[petsc-users] GAMG scaling
Fande Kong
fdkong.jd at gmail.com
Thu Dec 20 17:23:54 CST 2018
Hong,
Thanks for your improvements on PtAP that is critical for MG-type
algorithms.
On Wed, May 3, 2017 at 10:17 AM Hong <hzhang at mcs.anl.gov> wrote:
> Mark,
> Below is the copy of my email sent to you on Feb 27:
> I implemented scalable MatPtAP and did comparisons of three
> implementations using ex56.c on alcf cetus machine (this machine has
> small memory, 1GB/core):
> - nonscalable PtAP: use an array of length PN to do dense axpy
> - scalable PtAP: do sparse axpy without use of PN array
What PN means here?
> - hypre PtAP.
> The results are attached. Summary:
> - nonscalable PtAP is 2x faster than scalable, 8x faster than hypre PtAP
> - scalable PtAP is 4x faster than hypre PtAP
> - hypre uses less memory (see job.ne399.n63.np1000.sh)
I was wondering how much more memory PETSc PtAP uses than hypre? I am
implementing an AMG algorithm based on PETSc right now, and it is working
well. But we find some a bottleneck with PtAP. For the same P and A, PETSc
PtAP fails to generate a coarse matrix due to out of memory, while hypre
still can generates the coarse matrix.
I do not want to just use the HYPRE one because we had to duplicate
matrices if I used HYPRE PtAP.
It would be nice if you guys already have done some compassions on these
implementations for the memory usage.
Fande,
> Based on above observation, I set the default PtAP algorithm as
> 'nonscalable'.
> When PN > local estimated nonzero of C=PtAP, then switch default to
> 'scalable'.
> User can overwrite default.
> For the case of np=8000, ne=599 (see job.ne599.n500.np8000.sh), I get
> MatPtAP 3.6224e+01 (nonscalable for small mats, scalable
> for larger ones)
> scalable MatPtAP 4.6129e+01
> hypre 1.9389e+02
> This work in on petsc-master. Give it a try. If you encounter any problem,
> let me know.
> Hong
> On Wed, May 3, 2017 at 10:01 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> (Hong), what is the current state of optimizing RAP for scaling?
>> Nate, is driving 3D elasticity problems at scaling with GAMG and we are
>> working out performance problems. They are hitting problems at ~1.5B dof
>> problems on a basic Cray (XC30 I think).
>> Thanks,
>> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181220/fcdf8b59/attachment.html>
