[petsc-users] Elliptic operator with Neumann conditions
Matthew Knepley
knepley at gmail.com
Wed Feb 7 11:57:56 CST 2018
On Thu, Feb 8, 2018 at 4:43 AM, Marco Cisternino <
marco.cisternino at optimad.it> wrote:
> Hi everybody,
> I would like to ask what solution is computed if I try to solve the linear
> system relative to the problem in subject without creating the null space.
> I tried with and without the call to
> MatNullSpaceCreate(m_communicator, PETSC_TRUE, 0, NULL, &nullspace);
> and I get zero averaged solution with and the same solution plus a
> constant without.
> How does PETSc work in the second case?
It depends on the Krylov method you use and the initial residual. We do not
do anything special.
Matt
> Does it check the matrix singularity? And is it able to create the null
> space with the constant automatically?
> Thanks.
> Marco Cisternino, PhD
> _______________________________
> OPTIMAD Engineering srl
> Via Giacinto Collegno 18, Torino, Italia.
> +3901119719782
> www.optimad.it
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180208/79075596/attachment.html>
