[petsc-users] object name overwritten in VecView
Matthew Knepley
knepley at gmail.com
Wed Feb 28 05:58:08 CST 2018
On Wed, Feb 28, 2018 at 12:39 AM, Smith, Barry F. <bsmith at mcs.anl.gov>
wrote:
> Matt,
> I have confirmed this is reproducible and a bug. The problem arises
> because
> frame #0: 0x000000010140625a libpetsc.3.8.dylib`
> PetscViewerVTKAddField_VTK(viewer=0x00007fe66760c750,
> dm=0x00007fe668810820, PetscViewerVTKWriteFunction=(libpetsc.3.8.dylib`DMPlexVTKWriteAll
> at plexvtk.c:633), fieldtype=PETSC_VTK_POINT_FIELD,
> vec=0x00007fe66880ee20) at vtkv.c:140
> frame #1: 0x0000000101404e6e libpetsc.3.8.dylib`
> PetscViewerVTKAddField(viewer=0x00007fe66760c750, dm=0x00007fe668810820,
> PetscViewerVTKWriteFunction=(libpetsc.3.8.dylib`DMPlexVTKWriteAll at
> plexvtk.c:633), fieldtype=PETSC_VTK_POINT_FIELD, vec=0x00007fe66880ee20)
> at vtkv.c:46
> frame #2: 0x0000000101e0b7c3 libpetsc.3.8.dylib`VecView_Plex_Local(v=0x00007fe66880ee20,
> viewer=0x00007fe66760c750) at plex.c:301
> frame #3: 0x0000000101e0ead7 libpetsc.3.8.dylib`VecView_Plex(v=0x00007fe66880e820,
> viewer=0x00007fe66760c750) at plex.c:348
> keeps a linked list of vectors that are to be viewed and the vectors are
> the same Vec because they are obtained with DMGetLocalVector().
> The safest fix is to have PetscViewerVTKAddField_VTK() do a VecDuplicate()
> on the vector passed in and store that in the linked list instead of just
> storing a pointer to the passed in vector (which might and can be
> overwritten before all the linked vectors are actually stored).
Danyang,
Barry is right, and the bug can be fixed the way he says. However, this
points out why VTK is bad format. I think a better choice is
to use HDF5 and XDMF. For example, in my code now I always use
DMVIewFromOptions(dm, NULL, "-dm_view");
and then later (perhaps several times)
VecViewFromOptions(u, NULL, "-u_vec_view")
VecViewFromOptions(v, NULL, "-v_vec_view")
and then on the command line
-dm_view hdf5:test.h5 -u_vec_view hdf5:test.h5::append -v_vec_view
which produces a file
test.h5
Then I run
$PETSC_DIR/bin/petsc_gen_xdmf.py test.h5
which produces another file
test.xmf
This can be loaded by Paraview for visualization.
Matt
> Barry
> > On Feb 27, 2018, at 10:44 PM, Danyang Su <danyang.su at gmail.com> wrote:
> > Hi All,
> > How to set different object names when using multiple VecView? I try to
> use PetscObjectSetName with multiple output, but the object name is
> overwritten by the last one.
> > As shown below, as well as the enclosed files as example, the vector
> name in sol.vtk is vec_v for both vector u and v.
> > call PetscViewerCreate(PETSC_COMM_WORLD, viewer,
> ierr);CHKERRA(ierr)
> > call PetscViewerSetType(viewer, PETSCVIEWERVTK, ierr);CHKERRA(ierr)
> > call PetscViewerPushFormat(viewer, PETSC_VIEWER_ASCII_VTK,
> ierr);CHKERRA(ierr)
> > call PetscViewerFileSetName(viewer, 'sol.vtk', ierr);CHKERRA(ierr)
> > call PetscObjectSetName(u, 'vec_u', ierr);CHKERRA(ierr)
> > call VecView(u, viewer, ierr);CHKERRA(ierr)
> > call PetscObjectSetName(v, 'vec_v', ierr);CHKERRA(ierr)
> > call VecView(v, viewer, ierr);CHKERRA(ierr)
> > call PetscViewerDestroy(viewer, ierr);CHKERRA(ierr)
> > call DMRestoreGlobalVector(dm, u, ierr);CHKERRA(ierr)
> > call DMRestoreGlobalVector(dm, v, ierr);CHKERRA(ierr)
> > Thanks,
> > Danyang
> > <ex1f90.F90><makefile.txt><sol.vtk>
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180228/dcfacc3b/attachment.html>
