fieldsplit_m_sub_ksp_type preonly
-fieldsplit_m_sub_pc_factor_levels 0
-fieldsplit_m_sub_pc_type ilu
-fieldsplit_p_ksp_ksp_convergence_test skip
-fieldsplit_p_ksp_ksp_max_it 5
-fieldsplit_p_ksp_ksp_norm_type none
-fieldsplit_p_ksp_ksp_type cg
-fieldsplit_p_ksp_pc_type bjacobi
-fieldsplit_p_ksp_type preonly
-fieldsplit_p_pc_type ksp
-geo_iga_load em3d_geo.dat
-geo_iga_order 2
-geo_iga_periodic 1,1,0
-geo_iga_quadrature 3,3,3
-iga_view
-igam_view
-ksp_atol 1e-8
-ksp_converged_reason
-ksp_monitor
-ksp_norm_type unpreconditioned
-ksp_rtol 0.0
-ksp_type fgmres
-log_view
-p_iga_load em3d_p.dat
-p_iga_order 1
-p_iga_periodic 1,1,0
-p_iga_quadrature 3,3,3
-pc_fieldsplit_schur_fact_type upper
-pc_fieldsplit_schur_precondition user
-pc_fieldsplit_type schur
-pc_type fieldsplit
-press_ksp_rtol 1e-10
-snes_converged_reason
-snes_lag_jacobian 20
-snes_max_it 150
-snes_monitor
-snes_rtol 1e-3
-ts_max_snes_failures 20000
-ts_monitor
-ts_view
-u_iga_load em3d_u.dat
-u_iga_order 1
-u_iga_periodic 1,1,0
-u_iga_quadrature 3,3,3
-v_iga_load em3d_v.dat
-v_iga_order 1
-v_iga_periodic 1,1,0
-v_iga_quadrature 3,3,3
-w_iga_load em3d_w.dat
-w_iga_order 1
-w_iga_periodic 1,1,0
-w_iga_quadrature 3,3,3
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --with-cc=gcc --with-fc=gfortran --download-fblaslapack --download-mpich --with-debugging=0 COPTFLAGS=-O3 FOPTFLAGS=-O3 CXXOPTFLAGS=-O3 PETSC_ARCH=optimO3fftw391 --download-mumps --download-hypre --download-scalapack --download-parmetis --download-metis --download-fftw --download-cmake
Libraries compiled on 2018-04-30 16:27:28 on ubuntu
Machine characteristics: Linux-4.13.0-38-generic-x86_64-with-Ubuntu-16.04-xenial
Using PETSc directory: /home/hcasquer/petsc-3.9.1
Using PETSc arch: optimO3fftw391
Using C compiler: /home/hcasquer/petsc-3.9.1/optimO3fftw391/bin/mpicc    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -O3
Using Fortran compiler: /home/hcasquer/petsc-3.9.1/optimO3fftw391/bin/mpif90   -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3
Using include paths: -I/home/hcasquer/petsc-3.9.1/include -I/home/hcasquer/petsc-3.9.1/optimO3fftw391/include
Using C linker: /home/hcasquer/petsc-3.9.1/optimO3fftw391/bin/mpicc
Using Fortran linker: /home/hcasquer/petsc-3.9.1/optimO3fftw391/bin/mpif90
Using libraries: -Wl,-rpath,/home/hcasquer/petsc-3.9.1/optimO3fftw391/lib -L/home/hcasquer/petsc-3.9.1/optimO3fftw391/lib -lpetsc -Wl,-rpath,/home/hcasquer/petsc-3.9.1/optimO3fftw391/lib -L/home/hcasquer/petsc-3.9.1/optimO3fftw391/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/5 -L/usr/lib/gcc/x86_64-linux-gnu/5 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lpthread -lscalapack -lHYPRE -lfftw3_mpi -lfftw3 -lflapack -lfblas -lparmetis -lmetis -lm -lpthread -lstdc++ -ldl -lmpifort -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -ldl
