[petsc-users] Can I use TAO for embarrassingly parallel problems with multiple threads?
Krzysztof Kamieniecki krys at kamieniecki.com
Thu Dec 20 14:24:55 CST 2018
Hi Alp,
Thanks! This worked, I reverted back to v3.9.4 and after removing the
monitors (which caused an error in PetscViewerASCIIPopTab) it seems to be
passing tests for now.
(For the future peanut gallery) I misread what PetscCommDuplicate does, it
does not duplicate Petsc communicators that already "wrap" MPI
communicators, so I may look into MPI and creating a completely independent
MPI_Comm for each thread.
Best Regards,
Krys
On Thu, Dec 20, 2018 at 12:16 PM Dener, Alp <adener at anl.gov> wrote:
> Hi Krys,
> On Dec 20, 2018, at 10:59 AM, Krzysztof Kamieniecki via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> That example seems to have critical sections around certain Vec calls, and
> it looks like my problem occurs in VecDotBegin/VecDotEnd which is called by
> TAO/BLMVM.
> The quasi-Newton matrix objects in BLMVM have asynchronous dot products in
> the matrix-free forward and inverse product formulations. This is a
> relatively recent performance optimization. If avoiding this split phase
> communication would solve the problem, and you don’t need other recent
> PETSc features, you could revert to 3.9 and use the old version of BLMVM
> that will use straight VecDot operations instead.
> Unfortunately I don’t know enough about multithreading to definitively say
> whether that will actually solve the problem or not. Other members of the
> community can probably provide a more complete answer on that.
> I assume  PetscSplitReductionGet is pulling the PetscSplitReduction for
> PETSC_COMM_SELF which is shared across the whole process?
> I tried PetscCommDuplicate/PetscCommDestroy but that does not seem to help.
> PetscErrorCode  VecDotBegin(Vec x,Vec y,PetscScalar *result)
>   PetscErrorCode      ierr;
>   PetscSplitReduction *sr;
>   MPI_Comm            comm;
>   PetscFunctionBegin;
>   PetscValidHeaderSpecific(x,VEC_CLASSID,1);
>   PetscValidHeaderSpecific(y,VEC_CLASSID,1);
>   ierr = PetscObjectGetComm((PetscObject)x,&comm);CHKERRQ(ierr);
>   ierr = PetscSplitReductionGet(comm,&sr);CHKERRQ(ierr);
>   if (sr->state != STATE_BEGIN)
> SETERRQ(PETSC_COMM_SELF,PETSC_ERR_ORDER,"Called before all VecxxxEnd()
> called");
>   if (sr->numopsbegin >= sr->maxops) {
>     ierr = PetscSplitReductionExtend(sr);CHKERRQ(ierr);
>   sr->reducetype[sr->numopsbegin] = PETSC_SR_REDUCE_SUM;
>   sr->invecs[sr->numopsbegin]     = (void*)x;
>   if (!x->ops->dot_local) SETERRQ(PETSC_COMM_SELF,PETSC_ERR_SUP,"Vector
> does not suppport local dots");
>   ierr = PetscLogEventBegin(VEC_ReduceArithmetic,0,0,0,0);CHKERRQ(ierr);
>   ierr =
> (*x->ops->dot_local)(x,y,sr->lvalues+sr->numopsbegin++);CHKERRQ(ierr);
>   ierr = PetscLogEventEnd(VEC_ReduceArithmetic,0,0,0,0);CHKERRQ(ierr);
>   PetscFunctionReturn(0);
> On Thu, Dec 20, 2018 at 11:26 AM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
>>    The code src/ksp/ksp/examples/tutorials/ex61f.F90 demonstrates working
>> with multiple threads each managing their own collection of PETSc objects.
>> Hope this helps.
>>     Barry
>> > On Dec 20, 2018, at 9:28 AM, Krzysztof Kamieniecki via petsc-users <
>> > Hello All,
>> > I have an embarrassingly parallel problem that I would like to use TAO
>> on, is there some way to do this with threads as opposed to multiple
>> processes?
>> >  I compiled PETSc with the following flags
>> > ./configure \
>> > --prefix=${DEP_INSTALL_DIR} \
>> > --with-threadsafety --with-log=0 --download-concurrencykit \
>> > --with-openblas=1 \
>> > --with-openblas-dir=${DEP_INSTALL_DIR} \
>> > --with-mpi=0 \
>> > --with-shared=0 \
>> > --with-debugging=0 COPTFLAGS='-O3' CXXOPTFLAGS='-O3' FOPTFLAGS='-O3'
>> > When I run TAO in multiple threads I get the error "Called VecxxxEnd()
>> in a different order or with a different vector than VecxxxBegin()"
>> > Thanks,
>> > Krys
>> Alp
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181220/337586ba/attachment.html>
