[petsc-users] Fwd: what is the equivalent DMDAVecRestoreArray() function in petsc4py?
HeeHo Park
heeho.park at gmail.com
Thu Feb 15 15:13:58 CST 2018
Yes, this works.
u = da.getVecArray(U)
for i in range(mstart, mend):
u[i] = np.sin(np.pi*i*6.*h) + 3.*np.sin(np.pi*i*2.*h)
The code above also worked without restoreVecArray. I guess the u just
points at the array U.
I think your code is clearer to understand what is happening.
Thank you,
On Wed, Feb 14, 2018 at 5:57 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Feb 14, 2018 at 6:05 PM, HeeHo Park <heeho.park at gmail.com> wrote:
>> I just found a user group on PETSc website. Can someone please answer the
>> question below?
> I think it will work using
> with da.getVecArray(U) as u
> Does it?
> Thanks,
> Matt
> Thanks!
>> ---------- Forwarded message ----------
>> From: HeeHo Park <heeho.park at gmail.com>
>> Date: Wed, Feb 14, 2018 at 5:04 PM
>> Subject: what is the equivalent DMDAVecRestoreArray() function in
>> petsc4py?
>> To: dalcinl at gmail.com
>> Hi Lisandro,
>> I cannot find DMDAVecRestoreArray() equivalent in petsc4py.
>> I'm trying to set a 1D initial condition like this.
>> def initial_conditions(ts, U, appctx):
>> da = ts.getDM()
>> mstart,xm = da.getCorners()
>> mstart = mstart[0]
>> xm = xm[0]
>> M = da.getSizes()[0]
>> h = 1.0/M
>> mend = mstart + xm
>> da.getVecRestoreArray(u)
>> Also, is there a better way to ask questions about petsc4py? a forum? or
>> google-group?
>> Thanks,
>> HeeHo Daniel Park
>> HeeHo Daniel Park
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
HeeHo Daniel Park
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180215/7e9b548d/attachment.html>
