[petsc-users] Problem when solving matrices with identity matrices as diagonal block domains
Smith, Barry F.
bsmith at mcs.anl.gov
Thu Feb 1 09:20:37 CST 2018
1) By default if you call MatSetValues() with a zero element the sparse Mat will store the 0 into the matrix. If you do not call it with zero elements then it does not create a zero entry for that location.
2) Many of the preconditioners in PETSc are based on "nonzero entries" in sparse matrices (here a nonzero entry simply means any location in a matrix where a value is stored -- even if the value is zero). In particular ILU(0) does a LU on the "nonzero" structure of the matrix
Hence in your case it is doing ILU(0) on a dense matrix since you set all the entries in the matrix and thus producing a direct solver.
The lesson is you should only be setting true nonzero values into the matrix, not zero entries. There is a MatOption MAT_IGNORE_ZERO_ENTRIES which, if you set it, prevents the matrix from creating a location for the zero values. If you set this first on the matrix then your two approaches will result in the same preconditioner and same iterative convergence.
Barry
> On Feb 1, 2018, at 2:45 AM, Adrián Amor <aamor at pa.uc3m.es> wrote:
> Hi,
> First, I am a novice in the use of PETSC so apologies for having a newbie mistake, but maybe you can help me! I am solving a matrix of the kind:
> (Identity (50% dense)block
> (50% dense)block Identity)
> I have found a problem in the performance of the solver when I treat the diagonal blocks as sparse matrices in FORTRAN. In other words, I use the routine:
> MatCreateSeqAIJ
> To preallocate the matrix, and then I have tried:
> 1. To call MatSetValues for all the values of the identity matrices. I mean, if the identity matrix has a dimension of 22x22, I call MatSetValues 22*22 times.
> 2. To call MatSetValues only once per row. If the identity matrix has a dimension of 22x22, I call MatSetValues only 22 times.
> With the case 1, the iterative solver (I have tried with the default one and KSPBCGS) only takes one iteration to converge and it converges with a residual of 1E-14. However, with the case 2, the iterative solver takes, say, 9 iterations and converges with a residual of 1E-04. The matrices that are loaded into PETSC are exactly the same (I have written them to a file from the matrix which is solved, getting it with MatGetValues).
> What can be happening? I know that the fact that only takes one iteration is because the iterative solver is "lucky" and its first guess is the right one, but I don't understand the difference in the performance since the matrix is the same. I would like to use the case 2 since my matrices are quite large and it's much more efficient.
> Please help me! Thanks!
> Adrian.
