[petsc-users] Can I use TAO for embarrassingly parallel problems with multiple threads?
    Krzysztof Kamieniecki
    krys at kamieniecki.com
    Thu Dec 20 15:52:25 CST 2018
Based on Barry's encouragement I spent the extra time to get back to
v3.10.2 and this code seems to work:
int mpierr;
MPI_Comm mpiCommRaw;
int tag = 0;
mpierr = MPI_Comm_dup(MPI_COMM_SELF, &mpiCommRaw); if(mpierr !=
MPI_SUCCESS) throw PSI::Exception("MPI ERROR: MPI_Comm_dup");
MPI_Comm mpiComm;
ierr = PetscCommDuplicate(mpiCommRaw, &mpiComm, &tag);
CHKERRABORT(PETSC_COMM_SELF, ierr);
Tao tao;
ierr = TaoCreate(mpiComm, &tao); CHKERRABORT(mpiComm, ierr);
ierr = TaoSolve(tao); CHKERRABORT(mpiComm, ierr);
ierr = TaoDestroy(&tao); CHKERRABORT(mpiComm, ierr);
ierr = PetscCommDestroy(&mpiComm); CHKERRABORT(PETSC_COMM_SELF, ierr);
mpierr = MPI_Comm_free(&mpiCommRaw); if(mpierr != MPI_SUCCESS) throw
PSI::Exception("MPI ERROR: MPI_Comm_free");
On Thu, Dec 20, 2018 at 4:06 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> > On Dec 20, 2018, at 2:24 PM, Krzysztof Kamieniecki via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > Hi Alp,
> > Thanks! This worked, I reverted back to v3.9.4 and after removing the
> monitors (which caused an error in PetscViewerASCIIPopTab) it seems to be
> passing tests for now.
> > (For the future peanut gallery) I misread what PetscCommDuplicate does,
> it does not duplicate Petsc communicators that already "wrap" MPI
> communicators, so I may look into MPI and creating a completely independent
> MPI_Comm for each thread.
>    Yes, this should work.
> > Best Regards,
> > Krys
> > On Thu, Dec 20, 2018 at 12:16 PM Dener, Alp <adener at anl.gov> wrote:
> > Hi Krys,
> >> On Dec 20, 2018, at 10:59 AM, Krzysztof Kamieniecki via petsc-users <
> >> That example seems to have critical sections around certain Vec calls,
> and it looks like my problem occurs in VecDotBegin/VecDotEnd which is
> called by TAO/BLMVM.
> > The quasi-Newton matrix objects in BLMVM have asynchronous dot products
> in the matrix-free forward and inverse product formulations. This is a
> relatively recent performance optimization. If avoiding this split phase
> communication would solve the problem, and you don’t need other recent
> PETSc features, you could revert to 3.9 and use the old version of BLMVM
> that will use straight VecDot operations instead.
> > Unfortunately I don’t know enough about multithreading to definitively
> say whether that will actually solve the problem or not. Other members of
> the community can probably provide a more complete answer on that.
> >> I assume  PetscSplitReductionGet is pulling the PetscSplitReduction for
> PETSC_COMM_SELF which is shared across the whole process?
> >> I tried PetscCommDuplicate/PetscCommDestroy but that does not seem to
> help.
> >> PetscErrorCode  VecDotBegin(Vec x,Vec y,PetscScalar *result)
> >>   PetscErrorCode      ierr;
> >>   PetscSplitReduction *sr;
> >>   MPI_Comm            comm;
> >>   PetscFunctionBegin;
> >>   PetscValidHeaderSpecific(x,VEC_CLASSID,1);
> >>   PetscValidHeaderSpecific(y,VEC_CLASSID,1);
> >>   ierr = PetscObjectGetComm((PetscObject)x,&comm);CHKERRQ(ierr);
> >>   ierr = PetscSplitReductionGet(comm,&sr);CHKERRQ(ierr);
> >>   if (sr->state != STATE_BEGIN)
> SETERRQ(PETSC_COMM_SELF,PETSC_ERR_ORDER,"Called before all VecxxxEnd()
> called");
> >>   if (sr->numopsbegin >= sr->maxops) {
> >>     ierr = PetscSplitReductionExtend(sr);CHKERRQ(ierr);
> >>   sr->reducetype[sr->numopsbegin] = PETSC_SR_REDUCE_SUM;
> >>   sr->invecs[sr->numopsbegin]     = (void*)x;
> >>   if (!x->ops->dot_local) SETERRQ(PETSC_COMM_SELF,PETSC_ERR_SUP,"Vector
> does not suppport local dots");
> >>   ierr = PetscLogEventBegin(VEC_ReduceArithmetic,0,0,0,0);CHKERRQ(ierr);
> >>   ierr =
> (*x->ops->dot_local)(x,y,sr->lvalues+sr->numopsbegin++);CHKERRQ(ierr);
> >>   ierr = PetscLogEventEnd(VEC_ReduceArithmetic,0,0,0,0);CHKERRQ(ierr);
> >>   PetscFunctionReturn(0);
> >> On Thu, Dec 20, 2018 at 11:26 AM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> >>    The code src/ksp/ksp/examples/tutorials/ex61f.F90 demonstrates
> working with multiple threads each managing their own collection of PETSc
> objects. Hope this helps.
> >>     Barry
> >> > On Dec 20, 2018, at 9:28 AM, Krzysztof Kamieniecki via petsc-users <
> >> > Hello All,
> >> > I have an embarrassingly parallel problem that I would like to use
> TAO on, is there some way to do this with threads as opposed to multiple
> processes?
> >> >  I compiled PETSc with the following flags
> >> > ./configure \
> >> > --prefix=${DEP_INSTALL_DIR} \
> >> > --with-threadsafety --with-log=0 --download-concurrencykit \
> >> > --with-openblas=1 \
> >> > --with-openblas-dir=${DEP_INSTALL_DIR} \
> >> > --with-mpi=0 \
> >> > --with-shared=0 \
> >> > --with-debugging=0 COPTFLAGS='-O3' CXXOPTFLAGS='-O3' FOPTFLAGS='-O3'
> >> > When I run TAO in multiple threads I get the error "Called
> VecxxxEnd() in a different order or with a different vector than
> VecxxxBegin()"
> >> > Thanks,
> >> > Krys
> > Alp
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181220/57c7be7d/attachment.html>
