[petsc-users] Parallel output in PETSc with pHDF5 and VTK
Buesing, Henrik
hbuesing at eonerc.rwth-aachen.de
Wed Feb 7 07:11:53 CST 2018
> >>> Can PETSc use parallel HDF5?
> >> Yeah, the implementation is in VecView_MPI_HDF5_DA and uses
> >> H5FD_MPIO_COLLECTIVE if supported. Did you build your HDF5 with
> MPI?
> > I just --download-hdf5. Do I need to do something else?
> That should configure it with whichever MPI PETSc is using. How are you
> concluding that it's only using rank 0?
I have to ask back to the person working on the parallel IO. But if built and linked correctly, it should work in parallel with PETSCViewerHDF5Open and VecView?
