[petsc-users] Meaning of the order of PETSC_VIEWER_ASCII_INDEX format in PETSc
    Matthew Knepley
    knepley at gmail.com
    Wed Feb  7 13:16:46 CST 2018
On Wed, Feb 7, 2018 at 2:08 PM, Paula Sanematsu <paulasan at gmail.com> wrote:
> I am using PETSc 3.7.6 and Fortran.
> I am trying to output a PETSc vector that contains the solution of a
> linear system. I am using VecView with the PETSC_VIEWER_ASCII_INDEX format
> as follows:
> call PetscViewerASCIIOpen(PETSC_COMM_WORLD,"output.dat",viewer,ierr)
> call PetscViewerPushFormat(viewer,PETSC_VIEWER_ASCII_INDEX,ierr)
> call VecView(myVec,viewer,ierr)
> When I run with 4 processors, my output file looks like:
> Vec Object: 4 MPI processes
>   type: mpi
> Process [0]
> 0: 30.7501
> 1: 164.001
> 2: 41.0001
> 3: 164.001
> Process [1]
> 4988: 60.1443
> 4989: 157.257
> 4990: 271.518
> 4991: 366.669
> Process [2]
> 9977: 114.948
> 9978: -77.2896
> 9979: 823.142
> 9980: -1096.19
> Process [3]
> 14916: 0.
> 14917: 4.4056
> 14918: 2.08151
> 14919: -0.110862
> 19843: 0.
> My question is: each processor outputs the part of the vector that it
> owns? Or does PETSc collects each processor's parts and then processor 0
> sequentially outputs the 1st quarter of the global vector, processor 1
> outputs the 2nd quarter of the global vector, processor 2 outputs the 3rd
> quarter of the global vector, and so on? Or, does PETSc do something else?
There is no difference between those two. The process portions are
contiguous.
Where are you going to read this in? It seems like there must be a more
appropriate format for you.
    Matt
> Thank you!
> Paula
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180207/3cfa37fd/attachment.html>
