[petsc-users] Dealing with DMPlexDistribute()
Thu Feb 15 16:51:07 CST 2018
On Thu, Feb 15, 2018 at 5:43 PM, Mohammad Hassan Baghaei <
mhbaghaei at mail.sjtu.edu.cn> wrote:
> Hi Matt
> In fact, I created a routine for my specific mesh generation. I firstly,
> create the DMPlex object at first, then setting the chart, then doing
> symmetrize and interpolate. Next, I created coordinate section and giving
> the coordinates. After finishing giving the coordinates, I declare the
> distribution in routine, with this two lines:
If you are creating the whole mesh, then you want to enclose the creation
steps in
if (!rank) {
  <your current code for creating the chart and cones>
} else {
  DMCreate()
  DMSetType()
DMPlexSymmetrize()
DMPlexInterpolate()
There are examples of me doing this in the Plex tests.
     Matt
> DMPlexDistribute(*dm, 0, NULL, &dmDist);
> if (dmDist) {DMDestroy(dm); *dm = dmDist;}
> Thanks
> Amir
> *From:* Matthew Knepley [mailto:knepley at gmail.com]
> *Sent:* Friday, February 16, 2018 6:34 AM
> *To:* Mohammad Hassan Baghaei <mhbaghaei at mail.sjtu.edu.cn>
> *Cc:* PETSc <petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] Dealing with DMPlexDistribute()
> On Thu, Feb 15, 2018 at 4:40 PM, Mohammad Hassan Baghaei <
> Hi
> I am using DMPlex as interface for mesh generation. On single core, I got
> around 30000 mesh cells. Whenever, I run on multiple core, say 3, in the
> output file for DM, VTK, I got 3 times mesh cell and point numbers. Does it
> mean that DMPlexDistribute() does not work properly!
> Hi Amir,
> It sounds like you are generating a mesh on every process. How are you
> generating the mesh?
>   Thanks,
>     Matt
> Thanks
> Amir
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180215/1c275c64/attachment.html>
