[petsc-users] multiply a mpibaij matrix by its block diagonal inverse
Wed Feb 14 08:39:52 CST 2018
On Wed, Feb 14, 2018 at 9:29 AM, Xiangdong <epscodes at gmail.com> wrote:
> The reason for the operation invdiag(A)*A is to have a decoupled
> matrix/physics for preconditioning. For example, after the transformation,
> the diagonal block is identity matrix ( e.g. [1,0,0;0,1,0;0,0,1]  for
> bs=3). One can extract a submatrix (e.g. corresponding to only first
> unknown) and apply special preconditioners for the extracted/decoupled
> matrix. The motivation is that after the transformation, one can get a
> better decoupled matrix to preserve the properties of the unknowns.
Barry's point is that this operation is usually rolled into the
preconditioner itself, as in his example of PBJACOBI. Are you building this
preconditioner yourself?
   Matt
> Thanks.
> Xiangdong
> On Tue, Feb 13, 2018 at 6:27 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
>>  In general you probably don't want to do this. Most good preconditioners
>> (like AMG) rely on the matrix having the "natural" scaling that arises from
>> the discretization and doing a scaling like you describe destroys that
>> natural scaling. You can use PCPBJACOBI to use point block Jacobi
>> preconditioner on the matrix without needing to do the scaling up front.
>> The ILU preconditioners for BAIJ matrices work directly with the block
>> structure so again pre-scaling the matrix buys you nothing. PETSc doesn't
>> have any particularly efficient routines for computing what you desire, the
>> only way to get something truly efficient is to write the code directly
>> using the BAIJ data structure, doable but probably not worth it.
>>   Barry
>> > On Feb 13, 2018, at 5:21 PM, Xiangdong <epscodes at gmail.com> wrote:
>> > Hello everyone,
>> > I have a block sparse matrices A created from the DMDA3d. Before
>> passing the matrix to ksp solver, I want to apply a transformation to this
>> matrix: namely A:= invdiag(A)*A. Here invdiag(A) is the inverse of the
>> block diagonal of A. What is the best way to get the transformed matrix?
>> > At this moment, I created a new mat IDA=inv(diag(A)) by looping through
>> each row and call MatMatMult to get B=invdiag(A)*A, then destroy the
>> temporary matrix B. However, I prefer the in-place transformation if
>> possible, namely, without the additional matrix B for memory saving purpose.
>> > Do you have any suggestion on compute invdiag(A)*A for mpibaij matrix?
>> > Thanks for your help.
>> > Best,
>> > Xiangdong
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180214/a6423219/attachment.html>
