[petsc-users] Compiling with PETSc 64-bit indices
Matthew Knepley
knepley at gmail.com
Thu Feb 22 04:32:00 CST 2018
On Thu, Feb 22, 2018 at 1:24 AM, TAY wee-beng <zonexo at gmail.com> wrote:
> On 21/2/2018 9:12 AM, Matthew Knepley wrote:
> On Tue, Feb 20, 2018 at 8:08 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>> On 21/2/2018 9:00 AM, Matthew Knepley wrote:
>> On Tue, Feb 20, 2018 at 7:54 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>> Hi,
>>> When I run my CFD code with a grid size of 1119x1119x499 ( total grid
>>> size = 624828339 ), I got the error saying I need to compile PETSc with
>>> 64-bit indices.
>>> So I tried to compile PETSc again and then compile my CFD code with the
>>> newly compiled PETSc. However, now I got segmentation error:
>>> rm: cannot remove `log': No such file or directory
>>> [409]PETSC ERROR: ------------------------------
>>> [409]PETSC ERROR: [535]PETSC ERROR: [410]PETSC ERROR:
>>> [410]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>> probably memory access out of range
>>> [410]PETSC ERROR: Try option -start_in_debugger or
>>> -on_error_attach_debugger
>>> [410]PETSC ERROR: [536]PETSC ERROR: ------------------------------
>>> [536]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>> [536]PETSC ERROR: Try option -start_in_debugger or
>>> [536]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/d
>>> ocumentation/faq.html#valgrind
>>> [536]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
>>> OS X to find memory corruption errors
>>> [536]PETSC ERROR: likely location of problem given in stack below
>>> [536]PETSC ERROR: --------------------- Stack Frames
>>> [536]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>> available,
>>> [536]PETSC ERROR: INSTEAD the line number of the start of the
>>> function
>>> [536]PETSC ERROR: is given.
>>> [536]PETSC ERROR: [536] DMDACheckOwnershipRanges_Private line 581
>>> /home/users/nus/tsltaywb/source/petsc-3.7.6/src/dm/impls/da/da.c
>>> [410]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
>>> [410]PETSC ERROR: likely location of problem given in stack below
>>> [410]PETSC ERROR: --------------------- Stack Frames
>>> [410]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>> available,
>>> [897]PETSC ERROR: [536] DMDASetOwnershipRanges line 613
>>> [536]PETSC ERROR: [536] DMDACreate3d line 1434
>>> /home/users/nus/tsltaywb/source/petsc-3.7.6/src/dm/impls/da/da3.c
>>> [536]PETSC ERROR: --------------------- Error Message
>>> The CFD code worked previously but increasing the problem size results
>>> in segmentation error. It seems to be related to DMDACreate3d and
>>> DMDASetOwnershipRanges. Any idea where the problem lies?
>>> Besides, I want to know when and why do I have to use PETSc with 64-bit
>>> indices?
>> 1) A 32-bit integer can hold numbers up to 2^32 = 4.2e9, so if you have a
>> 3D velocity, pressure, and energy, you already have 3e9 unknowns,
>> before you even start to count nonzero entries in the matrix. 64-bit
>> integers allow you to handle these big sizes.
>>> Also, can I use the 64-bit indices version with smaller sized problems?
>> 2) Yes
>>> And is there a speed difference between using the 32-bit and 64-bit
>>> indices ver?
>> 3) I have seen no evidence of this
>> 4) My guess is that you have defines regular integers in your code and
>> passed them to PETSc, rather than using PetscInt as the type.
>> Oh that seems probable. So I am still using integer(4) when it should be
>> integer(8) for some values, is that so? If I use PetscInt, is it the same
>> as integer(8)? Or does it depend on the actual number?
> PetscInt will be integer(4) if you configure with 32-bit ints, and
> integer(8) if you configure with 64-bit ints. If you use it consistently,
> you can avoid problems
> with matching the PETSc API.
> I wonder if I replace all my integer to PetscInt, will there be a large
>> increase in memory usage, because all integer(4) now becomes integer(8)?
> Only if you have large integer storage. Most codes do not.
> Hi,
> What do you mean by "large integer storage"?
You have some structure that stores 1B integers. Most codes do not.
> Btw, I got the following error when I ran a simple small test case with my
> CFD code:
You requested 7M TB of memory. This looks like an uninitialized integer.
Matt
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Out of memory. This could be due to allocating
> [0]PETSC ERROR: too large an object or bleeding by not properly
> [0]PETSC ERROR: destroying unneeded objects.
> [0]PETSC ERROR: Memory allocated 0 Memory used by process 52858880
> [0]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
> [0]PETSC ERROR: Memory requested 6917565139726106624
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.8.3, Dec, 09, 2017
> [0]PETSC ERROR: ./a.out on a petsc-3.8.3_intel_64_rel named nus02 by
> tsltaywb Thu Feb 22 10:34:29 2018
> [0]PETSC ERROR: Configure options --with-mpi-dir=/app/intel/
> xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64
> --with-blaslapack-dir=/app/intel/xe2018/compilers_and_
> libraries_2018.0.128/linux/mkl/lib/intel64 --download-hypre=/home/users/
> nus/tsltaywb/source/git.hypre.tar.gz --with-debugging=0
> --prefix=/home/users/nus/tsltaywb/lib/petsc-3.8.3_intel_64_rel
> --with-shared-libraries=0 --known-mpi-shared-libraries=0
> --with-fortran-interfaces=1 --CFLAGS="-xHost -g -O3" --CXXFLAGS="-xHost -g
> -O3" --FFLAGS="-xHost -g -O3" --with-64-bit-indices
> [0]PETSC ERROR: #105 DMSetUp_DA() line 18 in /home/users/nus/tsltaywb/
> source/petsc-3.8.3/src/dm/impls/da/dareg.c
> [0]PETSC ERROR: #106 DMSetUp_DA() line 18 in /home/users/nus/tsltaywb/
> [0]PETSC ERROR: #107 DMSetUp() line 720 in /home/users/nus/tsltaywb/
> source/petsc-3.8.3/src/dm/interface/dm.c
> [0]PETSC ERROR: Arguments are incompatible
> [0]PETSC ERROR: Ownership ranges sum to 4294967337 but global dimension is
> 41
> [0]PETSC ERROR: #108 DMDACheckOwnershipRanges_Private() line 548 in
> /home/users/nus/tsltaywb/source/petsc-3.8.3/src/dm/impls/da/da.c
> [0]PETSC ERROR: #109 DMDASetOwnershipRanges() line 580 in
> [0]PETSC ERROR: #110 DMDACreate3d() line 1444 in /home/users/nus/tsltaywb/
> source/petsc-3.8.3/src/dm/impls/da/da3.c
> What's the problem?
> Thanks.
> Thanks,
> Matt
>> Thanks.
>> Thanks,
>> Matt
>>> Thank you very much.
>>> Yours sincerely,
>>> TAY Wee-Beng (Zheng Weiming) 郑伟明
>>> Personal research webpage: http://tayweebeng.wixsite.com/website
>>> Youtube research showcase: https://www.youtube.com/channe
>>> l/UC72ZHtvQNMpNs2uRTSToiLA
>>> linkedin: www.linkedin.com/in/tay-weebeng
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180222/4295592c/attachment-0001.html>
