[petsc-users] Scaling problem when cores > 600
Wed Feb 28 20:07:10 CST 2018
On Wed, Feb 28, 2018 at 9:01 PM, TAY wee-beng <zonexo at gmail.com> wrote:
> On 1/3/2018 12:10 AM, Matthew Knepley wrote:
> On Wed, Feb 28, 2018 at 10:45 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>> Hi,
>> I have a CFD code which uses PETSc and HYPRE. I found that for a certain
>> case with grid size of 192,570,048, I encounter scaling problem when my
>> cores > 600. At 600 cores, the code took 10min for 100 time steps. At 960,
>> 1440 and 2880 cores, it still takes around 10min. At 360 cores, it took
>> 15min.
>> So how can I find the bottleneck? Any recommended steps?
> For any performance question, we need to see the output of -log_view for
> all test cases.
> Hi,
> To be more specific, I use PETSc KSPBCGS and HYPRE geometric multigrid
> (entirely based on HYPRE, no PETSc) for the momentum and Poisson eqns in my
> code.
> So can log_view be used in this case to give a meaningful? Since part of
> the code uses HYPRE?
Make an event to time the HYPRE solve. It only takes a few lines of code.
> I also program another subroutine in the past which uses PETSc to solve
> the Poisson eqn. It uses either HYPRE's boomeramg, KSPBCGS or KSPGMRES.
> If I use boomeramg, can log_view be used in this case?
Yes, its automatic.
> Or do I have to use KSPBCGS or KSPGMRES, which is directly from PETSc?
> However, I ran KSPGMRES yesterday with the Poisson eqn and my ans didn't
> converge.
Plain GMRES is not good for Poisson. You would be better off with
GMRES/GAMG.
     Matt
> Thanks.
>> I must also mention that I partition my grid only in the x and y
>> direction. There is no partitioning in the z direction due to limited code
>> development. I wonder if there is a strong effect in this case.
> Maybe. Usually what happens is you fill up memory with a z-column and
> cannot scale further.
>   Thanks,
>      Matt
>> Thank you very much
>> Yours sincerely,
>> TAY Wee-Beng 郑伟明 (Zheng Weiming)
>> Personal research webpage: http://tayweebeng.wixsite.com/website
>> Youtube research showcase: https://www.youtube.com/channe
>> l/UC72ZHtvQNMpNs2uRTSToiLA
>> linkedin: www.linkedin.com/in/tay-weebeng
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180228/30c1e238/attachment.html>
