[petsc-users] Check if allocated in Fortran
Sanjay Govindjee s_g at berkeley.edu
Mon Feb 26 09:41:13 CST 2018
I am trying to update some code that works in version 3.7.6 to version
3.8.3.
What is the recommended way to check if a petsc type, such as Vec, has
already been created?
Current code looks like:
Vec xvec
if(xvec.eq.0) then          ! Check if xvec needs to be created
   call VecCreate(PETSC_COMM_WORLD, xvec, ierr)
endif
In PETSc 3.8.3 I am now getting a compiler error
parkv.F(60): error #6355: This binary operation is invalid for this data
type.   [XVEC]
       if(xvec.eq.0) then
