[petsc-users] Question about PetscViewerHDF5SetTimestep usage
Smith, Barry F. bsmith at mcs.anl.gov
Thu Dec 20 21:38:29 CST 2018
  I don't understand. I run the program with both the maint and master branch and it works fine in both cases.
   Barry
> On Dec 20, 2018, at 8:58 PM, Sajid Ali via petsc-users <petsc-users at mcs.anl.gov> wrote:
> The example is the same as above. Link : https://pastebin.com/cAeZsUgA
> Here's what happens when I try to compile and run using petsc at 3.10.3: https://pastebin.com/EGVSxJu5
> Thank You,
> Sajid Ali
> Applied Physics
> Northwestern University
