[petsc-users] Scaling problem when cores > 600
TAY wee-beng zonexo at gmail.com
Wed Feb 28 09:45:14 CST 2018
I have a CFD code which uses PETSc and HYPRE. I found that for a certain
case with grid size of 192,570,048, I encounter scaling problem when my
cores > 600. At 600 cores, the code took 10min for 100 time steps. At
960, 1440 and 2880 cores, it still takes around 10min. At 360 cores, it
took 15min.
So how can I find the bottleneck? Any recommended steps?
I must also mention that I partition my grid only in the x and y
direction. There is no partitioning in the z direction due to limited
code development. I wonder if there is a strong effect in this case.
Thank you very much
Yours sincerely,
TAY Wee-Beng 郑伟明 (Zheng Weiming)
Personal research webpage: http://tayweebeng.wixsite.com/website
Youtube research showcase: https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
linkedin: www.linkedin.com/in/tay-weebeng
