[petsc-users] Compiling with PETSc 64-bit indices
TAY wee-beng
zonexo at gmail.com
Tue Feb 20 18:54:57 CST 2018
When I run my CFD code with a grid size of 1119x1119x499 ( total grid
size = 624828339 ), I got the error saying I need to compile PETSc
with 64-bit indices.
So I tried to compile PETSc again and then compile my CFD code with the
newly compiled PETSc. However, now I got segmentation error:
rm: cannot remove `log': No such file or directory
[409]PETSC ERROR:
[409]PETSC ERROR: [535]PETSC ERROR: [410]PETSC ERROR:
[410]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[410]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[410]PETSC ERROR: [536]PETSC ERROR:
[536]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
[536]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[536]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[536]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
OS X to find memory corruption errors
[536]PETSC ERROR: likely location of problem given in stack below
[536]PETSC ERROR: --------------------- Stack Frames
[536]PETSC ERROR: Note: The EXACT line numbers in the stack are not
available,
[536]PETSC ERROR: INSTEAD the line number of the start of the function
[536]PETSC ERROR: is given.
[536]PETSC ERROR: [536] DMDACheckOwnershipRanges_Private line 581
/home/users/nus/tsltaywb/source/petsc-3.7.6/src/dm/impls/da/da.c
[410]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
[410]PETSC ERROR: likely location of problem given in stack below
[410]PETSC ERROR: --------------------- Stack Frames
[410]PETSC ERROR: Note: The EXACT line numbers in the stack are not
available,
[897]PETSC ERROR: [536] DMDASetOwnershipRanges line 613
[536]PETSC ERROR: [536] DMDACreate3d line 1434
/home/users/nus/tsltaywb/source/petsc-3.7.6/src/dm/impls/da/da3.c
[536]PETSC ERROR: --------------------- Error Message
The CFD code worked previously but increasing the problem size results
in segmentation error. It seems to be related to DMDACreate3d and
DMDASetOwnershipRanges. Any idea where the problem lies?
Besides, I want to know when and why do I have to use PETSc with 64-bit
indices?
Also, can I use the 64-bit indices version with smaller sized problems?
And is there a speed difference between using the 32-bit and 64-bit
indices ver?
Thank you very much.
Yours sincerely,
TAY Wee-Beng (Zheng Weiming) 郑伟明
Personal research webpage: http://tayweebeng.wixsite.com/website
Youtube research showcase: https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
linkedin: www.linkedin.com/in/tay-weebeng
