[petsc-users] GAMG scaling
Matthew Knepley
knepley at gmail.com
Fri Dec 21 11:58:15 CST 2018
On Fri, Dec 21, 2018 at 12:55 PM Zhang, Hong <hzhang at mcs.anl.gov> wrote:
> Matt:
>> Does anyone know how to profile memory usage?
>> The best serial way is to use Massif, which is part of valgrind. I think
>> it might work in parallel if you
>> only look at one process at a time.
> Can you give an example of using Massif?
> For example, how to use it on petsc/src/ksp/ksp/examples/tutorials/ex56.c
> with np=8?
I have not used it in a while, so I have nothing laying around. However,
the manual is very good:
http://valgrind.org/docs/manual/ms-manual.html
Matt
> Hong
>>> Hong
>>> Thanks, Hong,
>>>> I just briefly went through the code. I was wondering if it is possible
>>>> to destroy "c->ptap" (that caches a lot of intermediate data) to release
>>>> the memory after the coarse matrix is assembled. I understand you may still
>>>> want to reuse these data structures by default but for my simulation, the
>>>> preconditioner is fixed and there is no reason to keep the "c->ptap".
>>>> It would be great, if we could have this optional functionality.
>>>> Fande Kong,
>>>> On Thu, Dec 20, 2018 at 9:45 PM Zhang, Hong <hzhang at mcs.anl.gov> wrote:
>>>>> We use nonscalable implementation as default, and switch to scalable
>>>>> for matrices over finer grids. You may use option '-matptap_via scalable'
>>>>> to force scalable PtAP implementation for all PtAP. Let me know if it
>>>>> works.
>>>>> Hong
>>>>> On Thu, Dec 20, 2018 at 8:16 PM Smith, Barry F. <bsmith at mcs.anl.gov>
>>>>> wrote:
>>>>>> See MatPtAP_MPIAIJ_MPIAIJ(). It switches to scalable automatically
>>>>>> for "large" problems, which is determined by some heuristic.
>>>>>> Barry
>>>>>> > On Dec 20, 2018, at 6:46 PM, Fande Kong via petsc-users <
>>>>>> petsc-users at mcs.anl.gov> wrote:
>>>>>> > On Thu, Dec 20, 2018 at 4:43 PM Zhang, Hong <hzhang at mcs.anl.gov>
>>>>>> wrote:
>>>>>> > Fande:
>>>>>> > Hong,
>>>>>> > Thanks for your improvements on PtAP that is critical for MG-type
>>>>>> algorithms.
>>>>>> > On Wed, May 3, 2017 at 10:17 AM Hong <hzhang at mcs.anl.gov> wrote:
>>>>>> > Mark,
>>>>>> > Below is the copy of my email sent to you on Feb 27:
>>>>>> > I implemented scalable MatPtAP and did comparisons of three
>>>>>> implementations using ex56.c on alcf cetus machine (this machine has small
>>>>>> memory, 1GB/core):
>>>>>> > - nonscalable PtAP: use an array of length PN to do dense axpy
>>>>>> > - scalable PtAP: do sparse axpy without use of PN array
>>>>>> > What PN means here?
>>>>>> > Global number of columns of P.
>>>>>> > - hypre PtAP.
>>>>>> > The results are attached. Summary:
>>>>>> > - nonscalable PtAP is 2x faster than scalable, 8x faster than hypre
>>>>>> PtAP
>>>>>> > - scalable PtAP is 4x faster than hypre PtAP
>>>>>> > - hypre uses less memory (see job.ne399.n63.np1000.sh)
>>>>>> > I was wondering how much more memory PETSc PtAP uses than hypre? I
>>>>>> am implementing an AMG algorithm based on PETSc right now, and it is
>>>>>> working well. But we find some a bottleneck with PtAP. For the same P and
>>>>>> A, PETSc PtAP fails to generate a coarse matrix due to out of memory, while
>>>>>> hypre still can generates the coarse matrix.
>>>>>> > I do not want to just use the HYPRE one because we had to duplicate
>>>>>> matrices if I used HYPRE PtAP.
>>>>>> > It would be nice if you guys already have done some compassions on
>>>>>> these implementations for the memory usage.
>>>>>> > Do you encounter memory issue with scalable PtAP?
>>>>>> > By default do we use the scalable PtAP?? Do we have to specify some
>>>>>> options to use the scalable version of PtAP? If so, it would be nice to
>>>>>> use the scalable version by default. I am totally missing something here.
>>>>>> > Thanks,
>>>>>> > Fande
>>>>>> > Karl had a student in the summer who improved MatPtAP(). Do you use
>>>>>> the latest version of petsc?
>>>>>> > HYPRE may use less memory than PETSc because it does not save and
>>>>>> reuse the matrices.
>>>>>> > I do not understand why generating coarse matrix fails due to out
>>>>>> of memory. Do you use direct solver at coarse grid?
>>>>>> > Hong
>>>>>> > Based on above observation, I set the default PtAP algorithm as
>>>>>> 'nonscalable'.
>>>>>> > When PN > local estimated nonzero of C=PtAP, then switch default to
>>>>>> 'scalable'.
>>>>>> > User can overwrite default.
>>>>>> > For the case of np=8000, ne=599 (see job.ne599.n500.np8000.sh), I
>>>>>> get
>>>>>> > MatPtAP 3.6224e+01 (nonscalable for small mats,
>>>>>> scalable for larger ones)
>>>>>> > scalable MatPtAP 4.6129e+01
>>>>>> > hypre 1.9389e+02
>>>>>> > This work in on petsc-master. Give it a try. If you encounter any
>>>>>> problem, let me know.
>>>>>> > Hong
>>>>>> > On Wed, May 3, 2017 at 10:01 AM, Mark Adams <mfadams at lbl.gov>
>>>>>> wrote:
>>>>>> > (Hong), what is the current state of optimizing RAP for scaling?
>>>>>> > Nate, is driving 3D elasticity problems at scaling with GAMG and we
>>>>>> are working out performance problems. They are hitting problems at ~1.5B
>>>>>> dof problems on a basic Cray (XC30 I think).
>>>>>> > Thanks,
>>>>>> > Mark
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181221/b7960bfa/attachment-0001.html>
