[petsc-users] multiply a mpibaij matrix by its block diagonal inverse
Smith, Barry F.
bsmith at mcs.anl.gov
Tue Feb 13 17:27:08 CST 2018
In general you probably don't want to do this. Most good preconditioners (like AMG) rely on the matrix having the "natural" scaling that arises from the discretization and doing a scaling like you describe destroys that natural scaling. You can use PCPBJACOBI to use point block Jacobi preconditioner on the matrix without needing to do the scaling up front. The ILU preconditioners for BAIJ matrices work directly with the block structure so again pre-scaling the matrix buys you nothing. PETSc doesn't have any particularly efficient routines for computing what you desire, the only way to get something truly efficient is to write the code directly using the BAIJ data structure, doable but probably not worth it.
Barry
> On Feb 13, 2018, at 5:21 PM, Xiangdong <epscodes at gmail.com> wrote:
> Hello everyone,
> I have a block sparse matrices A created from the DMDA3d. Before passing the matrix to ksp solver, I want to apply a transformation to this matrix: namely A:= invdiag(A)*A. Here invdiag(A) is the inverse of the block diagonal of A. What is the best way to get the transformed matrix?
> At this moment, I created a new mat IDA=inv(diag(A)) by looping through each row and call MatMatMult to get B=invdiag(A)*A, then destroy the temporary matrix B. However, I prefer the in-place transformation if possible, namely, without the additional matrix B for memory saving purpose.
> Do you have any suggestion on compute invdiag(A)*A for mpibaij matrix?
> Thanks for your help.
> Best,
> Xiangdong
