[petsc-users] Accessing a field values of Staggered grid
Mohammad Hassan Baghaei mhbaghaei at mail.sjtu.edu.cn
Tue Feb 13 16:05:41 CST 2018
Thanks for your great note, Dave. Yeah! I would be able to at least view the edge values, although I could not specify the data. Previously I searched in points data, I now view the values by Surface With Edges option.
Sent: Wednesday, February 14, 2018 5:37 AM
To: Matthew Knepley <knepley at gmail.com>
Cc: Mohammad Hassan Baghaei <mhbaghaei at mail.sjtu.edu.cn>; PETSc <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Accessing a field values of Staggered grid
On 13 February 2018 at 21:17, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com> > wrote:
On Tue, Feb 13, 2018 at 3:21 PM, Mohammad Hassan Baghaei <mhbaghaei at mail.sjtu.edu.cn <mailto:mhbaghaei at mail.sjtu.edu.cn> > wrote:
Hi
I am filling the local vector from dm , has a section layout. The thing is I want to know how I can see the field variable values defined on edges, the staggered grid. In fact, Whenever I output to VTK in preview, I would be able to see the main grid. But the values which are defined on edges, I could not see them and that makes me unsure about the way I fill the local vector. How I would be babe to check the field value on staggered grid?
VTK does not have a way to specify data on edges, only on cells or vertices.
This is not entirely true.
At least for a staggered grid, where you have one DOF per edge, you can represent the edge data via the type VTK_VERTEX.
You won't generate a beautiful picture, as your field will be rendered as a set of points (your edge faces) - but you can at least inspect the values within ParaView.
  Dave
    Matt
Thanks
Amir
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180214/8293e284/attachment-0001.html>
