[petsc-users] Problems about Picard and NolinearGS
    Yingjie Wu
    yjwu16 at gmail.com
    Wed Dec 26 21:24:15 CST 2018
Thank you very much for your previous reply.
I pay attention to Picard and NonlinearGS method because I use snes_mf
method with preconditioning matrix to solve my problem. The quality of
preconditioning matrix and initial values seriously affect the convergence
of my problem. Because of the poor quality of the preconditioning matrix
and inability to give a reasonable initial value for my problem, the
convergence is not good. High-order ILU ( in my case ILU20) is needed to
ensure that the linear step residual can be reduced  to ksp_rtol 1e-2. In
the future, the program may expand more complex and convergence may be
worse. However, Picard and NonlinearGS are two method to ensure
convergence. Although the convergence rate is very slow, the results of
these two method can be used to provide a reasonable initial value for my
program. So I need a solver similar to Picard or GS's iterative method,
which is very useful for providing initial guess or comparing with the
original program.
I tried Picard method, which split original residual function
SNESComputeFunction F(x)=A(x)x - b(x) in to two part, give the right-hand
part of the equation b(x) to SNESPicardComputeFunction,and then transfer
the A(x) to SNESPicardComputeJacobian(in snes_mf , I use A(x) as
preconditioning matrix) . Because A(x) only include the relations within a
single physical field, it does not consider the relationship between
physical fields. So it is equivalent to the diagonal block part of the
Jacobian matrix J.
I really need some advice on my question.
Yingjie
Smith, Barry F. <bsmith at mcs.anl.gov> 于2018年12月26日周三 下午4:23写道:
>    Try with -snes_mf_operator from the manual page of SNESSetPicard() this
> indicates that  with Newton's method using A(x^{n}) to construct the
> preconditioner.
> > On Dec 26, 2018, at 7:48 AM, Yingjie Wu via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > Dear Petsc developers:
> > Hi,
> > 1. I tried to use the Picard solver in Petsc, but the program didn't
> converge. My program is still a thermal program that contains multiple
> physical fields, and is a PDEs' problem. The error message is as follows.
> The reason I use Picard is that it can guarantee convergence(though slow
> and expensive). I follow the ex15.c, but I don't use DM to organize the
> solution vector. So I try the SNESSetPicard().
> > 0 SNES Function norm 2.91302e+08
> >     0 KSP Residual norm 5.79907e+08
> >     1 KSP Residual norm 1.46843e-05
> >   Linear solve converged due to CONVERGED_RTOL iterations 1
> >   1 SNES Function norm 2.891e+08
> >     0 KSP Residual norm 5.5989e+08
> >     1 KSP Residual norm 4.21314e-06
> >   2 SNES Function norm 2.78289e+08
> >     0 KSP Residual norm 5.53553e+08
> >     1 KSP Residual norm 2.04076e-05
> >   3 SNES Function norm 2.77833e+08
> >     0 KSP Residual norm 5.52907e+08
> >     1 KSP Residual norm 2.09919e-05
> >   4 SNES Function norm 2.77821e+08
> >     0 KSP Residual norm 5.52708e+08
> >     1 KSP Residual norm 2.08677e-05
> > Nonlinear solve did not converge due to DIVERGED_LINE_SEARCH iterations 4
> > SNES Object: 1 MPI processes
> >   type: newtonls
> >   maximum iterations=50, maximum function evaluations=10000
> >   tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
> >   total number of linear solver iterations=5
> >   total number of function evaluations=34
> >   norm schedule ALWAYS
> >   SNESLineSearch Object: 1 MPI processes
> >     type: bt
> >       interpolation: cubic
> >       alpha=1.000000e-04
> >     maxstep=1.000000e+08, minlambda=1.000000e-12
> >     tolerances: relative=1.000000e-08, absolute=1.000000e-15,
> lambda=1.000000e-08
> >     maximum iterations=40
> >   KSP Object: 1 MPI processes
> >     type: gmres
> >       restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> >       happy breakdown tolerance 1e-30
> >     maximum iterations=10000, initial guess is zero
> >     tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
> >     left preconditioning
> >     using PRECONDITIONED norm type for convergence test
> >   PC Object: 1 MPI processes
> >     type: lu
> >       out-of-place factorization
> >       tolerance for zero pivot 2.22045e-14
> >       matrix ordering: nd
> >       factor fill ratio given 5., needed 5.48356
> >         Factored matrix follows:
> >           Mat Object: 1 MPI processes
> >             type: seqaij
> >             rows=11368, cols=11368
> >             package used to perform factorization: petsc
> >             total: nonzeros=234554, allocated nonzeros=234554
> >             total number of mallocs used during MatSetValues calls =0
> >               not using I-node routines
> >     linear system matrix = precond matrix:
> >       type: seqaij
> >       total: nonzeros=42774, allocated nonzeros=56840
> > Are there any other examples of Picard methods? I'm very interested in
> this method.
> > 2. I found that in ex15.c and ex19.c use the NonlinearGS. I know it's a
> iterative method. I don't know how to use this method in above examples.
> As for as I know, NonlinearGS is an iterative method parallel to subspace
> method. NonlinearGS should not be required if subspace methods are used.
> > Thanks,
> > Yingjie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181226/096e7874/attachment.html>
