[petsc-users] Question on DMPlexCreateFromCellList and DMPlexCreateFromFile
Danyang Su
danyang.su at gmail.com
Fri Feb 16 10:36:55 CST 2018
On 18-02-15 05:57 PM, Matthew Knepley wrote:
> On Thu, Feb 15, 2018 at 7:40 PM, Danyang Su <danyang.su at gmail.com
> <mailto:danyang.su at gmail.com>> wrote:
> Hi Matt,
> I have a question on DMPlexCreateFromCellList and
> DMPlexCreateFromFile. When use DMPlexCreateFromFile with Gmsh file
> input, it works fine and each processor gets its own part.
> However, when use DMPlexCreateFromCellList, all the processors
> have the same global mesh. To my understand, I should put the
> global mesh as input, right?
> No. Each process should get part of the mesh in CreateFromCellList(),
> but the most common thing to do is to
> feed the whole mesh in on proc 0, and nothing in on the other procs.
Thanks for the explanation. It works now.
Danyang
> Thanks,
> Matt
> Otherwise, I should use DMPlexCreateFromCellListParallel instead
> if the input is local mesh.
> Below is the test code I use, results from method 1 is wrong and
> that from method 2 is correct. Would you please help to check if I
> did anything wrong with DMPlexCreateFromCellList input?
> !test with 4 processor, global num_cells = 8268, global num_nodes
> = 4250
> !correct results
> check rank 2 istart 2034 iend 3116
> check rank 3 istart 2148 iend 3293
> check rank 1 istart 2044 iend 3133
> check rank 0 istart 2042 iend 3131
> !wrong results
> check rank 0 istart 8268 iend 12518
> check rank 1 istart 8268 iend 12518
> check rank 2 istart 8268 iend 12518
> check rank 3 istart 8268 iend 12518
> !c ************* test part *********************
> !c method 1: create DMPlex from cell list, same duplicated
> global meshes over all processors
> !c the input parameters num_cells, num_nodes, dmplex_cells,
> dmplex_verts are all global parameters (global mesh data)
> call DMPlexCreateFromCellList(Petsc_Comm_World,ndim,num_cells, &
> num_nodes,num_nodes_per_cell, &
> Petsc_True,dmplex_cells,ndim, &
> dmplex_verts,dmda_flow%da,ierr)
> CHKERRQ(ierr)
> !c method 2: create DMPlex from Gmsh file, for test purpose,
> this works fine, each processor gets its own part
> call DMPlexCreateFromFile(Petsc_Comm_World, &
> prefix(:l_prfx)//'.msh',0, &
> dmda_flow%da,ierr)
> CHKERRQ(ierr)
> !c *************end of test part*********************
> distributedMesh = PETSC_NULL_OBJECT
> !c distribute mesh over processes
> call DMPlexDistribute(dmda_flow%da,0,PETSC_NULL_OBJECT, &
> distributedMesh,ierr)
> CHKERRQ(ierr)
> !c destroy original global mesh after distribution
> if (distributedMesh /= PETSC_NULL_OBJECT) then
> call DMDestroy(dmda_flow%da,ierr)
> CHKERRQ(ierr)
> !c set the global mesh as distributed mesh
> dmda_flow%da = distributedMesh
> end if
> !c get coordinates
> call DMGetCoordinatesLocal(dmda_flow%da,gc,ierr)
> CHKERRQ(ierr)
> call DMGetCoordinateDM(dmda_flow%da,cda,ierr)
> CHKERRQ(ierr)
> call DMGetDefaultSection(cda,cs,ierr)
> CHKERRQ(ierr)
> call PetscSectionGetChart(cs,istart,iend,ierr)
> CHKERRQ(ierr)
> #ifdef DEBUG
> if(info_debug > 0) then
> write(*,*) "check rank ",rank," istart ",istart," iend
> ",iend
> end if
> #endif
> Thanks and regards,
> Danyang
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180216/2efd9a46/attachment-0001.html>
