[petsc-users] Problems about Picard and NolinearGS
Yingjie Wu
yjwu16 at gmail.com
Wed Dec 26 07:48:50 CST 2018
Dear Petsc developers:
1. I tried to use the Picard solver in Petsc, but the program didn't
converge. My program is still a thermal program that contains multiple
physical fields, and is a PDEs' problem. The error message is as follows.
The reason I use Picard is that it can guarantee convergence(though slow
and expensive). I follow the ex15.c, but I don't use DM to organize the
solution vector. So I try the SNESSetPicard().
0 SNES Function norm 2.91302e+08
0 KSP Residual norm 5.79907e+08
1 KSP Residual norm 1.46843e-05
Linear solve converged due to CONVERGED_RTOL iterations 1
1 SNES Function norm 2.891e+08
0 KSP Residual norm 5.5989e+08
1 KSP Residual norm 4.21314e-06
2 SNES Function norm 2.78289e+08
0 KSP Residual norm 5.53553e+08
1 KSP Residual norm 2.04076e-05
3 SNES Function norm 2.77833e+08
0 KSP Residual norm 5.52907e+08
1 KSP Residual norm 2.09919e-05
4 SNES Function norm 2.77821e+08
0 KSP Residual norm 5.52708e+08
1 KSP Residual norm 2.08677e-05
Nonlinear solve did not converge due to DIVERGED_LINE_SEARCH iterations 4
SNES Object: 1 MPI processes
type: newtonls
maximum iterations=50, maximum function evaluations=10000
tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
total number of linear solver iterations=5
total number of function evaluations=34
norm schedule ALWAYS
SNESLineSearch Object: 1 MPI processes
type: bt
interpolation: cubic
alpha=1.000000e-04
maxstep=1.000000e+08, minlambda=1.000000e-12
tolerances: relative=1.000000e-08, absolute=1.000000e-15,
lambda=1.000000e-08
maximum iterations=40
KSP Object: 1 MPI processes
type: gmres
restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
happy breakdown tolerance 1e-30
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
left preconditioning
using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
type: lu
out-of-place factorization
tolerance for zero pivot 2.22045e-14
matrix ordering: nd
factor fill ratio given 5., needed 5.48356
Factored matrix follows:
Mat Object: 1 MPI processes
type: seqaij
rows=11368, cols=11368
package used to perform factorization: petsc
total: nonzeros=234554, allocated nonzeros=234554
total number of mallocs used during MatSetValues calls =0
not using I-node routines
linear system matrix = precond matrix:
type: seqaij
total: nonzeros=42774, allocated nonzeros=56840
Are there any other examples of Picard methods? I'm very interested in this
method.
2. I found that in ex15.c and ex19.c use the NonlinearGS. I know it's a
iterative method. I don't know how to use this method in above examples.
As for as I know, NonlinearGS is an iterative method parallel to subspace
method. NonlinearGS should not be required if subspace methods are used.
Yingjie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181226/7a90c8a2/attachment.html>
