[petsc-users] How to efficiently represent a diagonal matrix?
Smith, Barry F. bsmith at mcs.anl.gov
Wed Feb 14 22:19:28 CST 2018
  Fande,
    I think you should just use AIJ, all the algorithms MatMult, MatFactor, MatSolve when the matrix is diagonal are order n work with a relatively small constant, and the overhead of using AIJ instead of a custom format is probably at most a factor of three  and since work is order n and it is a small constant any gain would be lost in the much bigger constants for the rest of the computation.
   Barry
I know Rich doesn't have unlimited money and suspect spending it on almost anything else (like improving the load balancing in libMesh) will pay off far far more.
> On Feb 14, 2018, at 8:29 PM, Jed Brown <jed at jedbrown.org> wrote:
> Fande Kong <fdkong.jd at gmail.com> writes:
>> On Wed, Feb 14, 2018 at 4:35 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>>>  What are you doing with the matrix?
>> We are doing an explicit method. PDEs are discretized using a finite
>> element method, so there is a mass matrix. The mass matrix will be lumped,
>> and it becomes diagonal. We want to compute the inverse of the lumped
>> matrix, and also do a few of matrix-vector multiplications using  the
>> lumped matrix or  its inverse.
>> The specific implementation won't make this more efficient?
> You can use pretty much any representation and you won't notice the time
> because you still have to apply the RHS operator and that is vastly more
> expensive.
