[petsc-users] Create a DM given sets of IS's
Matthew Knepley
knepley at gmail.com
Mon Dec 31 08:40:22 CST 2018
On Mon, Dec 31, 2018 at 2:40 AM Justin Chang via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi all,
> I am solving a six field battery problem (concentration and potential for
> each of the two solid and one electrolyte domains) and I want to experiment
> with nested/recursice fieldsplitting. I have the IS's and am able to use
> these to define my PCFieldSplitsSetIS(). However, I can imagine this
> getting really messy from a programming standpoint, especially once I need
> to add temperature into the mix, so it is my hope that I can translate
> these index sets and fields into a DM (maybe DMShell?) so that I can just
> rely on command line options to play around with various combinations of
> field assignments and splits (e.g. -pc_fieldsplit_X_fields)
> However, it doesn't seem clear to me how I would create a DM when you
> already know the IS's for each fields. If I understand functions like
> DMCreateFieldDecomposition() correctly, it seems that it returns to you the
> IS's and sub DM's associated with the original DM, whereas I want to do it
> the other way around. Perhaps the "reversal" of something like
> DMCreateFieldIS()
> <https://www.mcs.anl.gov/petsc/petsc-dev/src/dm/interface/dm.c.html#DMCreateFieldIS>,
> where you convert the IS into a PetscSection or is there an easier/better
> way?
> Any thoughts/help appreciated!
Paul has recently done this for LibMesh. I believe that constructing a
PetscSection is enough to get you minimally started. That allows
DMCreateSubDM() to work by subsetting the Section, and that should allow
the command line to work. CreateFieldDecomposition() should
be removed I think.
Matt
> Justin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181231/fa83b7d7/attachment.html>
